putter taylor made
  • putter taylor made
    Similar to its Ghost Spider predecessor, Taylormade ghost putter the new Ghost Manta provides the performance benefits of a high-MOI (moment of inertia) putter, TaylorMade RBZ Driver but is packaged neatly in a more traditional one-piece neo-mallet shape that is sure to appeal to a wide range of golfers.
    An update to its Ghost predecessors, Mizuno MP-650 Driver the Ghost Manta features a new flat matte white finish which helps golfers align themselves to the putt more easily. Key to the alignment performance of the Ghost Manta is its wide-bodied frame, Taylor Made Ghost Tour Putter which features two black rails on the top of the putter head that frame the golf ball and contrast with the white top to help improve alignment and visibility.Taylormade Tour PREFERRED Ghost Putter In additon, the Ghost Manta features a new double-bend shaft, which provides the correct amount of offset without the shaft distracting from the putt. R11S Fairway Wood
    Weighting system provides high MOI
    The Ghost Manta features two 50-gram tungsten weights on the heel and toe of the sole, which are designed to stabilise the putter and increase MOI. Taylormade golf This high MOI produces consistent speed on off-centre hits. There is also a third adjustable weight in the back-centre of the sole (additional weights may be purchased separately). Titleist Driver The stock 33 and 34-inch putter heads weigh 360 grams, whereas the 35-inch putter head weighs 370 grams and the belly putter head weight is 380 grams. The head weight of the Ghost Manta long version is 440 grams.
    best Golf clubs
    Taylormade Ghost Putter
    taylormade rossa putter
