คือว่า เพิ่งโหลดเกมส์มาจากเว็บบิต
แต่พอลงแล้ว ตอนเล่นมันเป็นแบบเนี่ยอะครับ
ใครพอรู้วิธีแก้บ้างอะครับ
อันนี้ config นะครับ
WINE REGISTRY Version 2
;; All keys relative to \\Machine\\Software\\Wine\\Wine\\Config
;; MS-DOS drives configuration
;; Each section has the following format:
;; [Drive X]
;; "Path"="xxx" (Unix path for drive root)
;; "Type"="xxx" (supported types are 'floppy', 'hd', 'cdrom' and 'network')
;; "Label"="xxx" (drive label, at most 11 characters)
;; "Serial"="xxx" (serial number, 8 characters hexadecimal number)
;; "Filesystem"="xxx" (supported types are 'msdos'/'dos'/'fat', 'win95'/'vfat', 'unix')
;; This is the FS Wine is supposed to emulate on a certain
;; directory structure.
;; Recommended:
;; - "win95" for ext2fs, VFAT and FAT32
;; - "msdos" for FAT16 (ugly, upgrading to VFAT driver strongly recommended)
;; DON'T use "unix" unless you intend to port programs using Winelib !
;; "Device"="/dev/xx" (only if you want to allow raw device access)
[Drive C]
"Path" = "@BUNDLEPATHRESOURCE@/transgaming/c_drive"
"Type" = "hd"
"Label" = "Dos Drive"
"Filesystem" = "win95"
[Drive D]
"Path" = "${HOME}"
"Type" = "hd"
"Label" = "My Home"
[Drive E]
"Path" = "/tmp"
"Type" = "hd"
"Label" = "tmp"
[Drive G]
"Path" = "/"
"Type" = "hd"
"Label" = "root"
[Drive P]
"Path" = "@USERPREFS@/p_drive"
"Type" = "hd"
"Label" = "Dos Drive 2"
[wine]
"Windows" = "c:\\windows"
"System" = "c:\\windows\\system32\\"
"Temp" = "e:\\"
"Path" = "c:\\windows\\;c:\\windows\\system32\\"
"GraphicsDriver" = "sdldrv"
; Wine doesn't pass directory symlinks to Windows programs by default.
; Enabling this may crash some programs that do recursive lookups of a whole
; subdir tree in case of a symlink pointing back to itself.
; Note: The WINESHELLLINK Environment variable will override this setting.
; (which is set in the winex startup script)
;"ShowDirSymlinks" = "1"
"ShellLinker" = "/usr/lib/transgaming_stilton_4.2test_25/winex/bin/wineshelllink"
; Browser to be used by winebrowserlink.
; Note: The WINEBROWSER Environment variable will override this setting.
;"Browser" = "/usr/bin/konqueror"
; Use the mozilla control as the IE control where available
;"MozillaControl" = "Y"
# <wineconf>
[DllDefaults]
"DefaultLoadOrder" = "native, builtin, so"
[DllOverrides]
"commdlg" = "builtin, native"
"comdlg32" = "builtin, native"
"oleaut32" = "builtin, native"
"ver" = "builtin, native"
"version" = "builtin, native"
"shell" = "builtin, native"
"shell32" = "builtin, native"
"shfolder" = "builtin, native"
"shlwapi" = "builtin, native"
"lzexpand" = "builtin, native"
"lz32" = "builtin, native"
"comctl32" = "builtin, native"
"commctrl" = "builtin, native"
"advapi32" = "builtin, native"
"crtdll" = "builtin, native"
"mpr" = "builtin, native"
"winspool.drv" = "builtin, native"
"d3d8" = "builtin, native"
"d3d9" = "builtin, native"
"d3drm" = "builtin, native"
"ddraw" = "builtin, native"
"dinput" = "builtin, native"
"dinput8" = "builtin, native"
"dmusic" = "builtin, native"
"dsound" = "builtin, native"
"opengl32" = "builtin, native"
