Originally posted by loveniknak
Screen Size 27"W
Viewable Image Size 68.56cm
Pixel Pitch 0.311(H)?0.311 (V)mm
Display Area 597.6(H)?336.15 (V)mm
Brightness 2D 250 cd/m?
Contrast Ratio (typical) 20000000:1 (DCR)
Response Time (typical) 5ms
Viewing Angle 178/178 (CR?10)
Scan Frequency H: 30K~83KHz V: 50~76Hz
Pixel Frequency 144MHz
Recommended Resolution 1920?1080@60Hz
Display Colours 16.7M
HDCP Compatible Yes
Input Signal Analog RGB, HDMI*2
Input Connector 15-pin D-Sub and HDMI*2
Power Supply 110~240VAC, 50/60Hz
Power Consumption Power On: <40W?Typical), Standby: <0.5W
Plug & Play VESA DDC2B? & DDC2B/CI
User Control ECO/< ,Aspect Ratio/>,Source/Auto,Power
OSD Languages 16Languages
Speakers Yes
Safety & Regulations CB/CE,FCC, KCC, ISO 9241-307,BSMI,EPA,TCO5.0,VCCI,PSE,J-MOSS,WIN7,EPEAT Silver; C-tick,CKT,E-standby.
Wall-Mount NA
Cabinet Colour Black & Sliver
Mechanical Function Tilt: -5?~15?
W?H?D (w/base)mm 622? 499 ?130
W?H?D (package)mm 714?140?490
Weight (Net /Gross) 5.7Kg/7.95Kg
