D-Tek Fuzion V2 V.S. Heatkiller Rev3.0
  • #31
    ขอบคุณกับผลเทสครับ กำลังเล็งๆอยู่พอดี
    • #32
      สวยงามได้ใจเลยครับ
      GLORIOUS PC MASTER RACE
      May your frame rate be mighty and your draw distance far.
      • #33
        • #34
          ไม่ได้เล่นน้ำมาซักปีกว่าๆ แล้วทบทวนความรู้หน่อยแล้ว ครั้งก่อนเล่นแบบลูกทุ่งมีอะไรยัดใส่หมด
          ตัวนี้เป็นไงครับ เคยเล็งๆ ดูไหม
          ****** NEW ****** Alphacool HF 14 Yellowstone Socket 775/1366/1160 Ultimate CPU Water Block
          Model: 12034
          Product Details:
          The Ultimate CPU Water Block!
          This cooler does not only offer good performance in cooling efficiency and flow on most diverse CPU types; it also has a distinctive feature, which makes it unique among the crowd of Water-cooling:
          This cooler has particularly been optimized for Intel ® Nehalem ® processors.
          In order to meet the enormous expectations referring to the cooling performance, the water flow focus on important scopes within the CPU, in order to offer extra achievements amid this CPU models. This cooler is generally suitable for all other CPU models and reaches here too a high performance Level*.
          The cooler relies on the successful and patented principle from the combination of more tightly focused water supply and return flow. The internal structure however has been completely new designed.
          Characteristics overview:
          High -cooling Performance for all Standard Intel ®CPU and AMD ® Models *
          Extra plus performance for Intel Nehalem CPUs: particularly geometry adapted cooling fluid flow in the CPU.
          High- flow up to 4,9 Liters per Minute
          Direct vertical water supply into the centered incorporated pre-chamber, from there the liquid is led and aimed at the cooler base, without losses by detour of water.
          Full metal version:
          - Top/nozzle combination made of full metal, brass, media blasted and with clear lacquer protected from starting and castings permanently.
          - Integrated aluminum mounting plate, anodized (no contact to hydrophilic areas)
          - Electrolyte copper base plate with pin structure (pin surface covers completely CPU core) with high plan bottom plate surface, pin structure media blasted. The pin structure of our CPU cooler bottom plate has been optimized and further developed on the most recent cooler geometry.
          Practical and safe mounting plate: The mounting plate screws are secured against coincidental dismantling by a high lock nut plus lock washer. As a result of the high design of the screw nut this can be tightened comfortably and firmly by simply using the fingers. During the assembly of the screw nut, the screw are fixed with the enclosed hexagonal pin spanner; consequently preventing dangerous assemblies with screwdriver and pliers, which can damage the Main board when slipping.
          High-Quality manufacture Made in Germany
          *For AMD CPUs an appropriate version of the cooler will be available soon.
          Included in delivery:
          Blister Retail packing, thermal compound, instructions and mounting screws
          Technical data:
          Connecting thread: 2x G ¼ internal thread
          Flow indicator: up to 4, 9 liter/min.
          Weight: 410 gr
          Compatible with socket: Intel 1366, 1166 and socket 775
          • #35
            H Killer vs Swit GTZ only karp !
