What is WMA
Windows Media Audio (WMA) is an audio data compression technology developed by Microsoft. The name can be used to refer to its audio file format or its audio codecs. It is a proprietary technology that forms part of the Windows Media framework. WMA consists of four distinct codecs. The original WMA codec, known simply as WMA, was conceived as a competitor to the popular MP3 and RealAudio codecs. WMA Pro, a newer and more advanced codec, supports multichannel and high resolution audio. A lossless codec, WMA Lossless, compresses audio data without loss of audio fidelity. And WMA Voice, targeted at voice content, applies compression using a range of low bit rates.
How to play WMA files on Mac OS X for free
WMA is a Windows audio format, Apple Mac cannot recognize it, but there are some free plugins, such as flip4mac andfluke. With these utilities, WMA files can be played by QuickTime or iTunes.
How to extract WMA from DVD for Mac OS X
If you want to extract audio from a excellent DVD movie as WMA file on Mac, just convert the DVD to WMA,Wondershare DVD to WMA Ripper for Mac could help you convert DVD to WAV, AAC, OGG, MP3 and other audio formtas. Moreover, this DVD to WMA Extractor could also rip DVD to WMV, MOV, MKV, MP4 and other popular videos on Apple.
After installing, import DVD, select WMA as your output formats, and click "Start", you will get WMA files from your DVD.
How to convert WMV, MOV, FLV, AVI, MKV to WMA on Mac OS X
If you need to convert video files like WMV, MOV, FLV, AVI, MTS to WMA, just try WMA Converter for Mac, which can easily extract WMA from popular video files.
How to switch WMA to WAV, MP3, MKA, OGG, M4A, FLAC, etc.
Wondershare WMA Converter for Mac will also switch WMA to other popular audio files like AIFF, W4A, AAC, AC3, OGG, AU, APE, MKA, MP3, etc.
With only three steps, you could finish the work:
import files -> choose output file format -> start conversion.
And there are other interesting editing functions, merging several video or audio clips into one to make a creative movie, and trimming audio length, or cropping video edges. How to edit with WMA Converter for Mac.
