Singer Quantum Stylist 9960 Computerized Portable Sewing Machine Review
While working on some proper project if you don’t have the best basic sewing machine for beginners
which should be easy to handle with lots of features, then a simple task can take your half of the day. If you are tired of maintaining your old sewing machine again and again then this is the time to go for Singer 9960 Quantum Stylist sewing machine.
Built-in Buttonholes:
Now even if you are a beginner, you don’t have to struggle to make a buttonhole from the sewing machine. This sewing machine has come up with the one-step buttonhole feature that can save your time and energy. Singer 9960 Quantum stylist sewing machine can work in 13 different styles. You can choose any of the buttonhole designs and the rest leave it to the machine.
Top Loading Bobbin:
Another thing you are going to get rid of is manually setting the bobbin. In this sewing machine, top loading bobbin is located at the top which makes it easy for the user to change stitching settings. There will be no more problems with bobbin setting and it can simply be adjusted. This feature is the most demanding and customers love it.
LCD:
This sewing machine has come up with 600 built-in stitches with width and line lengths. To adjust the stitch settings, there is an LCD attached to the sewing machine. This LCD can also help you in adjusting the needle and bobbin according to the nature of your project. With the help of an LCD, you can set the sewing machine as you want without creating handling complications.
Speed Control:
People who don’t have a good sewing machine but want to pursue a career in sewing should read this article
Best Sewing Machine For Beginners, and the answer is Singer 9960 Quantum Stylist.
Singer 9960 comes with an easy control panel
This sewing machine allows a beginner to take control over speed and is affordable in price. With new and advanced features, this sewing machine is an ideal choice.
Accessories:
Once you have decided to invest in a new beginner sewing machine that can fulfill your working requirements then it’s important to get all the necessary accessories with it. This sewing machine has just not come up with the accessories but also with three different kinds of warranties. The first warranty is 25 years for the head, the second one is for five years valid on the motor, electronic components, speed control wiring, and others.
The third warranty is for one year which includes a ring, bulbs, belts, and other adjustments. The sewing has also come up with the user manual in case you have to use some new feature, then you can read the manual and simply use it.
Should you buy the Singer 9960 Quantum Stylist?
If you were wondering What is The Best Sewing Machine For Beginners
then Singer 9960 Quantum Stylist is the right match for you. You can use the advanced and new features all in one sewing machine and no matter what customization you are required to do in the project, it can help you in doing anything.
Top Loading Bobbin:
LCD:
Speed Control:
Accessories:
