ช่วยดุให้หน่อยครับ ผมทำตามขั้นตอนแล้ว
  • ช่วยดุให้หน่อยครับ ผมทำตามขั้นตอนแล้ว
    For Lion users
    YOU MUST HAVE XCODE INSTALLED TO CRACK THE PRODUCT
    1. Install Autodesk Autocad 2012 MACOSX
    2. Finish the installation & restart Autocad Product
    3. Use Serial 666-69696969 and Product Key 777D1
    4. Select I have an activation code from Autodesk
    5. Open Activity monitor, find Autodesk License Manager and note down it's PDID number in left column.
    6. Now open Terminal and execute this command:
    vmmap -resident -interleaved PID (replace PDID with the number you wrote down from Activity Monitor)
    7. Find libadlmact_libFNP.dylib" and note the base of the __TEXT segment which will be a hexadecimal number.
    8. In terminal, execute these commands and enter password
    cd /
    sudo gdb volumes/"autocad 2012_mac"/crack/xforce2012.app/Contents/MacOS/x-force
    9. Set the breakpoint by executing this command:
    b *0x32c2
    10. Type 'r' and enter to run kegen or if it doesn't work, type 'file' press space and drag xforece app to terminal and press enter?. then press 'r' and enter to run.
    11. Copy request code in the keygen and press generate. Now copy the activation code and paste it in autodesk license windows. but do not press next.
    11. Click on 'Mem Patch' in the keygen window.
    12. Now run the last command in terminal window:
    set $eax=0xADDRESS
    replace the word address with the Hexadecimal one you found in terminal window.
    13. In terminal, press 'c' and enter. All done
    Now you can get back and click on 'Next' button in Autodesk License window.
    ติดปัญหาที่ตัวหนังสือสีแดงอ่ะ ผมทำตามไม่ได้ ใครรู้ช่วยสอน หน่อยครับรบกวนด้วยน่ะครับ
