หาๆๆๆๆๆๆๆๆๆ Zen Double Per-core
  • หาๆๆๆๆๆๆๆๆๆ Zen Double Per-core
    AMD Zen Features Double the Per-core Number Crunching Machinery to Predecessor
    by btarunr Monday, October 5th 2015 11:45 Discuss (29 Comments)
    AMD "Zen" CPU micro-architecture has a design focus on significantly increasing per-core performance, particularly per-core number-crunching performance, according to a 3DCenter.org report. It sees a near doubling of the number of decoder, ALU, and floating-point units per-core, compared to its predecessor. In essence, the a Zen core is AMD's idea of "what if a Steamroller module of two cores was just one big core, and supported SMT instead."
    In the micro-architectures following "Bulldozer," which debuted with the company's first FX-series socket AM3+ processors, and running up to "Excavator," which will debut with the company's "Carrizo" APUs, AMD's approach to CPU cores involved modules, which packed two physical cores, with a combination of dedicated and shared resources between them. It was intended to take Intel's Core 2 idea of combining two cores into an indivisible unit further.
    AMD's approach was less than stellar, and was hit by implementation problems, where software sequentially loaded cores in a multi-module processor, resulting in a less than optimal scenario than if they were to load one core per module first, and then load additional cores across modules. AMD's workaround tricked software (particularly OS schedulers) into thinking that a "module" was a "core" which had two "threads" (eg: an eight-core FX-8350 would be seen by software as a 4-core processor with 8 threads).
    In AMD's latest approach with "Zen," the company did away with the barriers that separated two cores within a module. It's one big monolithic core, with 4 decoders (parts which tell the core what to do), 4 ALUs ("Bulldozer" had two per core), and four 128-bit wide floating-point units, clubbed in two 256-bit FMACs. This approach nearly doubles the per-core number-crunching muscle. AMD implemented an Intel-like SMT technology, which works very similar to HyperThreading.
    จากคอร์ละครึ่ง เป็น คอร์เดียวเบิ้ล 2 เท่า อืม amd เพื่ออนาคตจริงๆ
      อยากจะภาวนาให้ผลิตออกมาได้เร็วๆ ตอนเปลี่ยนคอมอีกทีจะได้กลับไปใช้
      Sent from my GT-I9300 using OCZ
        รีบมาหน่อยก็ดีนะคับผมรออยู่
          กลัวราคาจะเบิ้ล 2 เท่าของปัจจุบันด้วยนี่ซิ
            มันคล้ายๆกับ HT หรือเปล่า
              HT มันเป็นอย่างไงหว่า มันเป็นแค่เพิ่มทางวิ่งเองไม่ใช่เหรอ
              แต่อันนี้มันเพิ่มจำนวนชุดถอดรหัสในลักษณะของ Hardware ของ CPU เข้าไปจริงๆนะ
                ใช่แวร้ว HT มันแค่เพิ่มช่องทางหลอกๆ เท่านั้นแหละ เหมือนกับถนนเส้นทางลัดแต่ว่าแคบๆ
                  เพราะฉะนั้นก็เหมือน Zen ไปกินรังนก กินแบรนด์อัพความฉลาดกับขนาดสมองเพิ่มมานะละ
                  แต่ HT เหมือนเสกแขนเพิ่มเข้ามาเฉยๆ
                    ไม่เทียบอย่างงั้นได้มะ กิน รังนก กะ กินแบรนด์ กินแล้วโง่ลงไม่ใช่รึไง(บางคนกินแล้วฉลาดขึ้น คือ กินแล้วก็รู้ทันทีว่าไม่ต้องไปกินน้ำลายนกมันอีก ไม่มีอะไรดี) ... เอาเป็นว่า กิน "ไอโอดีน" แล้ว IQ เพิ่มละกันนะ
                      กินแบรนด์ หรอ ติดแบรนด์ละมั๊ง กินเจดีกว่าน่า ดีฟ่าเห็นๆ เพิ่มอายุให้นานขึ้น มีเวลาดูเมะมากขึ้นไง
                              เหมือนกินแบรนกินรังนก = แพง แต่ไร้คุณภาพ เพี่ยง
