CPU Support
Intel® Core™2 Extreme/ Core™2 Quad (Quad-Core)
Intel® Core™2 Duo/ Pentium® Dual Core/ Pentium® D (Dual-Core)
Intel® Pentium® 4 HT/Celeron® D
AMD Athlon™ 64 FX
AMD Athlon™ 64 X2
AMD Athlon™ 64
AMD Phenom™ FX/X3/X4
AMD Sempron™
CPU Socket Intel LGA 775
AMD 754/939/940
AMD AM2/AM2+/socket F(1207)/1207+
Dimensions (L x W x H) 90 (L) x 78 (W) x 125 (H) mm
Net Weight (g) 470 g
Heatsink Material Cu. Base + Al. Fins + 3 x 6mm Copper Heat Pipes
Fan Dimension (mm)
92 x 92 x 25
Bearing Type
Vapo
Connector
4 Pin with PWM Control
Speed
2300 rpm ± 10%
Max. Airflow
36.5 CFM
Max. Air Pressure
2.8 mm-H2O