"msvcrt" = "native, builtin"
"rpcrt4" = "native, builtin"
"msvideo" = "builtin, native"
"msvfw32" = "builtin, native"
"mcicda.drv" = "builtin, native"
"mciseq.drv" = "builtin, native"
"mciwave.drv" = "builtin, native"
"mciavi.drv" = "native, builtin"
"mcianim.drv" = "native, builtin"
"msacm.drv" = "builtin, native"
"msacm" = "builtin, native"
"msacm32" = "builtin, native"
"midimap.drv" = "builtin, native"
"psapi" = "builtin, native"
"wininet" = "builtin, native"
"dbghelp" = "native, builtin"
[Version]
; Windows version to imitate. Valid versions are: 'win20', 'win30', 'win31', 'win95', 'win98', 'winme', 'nt351', 'nt40', 'win2000', 'winxp'
"Windows" = "winxp"
; DOS version to imitate
;"DOS" = "6.22"
[sdldrv]
"DefaultScreenWidth" = "1024"
"DefaultScreenHeight" = "768"
"ScreenDepth" = "32"
"Enable3D" = "1"
"FullScreen" = "0"
"ShowFPS" = "0"
"DisplaySettingsDialog" = "0"
[x11drv]
; Number of colors to allocate from the system palette
"AllocSystemColors" = "100"
; Number of colors to copy from the default palette
"CopyDefaultColors" = "0"
; Use a private color map
"PrivateColorMap" = "N"
; Favor correctness over speed in some graphics operations
"PerfectGraphics" = "N"
; Color depth to use on multi-depth screens
;;"ScreenDepth" = "16"
; Name of X11 display to use
;;"Display" = ":0.0"
; Allow the window manager to manage created windows
"Managed" = "Y"
; Use a desktop window of the given size
"Desktop" = "1024x768"
; Use XFree86 DGA extension if present
; (make sure /dev/mem is accessible by you !)
"UseDGA" = "N"
; Use XShm extension if present
"UseXShm" = "Y"
; Enable DirectX mouse grab
"DXGrab" = "N"
; Use XVidMode extension if present
"UseXVidMode" = "Y"
; Use XRandR extension if present
"UseXRandR" = "N"
; Create the desktop window with a double-buffered visual
; (useful to play OpenGL games)
"DesktopDoubleBuffered" = "Y"
; Code page used for captions in managed mode
; 0 means default ANSI code page (CP_ACP == 0)
"TextCP" = "0"
; Use this if you have more than one port for video on your setup
; (Wine uses for now the first 'input image' it finds).
;; "XVideoPort" = "43"
; Use this to make your X server execute all commands
; sequentially rather than buffering commands. Will make
; everything really SLOW but can be nice for debugging.
;; "Synchronous" = "Y"
; Enable the FPS count on the TransGaming HUD (also activates the HUD)
"ShowFPS" = "N"
; Enable memory statistics on the TransGaming HUD (must have ShowFPS activated)
"ShowMem" = "N"
; How much Video RAM does your card have?
"VideoRam" = "64"
; How much AGP memory should be used for vertex data (about 1/2 your AGP aperature size)
"AGPVertexRam" = "64"
; Use NV_VAR (enabled by default)
"NV_VAR" = "N"
; Use ARB_VBO (enabled by default, NV_VAR takes precendence)
"ARB_VBO" = "Y"
[d3dgl]
"AnisotropicTextureFiltering" = "Y"
"VertexShaders" = "Y"
; type of vertex shaders to use (Hardware/Software/Auto)
; hardware will use whatever the opengl drivers make available
; software will use winex software emulation (will be slow!)
; (has not been implemented yet!)
