FREEZEMOD Model: TSRP-ZT-360TG
Material: copper fin + copper water chamber + copper guard plate (T2 copper)
Hole position: G1/4*2
Pressure test: 1bar
Compatible fan: 12cm*12cm*2.5cm fan
Number of pipes: double round tubes, 6 tubes per layer
Channel specification: 7mm*0.28mm*6pcs (inner diameter of copper pipe is more than 6mm, increase the passage of water flow and impurities in the liquid)
Fin density: one inch = 18.5 strips
Fin thickness 0.11mm
Pressure test: 1bar
