call 089-1090817 T
sale about 1200
ของแทบใหม่เลย ใช้มาไม่ถึงเดือนครับ อุปกรณ์ครบกล่องเลย
CPU Socket Intel Socket LGA775
AMD Socket (AM2/ 940/939/754)
CPU Support Intel
Core 2 Extreme, Core 2 Quad, Core 2 Duo,
Pentium Extreme, Pentium Dual-Core, Pentium D, Pentium 4,
Celeron Dual-Core, Celeron D, Celeron
AMD
Phenom,
Athlon 64 FX,Athlon 64 X2,Athlon X2,
Sempron
Dimensions Φ113 x 132 mm
Weight 684.54 g
Heat Sink Material 100% copper heatsink with 4 heatpipes
Heat Pipes Dimensions Φ6 mm
Fan Type Blue LED Fan
Fan Dimension (W / H / D) Φ66 x 68 mm
Fan Speed 2200 R.P.M.
Fan Airflow 84.7 CFM
Bearing Type Long life sleeve
Fan Life Expectancy 40,000 hours
Fan Noise Level (dB-A) 22 dBA
Connector 3-pin
Rated Voltage 12 V
Start Voltage 6 V
Operating Voltage 6~13.8 V
Rated Current 0.4 A
Input Power 4.8 W
sale about 1200
CPU Support Intel
AMD
Phenom,
Sempron
Weight 684.54 g
Connector 3-pin
Rated Voltage 12 V
Start Voltage 6 V
Rated Current 0.4 A
Input Power 4.8 W