"VertexShaderMode" = "A"
"PixelShaders" = "Y"
; Which version of pixel shaders to attempt to use, if available
"PixelShadersLevel" = "2.0"
"VertexShadersLevel" = "2.0"
; enable software vertex blend weight support (Yes/No/Auto)
; provide software blending fallback if hardware support not available
;; "SoftwareVertexBlending" = "Auto"
; (dev-only) Maximum number of texture stages that WineX should attempt to use (1-8)
;; "MaxTextureStages" = "8"
; (dev-only) Identify polygons under the mouse cursor
;; "InterceptMode" = "N"
; (dev-only) apply fragment translation in vertex program (No/Tex/Auto/Pos)
;;"FragmentOffset" = "Auto"
; use the fixed function over vertex shader pipeline (Yes/No/Auto)
"FixedProgram" = "Y"
"GLSL" = "N"
; (dev-only) Provide non power of two texture support using rectangle textures (Yes/No/Auto)
;;"RectangleTextures" = "Auto"
"FBO" = "Y"
"FBOCache" = "Y"
"FBOBackbuffer" = "Y"
"DynamicVBO" = "Y"
"IndexVBO" = "N"
[opengl]
; Report a truncated list of OpenGL extensions to the application
;;"FixedGLExtensionBuffer" = "N"
; list of additions (+) or deletions (-) to the list of extensions
; reported when FixedGLExtensionBuffer is enabled. Note that extensions
; cannot be enabled if they are not supported by your video card/drivers
;;"GLExtensionBuffer" = "+GL_ARB_imaging,-GL_ARB_depth_texture"
[dinput]
; dead zone for joystick input from 0 to 10000. 1000 is 10% of range.
"DefaultDeadZone" = "1000"
"AbsoluteMouseSensitivity" = "100"
[joystick]
;; Configuration of the function of joystick axes
;; The joystick name and axis functions can be determined with jstest.
;; The available axis types are:
;; "none", "X", "Y", "Z", "RX", "RY", "RZ",
;; "slider", "hat", "POV", and "ball"
;; "hat" and "POV" are synonymous. Hats use two axes.
"Logitech Inc. WingMan RumblePad" = "X,Y,slider,Z,RZ,hat,none"
[fonts]
;Read documentation/fonts before adding aliases
"Resolution" = "96"
"Default" = "-adobe-times-"
; Use new improved fonts (uses FreeType and XRender libraries) at user request.
; Defaults to "Y".
"FreeType" = "Y"
[FontPatterns]
"Pattern0" = "-adobe-times*"
"Pattern1" = "-adobe-helvetica*"
"Pattern2" = "-adobe-courier*"
"Pattern3" = "-misc-fixed*"
[FontDirs]
;"0"="/path/to/extra/fonts"
[FontAlias]
;; Add font aliases here. On the left put the name of the windows font family
;; that you want to fake, on the right put the a similar font family that you
;; have installed. These will override the fontconfig and the WineX builtin fallbacks,
;; but may look better (if you choose them correctly).
;; Alias' may refer to other alias' that have been defined above them.
;; These alias' are the first that WineX loads.
;; Serif Fonts
;"Times New Roman"="Times"
"MS Serif"="Times New Roman"
;; Sans Serif Fonts
;"Arial"="Helvetica"
"Helv"="Arial"
"MS Sans Serif"="Arial"
"System"="Arial"
"Tahoma"="Arial"
;; Mono Space Fonts
;"Courier New"="Courier"
;"FixedSys"="Courier"
[memory]
;; Attempt to make memory allocation more windows like.
;; Not for use with all applications. Best used in app default section.
; "MemoryLayoutOverride" = "0x10000000"
[serialports]
"Com1" = "/dev/ttyS0"
"Com2" = "/dev/ttyS1"
"Com3" = "/dev/ttyS2"
"Com4" = "/dev/modem"
[parallelports]
"Lpt1" = "/dev/lp0"
[spooler]
"LPT1:" = "|lpr"
"LPT2:" = "|gs -sDEVICE=bj200 -sOutputFile=/tmp/fred -q -"
"LPT3:" = "/dev/lp3"
[ports]
;"read" = "0x779,0x379,0x280-0x2a0"
; "write" = "0x779,0x379,0x280-0x2a0"
[spy]
"Exclude" = "WM_SIZE;WM_TIMER;"
[registry]
;These are all booleans. Y/y/T/t/1 are true, N/n/F/f/0 are false.
;Defaults are read all, write to Home
; Global registries (stored in /etc)
"LoadGlobalRegistryFiles" = "n"
; Home registries (stored in ~user/.wine/)
"LoadHomeRegistryFiles" = "Y"
; Load Windows registries from the Windows directory
"LoadWindowsRegistryFiles" = "n"
; TRY to write all changes to home registries
"WritetoHomeRegistryFiles" = "Y"
; Registry periodic save timeout in seconds
; "PeriodicSave" = "600"
; Save only modified keys
"SaveOnlyUpdatedKeys" = "Y"
[Tweak.Layout]
;; supported styles are 'Win31'(default), 'Win95', 'Win98'
"WineLook" = "Win98"
[Console]
"Drivers" = "xterm"
;"Drivers" = "tty"
"XtermProg" = "konsole"
;"InitialRows" = "25"
;"InitialColumns" = "80"
;"TerminalType" = "nxterm"
[Clipboard]
"ClearAllSelections" = "0"
"PersistentSelection" = "1"
; List of all directories directly contain .AFM files
[afmdirs]
;"1" = "/usr/share/ghostscript/fonts"
;"2" = "/usr/share/a2ps/afm"
;"3" = "/usr/share/enscript"
;"4" = "/usr/X11R6/lib/X11/fonts/Type1"
[Wineserver]
"SHMWineserver" = "N"
"Scheduler" = "N"
[WinMM]
"Drivers" = "winemacca.drv"
"WaveMapper" = "msacm.drv"
"MidiMapper" = "midimap.drv"
[wineoss]
"UseMMap" = "N"
"FullDuplex" = "N"
;; Specify a mapping for what digital audio devices to use
;"dsp0" = "/dev/dsp0"
;"mixer0" = "/dev/mixer0"
[winealsa]
"UseMMap" = "Y"
;"pcm0" = "hw"
;"ctl0" = "hw"
;; [Drive X]
;; Recommended:
[Drive C]
"Type" = "hd"
[Drive D]
"Path" = "${HOME}"
"Type" = "hd"
"Label" = "My Home"
[Drive E]
"Path" = "/tmp"
"Type" = "hd"
"Label" = "tmp"
[Drive G]
"Path" = "/"
"Type" = "hd"
"Label" = "root"
[Drive P]
"Type" = "hd"
[wine]
"Temp" = "e:\\"
# <wineconf>
[DllDefaults]
[DllOverrides]
[Version]
"Windows" = "winxp"
;"DOS" = "6.22"
[sdldrv]
"Enable3D" = "1"
"FullScreen" = "0"
"ShowFPS" = "0"
[x11drv]
"Managed" = "Y"
"UseDGA" = "N"
"UseXShm" = "Y"
"DXGrab" = "N"
"UseXVidMode" = "Y"
"UseXRandR" = "N"
"TextCP" = "0"
"ShowFPS" = "N"
"ShowMem" = "N"
"VideoRam" = "64"
"NV_VAR" = "N"
"ARB_VBO" = "Y"
[d3dgl]
"GLSL" = "N"
"FBO" = "Y"
"FBOCache" = "Y"
"DynamicVBO" = "Y"
"IndexVBO" = "N"
[opengl]
[dinput]
[joystick]
[fonts]
"Resolution" = "96"
; Defaults to "Y".
"FreeType" = "Y"
[FontPatterns]
[FontDirs]
[FontAlias]
;; Serif Fonts
;; Sans Serif Fonts
"Helv"="Arial"
"System"="Arial"
"Tahoma"="Arial"
;; Mono Space Fonts
[memory]
[serialports]
[parallelports]
"Lpt1" = "/dev/lp0"
[spooler]
"LPT1:" = "|lpr"
[ports]
[spy]
[registry]
[Tweak.Layout]
[Console]
"Drivers" = "xterm"
;"Drivers" = "tty"
[Clipboard]
[afmdirs]
[Wineserver]
"Scheduler" = "N"
[WinMM]
[wineoss]
"UseMMap" = "N"
"FullDuplex" = "N"
[winealsa]
"UseMMap" = "Y"
;"pcm0" = "hw"
;"ctl0" = "hw"
