V10 ติดพัดลม 2 ตัว โฮ่ๆๆๆ
Cooler Master V8เมื่อไรจะมีขายในไทยครับ
Specifications of V8
CPU Socket Intel Socket LGA775
AMD Socket (Socket 940/AM2/AM2+)
CPU Support Intel: Core 2 Extreme, Core 2 Quad, Core 2 Duo, Pentium Extreme Ed., Pentium Dual-Core, Pentium D, Pentium 4 Extreme Ed., Pentium 4 HT, Pentium 4, Celeron Dual-Core, Celeron D
AMD:Phenom, Athlon 64 X2, Athlon X2, Sempron
Dimensions 120 x 128 x 161.1mm
Weight 865g
Heat Sink Dimensions 120 x 120 x 158mm
Heat Sink Material Copper Base / Aluminum Fins / 8 Heat Pipes
Heat Pipes Dimensions 6mm
Fan Dimension (W / H / D) 120 x 120 x 25mm
Fan Speed 800 - 1800RPM
Fan Airflow 69.69CFM
Air pressure (mmH2O) 2.94mm H2O
Bearing Type Rifle Bearing
Fan Life Expectancy 40,000hrs
Fan Noise Level (dB-A) 17 - 21dBA
Fan Speed Adjustment Install on PCI Slot
Connector 4-pin
Fan Control PWM + VR Controller
Rated Voltage 12V
Start Voltage 7V
Operating Voltage 10.38V - 13.2V
Rated Current 0.12A
Input Power 1.44W
