Eclipse กับ Mars CPU Cooler / CoolerMaster
อันไหนดีกว่ากัน
Mars
Socket Type Intel LGA 775, AMD Socket (754/ 939/ 940 / AM2 / F)
Heat Sink Dimensions 132 x 120 x 105mm
Heat Sink Material Aluminum Fin + Copper base + 3 Heat pipes
Fan Dimension (W / H / D) 90 x 25.4 mm
Fan Speed 900~3000 R.P.M.
Fan Airflow 55.3 CFM (Max).
Bearing Type Sleeve Bearing
Fan Life Expectancy 40,000 hours
Fan Noise Level (dB-A) 17 dBA (Min),
Connector 4 pin
Weight 672 g
Voltage 12 V
Fan Speed Adjustment 1. Silent Mode:1800R.P.M. 2. Performance Mode: 3000R.P.M. 3. PWM Mode: 900~2500 R.P.M.
UPC Code 870423003595
Eclipse
Socket Type Intel LGA775,AMD Socket (AM2/ 940/939/754)
Heat Sink Dimensions 132 x 120 x 105 mm
Fan Dimension (W / H / D) 66 x 68 mm
Fan Speed 900~3300 R.P.M.
Fan Airflow 39.8 CFM
Bearing Type Long life sleeve bearing
Connector 4 pin
Weight 670 g
Heat Sink Material Copper base with 4 heat pipes
Voltage 12 V
Fan Speed Adjustment Silent Mode: 1800 R.P.M.
UPC Code 870423003618
1,990 บาท Tkcom
ว่าจะเอามาใส่ใน Smilodon จะได้ป่าวคับ
อันไหนดีกว่ากัน
Mars
Connector 4 pin
Weight 672 g
Voltage 12 V
Eclipse
Connector 4 pin
Weight 670 g
Voltage 12 V
1,990 บาท Tkcom
