- Classic Cylinder Heatsink and Spiral Aluminum Fins
Optimized Structure
- 6 Copper Heatpipes
- 80mm Blow Fan
- 19 dBA Low Noise Performance
- VR Fan Control
Smart Airflow Design
- Also Cooling Down Surrounding Components
- 360 Degree Heat Dissipation
Specification
- Heatsink Dimension 121.63mm x 90mm x 151.85mm (L x W x H)
- Heatsink Material 50 Aluminum Fins + Copper & Aluminum Base
- Heatpipe 60mm x 6
- Fan Dimension 80mm x 85mm
- Rated Voltage 12 V
- Stared Voltage 7 V
- Rated Current 0.45 A
- Power Input 5.4 W
- Fan Speed 1000 ~ 1600 RPM
- Noise 19 ~ 28dBA
- Max. Air Flow 86.5 CFM
- LED Fan Blue LED
- Life Time 50,000 Hours
- Connector 3 Pin
- Weight 667 g
Compatibility
Optimized Structure
- 80mm Blow Fan
- VR Fan Control
Specification
- Heatpipe 60mm x 6
- Power Input 5.4 W
- Noise 19 ~ 28dBA
- LED Fan Blue LED
- Connector 3 Pin
- Weight 667 g
Compatibility
