aorus x470 ultra gaming ดี-ไหมคับพอดีจะเปลี่ยนบอร์ด 5650.-
ROZ - Republic Of Zen : Society for AMD Citizens
เทสต์ ทรมาน B450 tomahawak ด้วยการ โอซี ด้วย R7 2700X
https://www.guru3d.com/articles_page..._review,1.html
ปล. TEST 2700X ลากไป 4.3 ghz นั่นขนาด วีอาร์เอ้มกากนะนั่น 55
Final Words
We're going to see B450 based motherboards in many versions from really affordable to nearly high-end looking. The B450 Tomahawk sits in between the middle. A board that will offer most, if not all you need for a very decent Ryzen enabled PC. We had no problems with an 8-core 2700X, it ran great on defaults, and allowed for a good overclock as well. You can argue the phase design, but when overclocked it did not overheat. So nothing there is worrying to me. This B450 Tomahawk is a bit more cut down, just one M2 slot, no thermal heatsink for that M2 and sure, you just get to fool around with one full x16 slot PCIe Gen3. Realistically though, how many people actually run multiple graphics cards or multiple M2 SSD cards? As next to that one M2 slot (fully enabled x4 PCIe Gen3 btw), you still have up-to six SATA3 ports. Memory also is a no-brainer these days, we tested a 3200 CL14 kit, all works fine. Tweaking wise, the motherboard will not be a serious limitation, not all Zen+ processors will reach that 4.2~4.3 Ghz domain, but I do not see this motherboard to become the actual bottleneck. Our all-core 4200 MHz tweak was done by merely enabling a 42 multiplier, we left the rest at auto settings and sure, we had the XMP profile active. Do get some proper cooling though. Btw one remark here, I find the default FAN RPM settings to be rather extreme and thus loud for most coolers. That, however, is quite easily tweaked in the BIOS, of course.Last edited by micronzr; 3 Dec 2018, 11:53:07.
Originally posted by finaleak View Postผมใช้ Ryzen3 2200G กะ 1060 หรือ RX580 จะบอกว่า ยังเอาอยู่(เกือบทุกเกมส์) ยกเว้น Assassin's Origin ฮ่าๆ ยังไงก็เอาไม่อยู่ครับ 4 Core ไม่ไหว CPU 100% ทั้งเกมส์ ปรับแค่ High ได้แค่ 30-40 เฟรมเท่านั้น
ไม่งั้น เล่นพวก 6 คอร์ ขึ้นไปรองรับปัจจุบันอนาคตดีที่สุด
ผลเทสต์ oc. 2700X ที่ 4.3 พึ่งทยอยออกกันมา
4c4T นี่เกมสืกิน 6 เทรดนี่มี่อ้วกจริงๆ ถ้าอินเทล นี่ มันลาก 4.5 ghz ได้ยาวไปสบาย
-----------------------------------------------------------------------Last edited by micronzr; 3 Dec 2018, 17:14:08.
ดูเป็นแนวทาง Ryzen 3000
ดูเหมือน true/fake 30-70
https://www.ptt.cc/bbs/PC_Shopping/M...668.A.EE4.htmlLast edited by aotshooter; 3 Dec 2018, 15:11:52.
