ROZ - Republic Of Zen : Society for AMD Citizens
  • เอามาลงยังหว่า
    Sent from my ASUS_Z01BDB using Tapatalk
    • ดีไซน์ โหดมาก
      • Originally posted by MooNoiOCZ View Post
        คาดว่าล็อตใหม่ตัดSSD และM2 ออกไป เพราะพ่วงมาขายไม่ออก
        ป.ล. ถ้าราคานี้มีแถมSSD และM.2 นี่หละคือแถมของจริง จะสอยGT7 มาลองเลย
        ไม่น่ะท่านหมู ที่ advice ราคาเดิม แล้วไม่ระบุว่ามี free ssd ด้วย
        • แพ้ตะกูล 6xxx ด้วย T^T
          ทำไม Skylake-X ทำให้หน้าผิดหวัง? ลองอ่าน
          Skylake-X also features support for AVX-512. AVX-512 is a set of new instructions that can accelerate performance for workloads like scientific simulations, financial analytics, artificial intelligence (AI)/deep learning, 3D modeling and analysis, image and audio/video processing, cryptography and data compression. AVX-512 code can feature eight double precision (DP) and sixteen single precision (SP) floating point numbers within the 512-bit vectors, as well as eight 64-bit and sixteen 32-bit integers. This enables the workload to achieve more work per CPU cycle (with double the width of data registers) and helps to minimize latency and overhead (with double the number of registers), compared to AVX2. Applications must be coded to support AVX-512, however.
          image: https://hothardware.com/ContentImage...peed-shift.jpg
          Versus previous-gen processors, Skylake-X also features improvements to Intel?s SpeedShift Technology. SpeedShift allows Skylake to switch P states (power states) much faster than previous-gen products. Skylake can control P states fully in hardware, whereas older processors required OS control, which can to switch P states in as fast as 1ms. It takes roughly 30ms with older processors. Though it doesn?t affect peak performance of the processor, SpeedShift can enhance responsiveness and efficiency, because the processor is able to ramp up and down more quickly.
          Linking all of the cores, cache, and I/O in Skylake-X is the new mesh architecture we told you about here. In previous-generation, many-core Xeon processors, Intel has used a ring interconnect architecture to link the CPU cores, cache, memory, and various I/O controllers on the chips. As the number of cores in the processors, and memory and I/O bandwidth has increased, however, it has become increasingly more difficult to achieve peak efficiency with a ring interconnect, because a ring architecture could require data to be sent across long stretches (relatively speaking) of the ring to reach its intended destination. The new mesh architecture addresses this limitation by interconnecting on-chip elements in a more pervasive way, to ultimately increase the number of pathways and improve the efficiency.
          image: https://hothardware.com/ContentImage...-xeon-arch.jpg
          Read more at https://hothardware.com/reviews/inte...DIX0Yzhve6J.99
          ในข่าวเค้าบอก ระบบ Mesh มันน่าจะดี แต่ก็ไม่ดี (ระบบที่ Intel ใช้ เชื่อมหัว เชื่อม Cache IO Memory ไว้ด้วยกัน โดยไม่ได้ใช้กาว)
          ซึ่งมันสร้าง Latency เยอะกว่าแบบเดิม ( ring interconnect ) ทำให้ประสิทธิภาพต่อ Core ดันไปด้อยกว่า i7 7700k หรือแม้กระทั่ง i7 Core extreme Gen เก่าซะงั้น
          รอการปรับปรุงที่ดีกว่าเดิม Intel ของเค้าเยอะอยู่แล้ว
          Intel makes a mesh : NEW CORE-TO-CORE COMMUNICATION PARADIGM
          Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
          • ออกแบบมาห่วย คงต้องกลับไปแก้ใหม่ และใช้กาวเหมือนเดิม
            • มีบอร์ดไหนที่เอาขาพัดลม am3+ มาใส่ได้รึเปล่าครับ ขี้เกียจตามหาขา am4
              Sent from my E6653 using Tapatalk
              • Originally posted by truffle View Post
                ASUS X370 CROSSHAIR VI HERO ลงได้เลยทั้งAM3 และAM4 ทำไมรุ่นอื่นไม่ทำแบบนี้ด้วยก็ไม่รู้
                  ลดค่าขาพัดลมมาลงบอร์ดแทนซินะ -*-
                  • มาแล้ว สถิติโลก
                    • ดูดีๆ จะมีพลังงานบางอย่าง
                      • เชรสเขร้ เมนบอร์ด 20190 บาท
                        จัดสเปคคอม จัดจำหน่ายสินค้าไอที คอมพิวเตอร์สำหรับเล่นเกมส์-ทำงาน Hi-end Computer อุปกรณ์คอมพิวเตอร์ ซอร์ฟแวร์ จอมอนิเตอร์ และเกมมิ่งเกียร์ ผ่านตัวแทนจำหน่ายอย่างเป็นทางการ จัดสเปคคอม.
                        • สืบเนื่องจากบอร์ดเอ๋อเมื่อครั้งกระนู้น วันนี้ไปรับน้องเมียคนใหม่ซิงๆมาเเล้วคับ รอเทสว่าจะวิ่ง3200ได้ไหม ><
                          Sent from my iPhone using Tapatalk
                          • Originally posted by Regen View Post
                            รุ่นนี้ไปได้ถึง3800 เลย คนอื่นอาจจะพาไป4000+ ก็ได้ ผมลากแรมไม่เก่ง
                            ผมขาย7000 เผื่อมีคนสนใจ
                              ลุงหมู โม้ใช่มะ จะได้ขายออกง่ายๆ
                              • Last edited by CUTTER_Z; 3 Aug 2017, 22:54:43.
