!!NON-WORKING!!
These make the 5100/5300 show up as an ethernet card. Although it doesn't work, it's a great step forward. I'm offering it up to the public hoping maybe some user exp or not might find a way to rig it up and make it work.
********NOTICE********
ok i just uploaded a newer test installer package.
make sure to delete the previous iwi4965.kext first. from your extensions folder.
What steps will reproduce the revelation?
1. Download Attached zip file which is the iwi4965 package/installer and a
modified iwi4965 kext.
2. Open installer and install fully. Once it is completed DO NOT CLICK
RESTART.
3. Go to extensions folder and delete the iwi4965.kext.
4. Open up Kext Helper B7 (Use Google to download)
Tick the advanced box, click the button "Kext Permissions" in lower left.
5. Import modified iwi4965.kext included in zip.
6. Type password in the field and then click button "Easy Install".
7. Once finished, STILL DO NOT CLICK RESTART.
OS X should now notify you it found a new network interface, click ok and
when window opens up click apply.
As you can see it shows up as an ethernet card and not an airport/wireless
card.
we're looking into this heavily.
this is a great step forward!
!!NON-WORKING!!
**************NOTICE**************
RESTART.
card.
