น่าสนอ่ะ แต่ราคาแพง กันไปเล่นน้ำดีกว่าครับ
ทำ Heaksink เดิม พัดลมเดิม ให้อุณหภูมิลดลงได้ประมาณ 10 องศา สนใจมั๊ยครับ
พอดีไปหามาครับ มีเป็นหลอดขายด้วยสำหรับ หยดหน้าสัมผัส cpu ตัวยาเค้าบอกว่าเหมือนกันครับ
Introducing Arctic Alumina Thermal Compound the first ceramic-based, polysynthetic thermal compound for use between modern high-power CPUs and high performance heatsinks or water-cooling solutions.
@Made with micronized aluminum oxide and boron nitride:
Arctic Alumina uses a layered composite of three unique shapes and sizes of ceramic particles to maximize particle-to-particle contact area and thermal transfer. This exclusive combination provides performance exceeding most metal based compounds.
@Controlled triple phase viscosity:
Arctic Alumina does not contain any silicone. The suspension fluid is a proprietary mixture of advanced polysynthetic oils that work together to provide three distinctive functional phases. As it comes from the tube, Arctic Alumina's consistency is engineered for easy application in a thin even layer. During the CPU's initial use, the compound thins out to enhance the filling of the microscopic valleys and ensure the best physical contact between the heatsink and the CPU core. Then the compound thickens slightly over the next 50 to 200 hours of use to its final consistency designed for long-term stability.
NOTE: (This should not be confused with conventional phase change pads that are pre-attached to many heatsinks. Those pads melt each time they get hot then re-solidify when they cool. The viscosity changes that Arctic Alumina goes through are much more subtle and ultimately much more effective.)
This 1.75 gram tube is enough compound to cover at least 25 to 35 small CPU cores, or 9 to 15 large CPU cores, or 4 to 8 heat plates. At a layer 0.003" thick, one tube will cover approximately 24 square inches.
ตัวนี้เหมือนผมจะเคยซื้อที่ overclockstore.com ถ้าจำไม่ผิด มันเย็นใช้ได้เลยล่ะOriginally posted by sirapob View Postพอดีไปหามาครับ มีเป็นหลอดขายด้วยสำหรับ หยดหน้าสัมผัส cpu ตัวยาเค้าบอกว่าเหมือนกันครับ
มันสามารถล้างออกได้ด้วย Solvent กับพวก Degreaser อ่ะครับ ถ้าไม่ล้างด้วยพวกนี้ก็ไม่ลอกครับOriginally posted by kapoogloog View Postแล้ว พวกนี้มันเกอะ ไปตลอดไหมครับ หรือ อยู่ได้แปปเดียว
คือระยะเวลาการใช้ 1 ครั้ง ต่อการพ่น 1 ครั้งอะครับ
ดูการทดสอบด้วยน้ำแรงดันสูงได้ที่นี่ครับ
ตัวนี้ลักษณะการใช้จะไม่เหมือนกับที่ผมนำเสนอซะทีเดียวนะครับ คือของผมเป็นตัวพ่นที่ผิว Heatsink เพื่อเพิ่มพื้นที่สัมผัสอากาศให้ฮีตซิงค์โดยจะเป็น Boron Nitride เพียวๆ ส่วนตัวนี่ที่พี่ sirapob เอามาให้ดู เป็นตัวประสานระหว่าง CPU กับ Heatsink โดยจะมี aluminum oxide มาเป็นตัวประสานโดยคุณสมบัติการนำความร้อนที่ดีก็มาจาก Boron Nitride นั่นเองครับ
Originally posted by Explosively View Postเห็นราคาแล้ว
จ่ายคนเดียวคงไม่ไหว น่าจะหาคนหุ้นซัก 10-20 คน
นั่นราคาสำหรับกระป๋องใหญ่เพื่อใช้กับรถยนต์ครับ มีกระป๋องเล็กด้วยค้าบ แต่ราคายังไม่กำหนดครับ ขออภัยอย่างสูง แต่ถ้าพี่จะซื้อกระป๋องใหญ่ก็ได้ครับ พ่นมันทั้งบอร์ดเลย เย็นสบาย เพราะ ตัวนี้ไม่นำไฟฟ้าครับ
ส่งเมล์ไปแล้ว พี่ๆ OCZ ไม่ตอบกลับมาเลยครับพี่ เลยมีแต่ผลการทดสอบของนอกมาให้ดูแก้ร้อนครับOriginally posted by pchutchawan View Postลองส่งมาให้พี่ๆ OCZ เขาทดสอบขึ้น web ดูสิครับ
ฟังดูน่าสนดี
แต่ผมก็ยังอยากให้พี่ๆ OCZ ทำ test นะครับ ลองกันให้สุดๆไปเลย ยังรอเมล์อยู่นะครับ
หรือถ้าทางทีมงานไม่เห็นเมล์ผมแต่มาอ่านกระทู้นี้ ติดต่อได้ที่ ponlatep@hotmail.com เลยนะครับ
ขอตอบพี่ =-SaMmY- เป็นข้อๆดังนี้นะครับOriginally posted by -SaMmY- View Postเท่าที่อ่านดูผมว่าตัวที่เหมาะกับคอมคือRed Version
แต่ยังมีคำถามคือ พอพ่นแล้วมันแห้งแข็งเลยหรือไม่ ตืิดมือรึเปล่าถ้าไปโดน
สามารถเอามันออกได้หรือไม่
ข้อสำคัญนำไฟฟ้ารึเปล่า
เพราะถ้ามันไม่แห้งแข็งและนำไฟฟ้า จะอันตรายพอควร
่ถ้าแน่นติดหนึบเอาออกไม่ได้ นั่นหมายความว่าอุปกรณ์ชิ้นนั้นหมดประกันทันที
แต่น่าลองมากมาย
แต่ยังมีคำถามคือ พอพ่นแล้วมันแห้งแข็งเลยหรือไม่ ตืิดมือรึเปล่าถ้าไปโดน สามารถเอามันออกได้หรือไม่
พ่นแล้วแห้งแข็งเลยครับ ถ้าบังเอิญติดมือสามารถล้างออกได้ด้วย Solvent หรือ Degraser ครับ
เหมือนข้อข้างบนนะครับ
ไม่นำไฟฟ้าชัวร์ๆครับ
เอาออกได้โดยวิธีข้างบนนะครับ
