Moyea SWF to Apple TV Converter-Great solutions for Apple TV users
  • Moyea SWF to Apple TV Converter-Great solutions for Apple TV users
    What is SWF?
    The SWF file format (pronounced "swiff") delivers vector graphics, text, video, and sound over the Internet to AdobeFlashPlayer software. The SWF file format is designed to be an efficient delivery format, not a format for exchanging graphics between graphics editors. It is designed to meet the goals of On-screen display, Extensibility, Network delivery, Simplicity, Scriptability, Speed, Scalability.
    Which video files can be played on Apple TV?
    A lot of friends are asking me how to convert SWF to Apple TV movie. I have told those one by one. And now, I would like to share my knowledge of this respect with more people who have the need to play Flash on Apple TV. These video and audio formats, MP4, MP3, AAC, M4A, WAV, files, which can be played on Apple TV.
    This guide is written for Apple TV users to explain how to play back your favorite SWF Flash files on the Apple TV at home. The guide is easy to follow and doesn't require technical knowledge of multimedia.
    What is Apple TV?
    Apple TV is a digital media receiver designed, marketed and sold by Apple. It is a network device designed to play digital content originating from any Mac...
    Requirement: To finish this guide, it is recommended to install Moyea SWF to Video Converter Pro, Moyea SWF to Video Converter Standard or Moyea SWF to Apple TV Converter on your computer.
    For Apple TV users, you can either buy movies and songs from iTunes store and transfer them to Apple TV, or find the proper video program to convert your favorite video files to Apple TV movie.
    Moyea SWF to Apple TV is a handy utility that can perfectly convert Macromedia SWF files and Flash projectors to Apple TV video and iPod mp4 video for playback on Apple TV. It can, too, rip SWF to MP3, AAC, M4A, WAV audio files and support batch mode conversion. And its manual mode allows capturing interactive Flash for conversion.
    1: Launch program and import SWF file to program
    Click "Browse" to input your flash files on your computer, and click "V" immediately behind to choose from "From Folder", "From IE Cache", and "Flash Projector", and there will be a dialog box pop up accompanying with each preference. In it, click the file name, and it will play automatically, then click "OK". On the right of the playing pane are the properties of the flash file. Click "Export" for the export settings.
    Tips: Click the "Original" in the box to set the background color. You can set the basic color or DIY a color as the background color.
    2. Export Settings
    ① Click the box under "Format", and a drop list will cascade, choose your output file format from it.
    ②Click the "folder" in the "Export to" box to set the output destination, and click "Locate", the destination folder will pop up immediately.
    ③Select the check box before the "Rip Audio", and the audio will be extracted and generated as a single file. Click the folder on the right to browse for the audio destination folder, and click "Locate", the destination folder will pop up itself.
    ④Click "Converter" tab in the menu to convert.
    3. Audio & Video Settings
    On choosing each item in the box under the "Format", the values in the window after clicking "Settings" pop-up on the right will change in accordance. Change the video and audio parameters by clicking each item and selecting the value. Click "Save As" immediately after the box to save the profile you set as a new one. Click "V", you can save, rename, or delete the newly set.
    4. Convert
    If you have chosen "Always forward" conversion, then the process is the same with "Batch Mode". If you have chosen the "Manual Mode" conversion, the following window will pop up; you can do according to the instruction on the top. Then the program will play the file for you to set start and end points of the capture.
    Then the encoding process begins, and now the conversion completes. The rest is to enjoy your fancy on your TV.
    SWF converterflash converterconvert swfSWF to MPEG;flash to mpegSWF to FLV converter;convert SWF to FLV; Flash to MPEG;SWF to video;SWF to video converter;SWF to 3GP;flash to AVI ;SWF to iPhone;SWF to iPhone converter;Flash to iPod converter;flash to psp;SWF to psp;flash to zune;swf to zune;moyea swf to zune;flash to apple tv
