สเป็คแบบนี้ใช้แผ่นอะไรดีครับ
  • สเป็คแบบนี้ใช้แผ่นอะไรดีครับ
    ใช้แผ่นอะไรดีครับเสิร์ทในอากู๋ว่าอะไรแล้วต้องเลือกลงอะไรบ้างครับ
    แล้วในไบออสต้องปรับอะไรบ้างครับ
    CPU-Z TXT Report
    Binaries
    CPU-Z version 1.56
    Processors
    Number of processors 1
    Number of threads 2
    APICs
    Processor 0
    -- Core 0
    -- Thread 0 0
    -- Thread 1 1
    Processors Information
    Processor 1 ID = 0
    Number of cores 1 (max 1)
    Number of threads 2 (max 2)
    Name Intel Pentium 4 520
    Codename Prescott
    Specification Intel(R) Pentium(R) 4 CPU 2.80GHz
    Package (platform ID) Socket 775 LGA (0x4)
    CPUID F.4.1
    Extended CPUID F.4
    Core Stepping E0
    Technology 90 nm
    Core Speed 2793.1 MHz
    Multiplier x FSB 14.0 x 199.5 MHz
    Rated Bus speed 798.0 MHz
    Stock frequency 2800 MHz
    Instructions sets MMX, SSE, SSE2, SSE3
    L1 Data cache 16 KBytes, 8-way set associative, 64-byte line size
    Trace cache 12 Kuops, 8-way set associative
    L2 cache 1024 KBytes, 8-way set associative, 64-byte line size
    FID/VID Control no
    Chipset
    Northbridge Intel P35/G33/G31 rev. 10
    Southbridge Intel 82801GB (ICH7/R) rev. A1
    Memory Type DDR2
    Memory Size 2048 MBytes
    Channels Dual, (Symmetric)
    Memory Frequency 332.5 MHz (3:5)
    CAS# latency (CL) 5.0
    RAS# to CAS# delay (tRCD) 5
    RAS# Precharge (tRP) 5
    Cycle Time (tRAS) 14
    Row Refresh Cycle Time (tRFC) 44
    Command Rate (CR) 2T
    Monitoring
    Mainboard Model G31T-M9 (0x000001B2 - 0x004EE3D9)
    DMI
    DMI BIOS
    vendor American Megatrends Inc.
    version 080014
    date 10/15/2009
    DMI System Information
    manufacturer ECS
    product G31T-M9
    version 1.0
    serial 00000000
    UUID 00020003-00040005-00060007-00080009
    DMI Baseboard
    vendor ECS
    model G31T-M9
    revision 1.0
    serial 00000000
    DMI System Enclosure
    manufacturer ECS
    chassis type Desktop
    chassis serial 00000000
    DMI Processor
    manufacturer Intel
    model Intel(R) Pentium(R) 4 CPU 2.80GHz
    clock speed 2800.0 MHz
    FSB speed 200.0 MHz
    multiplier 14.0x
    DMI Memory Controller
    correction 64-bit ECC
    Max module size 4096 MBytes
    DMI Memory Module
    designation DIMM0
    size 1024 MBytes (single bank)
    DMI Memory Module
    designation DIMM1
    DMI Physical Memory Array
    location Motherboard
    usage System Memory
    correction None
    max capacity 4096 MBytes
    max# of devices 2
    DMI Memory Device
    designation DIMM0
    format DIMM
    type SDRAM
    total width 64 bits
    data width 64 bits
    size 1024 MBytes
    DMI Memory Device
    designation DIMM1
    format DIMM
    type SDRAM
    total width 64 bits
    data width 64 bits
    size 1024 MBytes
    Graphics
    Number of adapters 1
    Graphic APIs
    Display Adapters
    Display adapter 0
    Name Intel(R) G33/G31 Express Chipset Family
    Memory size 256 MB
    PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
    Vendor ID 0x8086 (0x1019)
    Model ID 0x29C2 (0x2699)
    Performance Level 0
    Software
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
    DirectX Version 11.0
    ครั้งที่แล้วๆลงKalywayแล้วติดตอนบูทมันวิ่งกลมๆไม่ผ่านกลมๆสักที(ลงได้แล้วแต่ติดตอนบูธ)
    รบกวนทีครับ
    มีครายฮู้ไหม
      เอิกๆยังบ่มี
        ลอง iAtkos 10.6.3 S3 V2 ดูดีมะ
        key word ในอากู๋ : ECS G31T-M9, wiki, osx86, insanelymac... นึกออกแค่นี้คับ
        ฝากดู http://wiki.osx86project.org/wiki/in...HCL_10.6.3#ECS, http://wiki.osx86project.org/wiki/index.php/HCL_10.6.5
