Want to copy a DVD movie to a blank DVD disc on your Mac machine? Wondershare DVD Copy for Mac can help you soon, it is a professional DVD copy program designed for Mac OS users to copy D9 and D5 DVD movies ( D9 to D9 and D5 to D5), and even able to remove DVD protections. You can click here to learn more about Wondershare DVD Copy for Mac .
Wondershare DVD Copy for Mac is quite easy to use and it takes only a few steps to copy the entire DVD:
Step 1: Select DVD Source
You can not only select a DVD rom, but also a DVD folder which appears like "Video_ts". Wondershare DVD Copy for Mac is also a DVD burning software to some extent.
Step 2: Select DVD Copy Method
In the "Select DVD Copy Method" field to select a method to output the selected DVD movie:
If you want to output your DVD movie to a folder on your hard disc, you can select the "Output DVD Folder" option, and specify a directory to save the copied DVD movie.
If you want to directly burn your DVD movie to a new DVD disc, you can just select the DVD ROM where you have inserted a blank DVD disc.
Step 3: Program Settings (Optional)
Set Buffer Directory: Select a folder on a hard disc that has relatively big free space to store the temporary files.
Select Language: Select an interface language for the program.
Step 4: Start Copying DVD
Click the Start button to start copying your DVD movie and/or burning it to a new DVD disc.
If you are copying a DVD disc from your DVD ROM to a new DVD disc, you will be asked to insert a blank DVD disc. If so, you can just take the original DVD disc out and insert a blank DVD disc.
Then, you can make a perfect DVD copy with quality 100% preserved.
If you just copy your DVD on Macintosh, MacTheRipper would be your best choice;
If you wanna convert DVD files to regular video(MOV/MP4/FLV/MPEG/AVI/WMV), you can turn to this mac DVD ripper tool.
