หนู @am คนเก่งจ๋า พี่ใช้ boad p5n32 จะลงไดัไหมจ๋ะ ขอให้สวยขึ้นทุกวันนะจ๋ะ thank you
มีภาพประกอบ ลง iDeneb 10.5.8 เชิญแอบดูได้จ๊ะ
Intro:
This new version of iDeneb, improves the possibility to excute upgrade after post install.
If you been for do an Upgrade system and you have an error ( when the installation ends ) : "Impossible to use the partition as parition of boot" , ignored the messeage and restart, because all the package are installed correctly;
Warnings!
If you have a restart when you try to boot the dvd, you boot with flag at the F8 boot prompt: cpus=1;
Do Not Install the iDeneb Base System over an existing Base System! This could cause the failure of the installation! To always execute a fresh install;
If you been for do an upgrade system, deselect of principal system;
You can boot the dvd also with the kernel, Qoopz 9.7.0 with flag 970, Kernel AnV 9.6.0 with the flag anv and Kernel ToH 9.2.0 with the flag mach_toh;
Do Not Select more than one a drivers of the same type! For example, Do not select 2 Audio Drivers or 2 SMBIOS, this will in many cases cause the install to fail;
Vanilla 9.7.0 is default kernel;
Bootloader of default is Chameleon v2;
If you have based on AMD and/or SSE2 you must select an alternative kernel, advised kernel Qoopz 9.7.0;
If you use kernel Qoopz, AnV, Voodoo you don't select the AMD Patch ;
If you use Voodoo Kernel you must select "Seatbelt Fix" under fix for resolve the problem of mount of an .dmg,.iso or .cdr;
If your system's sound does not work even after installing the proper sound drivers there may be an issue with the System Preferences. Go to System Preferences Sound > Output > and make sure that "Internal Speakers" is chosen and not Headphones or something else;
If you have a NVidia Video Card you don't select more than a injector. You can choice or NVinject, or NVKush, or NVdarwin;
If you have a problem with ACPI_SMC_PlatformPlugin.kext you can select ACPI_SMC_Fix under Fix Menu;
If you have a incompatible system with latest ACPI kext or you have a computer SSE2, you can select package ACPI/SSE2 Fix under Fix Menu;
If you have kernel panic and you don't know what caused it, boot in verbose mode ( -v boot flag at the F8 boot prompt ) for visualize the error;
If you don't know like resolve the error you can try install only based system with essential drivers ( Ex. Chipset Drivers ) without the "extra" drivers;
In some situations for the first boot it could be necessary to start with the flag - f for load the kext correctly;
If you haven't select Video Drivers it could be necessary to start with flag -x;
If you are installing iDeneb on one of the Netbook in list, not to select no other drivers or patch;
Netbook Section is in update, for problem o for add others netbook to write on the official forum in section Netbook;
Bootloader & DSDT
Chameleon v2
Chameleon v1.0.12
DSDT Patcher
LeopardAMD
Fix
ACPI/SSE2 Fix
IOPCMCIAFamily
SD_SDHC
IOUSBFamilyFix
Mouse Lag Fix
BatteryManager ( VoodooBattery )
VoodooPower
VoodooPower ( Kext )
GenericCPUPMControl ( App )
VoodooUSBEHCI
Kernel
9.7.0 Vanilla ( Intel/SSE3 )
9.7.0 Qoopz ( Intel/AMD SSE2/SSE3 )
9.6.0 AnV ( Intel/AMD SSE2/SSE3 )
Drivers
Audio
Analog Devices
AD1988 P5K
AD2000B
ALC Audio
ALC262
ALC268
ALC268 AA1
AL272
ALC880
ALC889A
ALC1200
AC97AC97 ALi Uli M5455
AC97 SiS 7012
SigmaTel STAC
STAC9200
STAC9205
STAC9223
STAC9227
VoodooHDA
Chipset:
ATIATA ( 64 Bit Support )
AppleNForceATA ( 64 Bit Support )
ICHx Fixed ( ICH10 Support )
JMicronATA ( 64 Bit Version )
VIA/SiS/Marvell/Uli ( 64 Bit Support )
Network:
Ethernet
AppleYukon2
RTL8169/RT8111
RTL8139
Tulip
USBAx8817x
USBPegasusEthernet
Wireless
Atheros AR5005
Netgear wg111 v3
Ralink
RT256x/RT266x
RT257x/RT2671
RT2860/2790
RT2870/RT2779/RT307x
Video
ATI
X Series
X1400
HD Series
HD2xxx Series
HD2400XT ( EFI String )
HD3xxx Series
HD3870x2
HD4xxx Series
HD4830
HD4850
HD4870
HD4870x2
FIXResolution
Intel
Intel GMA915
Intel GMAX3500
Netbook
Asus EEEPC
HP Mini 1000
ATI Mobility Redeon HD 4330 ลงตัวนี้ได้มั้ยคับ ใครรู้ช่วยบอกหน่อยLast edited by sangjan001; 24 Nov 2009, 10:48:48.
