Radeon Rx 300: Bermuda, Fiji, Grenada, Tonga and Trinidad
  • Radeon Rx 300: Bermuda, Fiji, Grenada, Tonga and Trinidad
    Credit : http://videocardz.com/54858/amd-rade...d-380x-grenada
    AMD Radeon R9 395X2 Bermuda (Fiji x2) GCN 1.3; 8192 (?) Cores; 8192-bit 8GB HBM Q4 2015
    AMD Radeon R9 390X Fiji XT GCN 1.3; 4096 (?) Cores; 4096-bit 4GB HBM Q2 2015
    AMD Radeon R9 390 Fiji PRO GCN 1.3; 3840 (?) Cores; 4096-bit 4GB HBM Q2 2015
    AMD Radeon R9 385X Fiji CE (?) GCN 1.3; 3328 (?) Cores; 2048-bit 2GB HBM (?)
    AMD Radeon R9 380X Grenada XTX (Hawaii) GCN 1.1; 2816 Cores; 512-bit 4GB GDDR5 Q2 2015
    AMD Radeon R9 380 Grenada PRO (Hawaii) GCN 1.1; 2560 Cores; 512-bit 4GB GDDR5 Q2 2015
    AMD Radeon R9 370X Tonga XT GCN 1.2; 2048 Cores; 384-bit 3GB GDDR5 Q2 2015
    AMD Radeon R9 370 Tonga PRO GCN 1.2; 1792 Cores; 256-bit 2GB GDDR5 Q2 2015
    AMD Radeon R9 360X Trinidad GCN 1.3; (?) Cores; 256-bit 2GB GDDR5 Q1 2015
    AMD Radeon R9 360 Trinidad GCN 1.3; (?) Cores; 256-bit 2GB GDDR5 Q1 2015
    Radeon R9 395X2 ?Bermuda?
    Starting with Bermuda. You probably heard this name before, but no one was certain if Bermuda is the actual flagship GPU or something else. Well as a matter of fact Bermuda could actually be the Vesuvius successor (R9 295X2). Radeon R9 395X2 would be a direct competitor to rumored GTX 990 (likely dual-GM204).
    Radeon R9 390(X) ?Fiji?
    According to 3DCenter, Fiji is ?confirmed? as next flagship GPU. The R9 390X will likely be powered by Fiji XT, whereas R9 390 with Fiji PRO. Fiji-powered graphics cards are said to be the first with High-Bandwidth-Memory on board. NVIDIA will possibly adopt HBM with Pascal, so we are looking at months, or maybe even years, of AMD leadership in this technology.
    Radeon R9 380(X) ?Grenada?
    I think it was quite obvious Hawaii, which was released in late 2013, would not be forgotten in upcoming 300 series. The rumor has it that Hawaii will be renamed to Grenada. Does it mean architectural changes? Likely not, but we expect Grenada to be more power efficient, and configured with higher clock speeds.
    Radeon R9 370(X) ?Tonga?
    Tonga was first released with Radeon R9 285. AMD had plans to release R9 285X (this is not a rumor), however due to GTX 970 announcement, those plans had to be changed. The full Tonga is actually equipped with 384-bit interface, so R9 370X should launch with 3GB on board. We are looking at potential GM206 competitor here.
    Radeon R7 360(X) ?Trinidad?
    Trinidad is Curacao (Pitcairn) replacement expected to launch with Radeon R7 360 series. The only information we have is limited to memory configuration of 256-bit and 2GB frame buffer. Additionally, Trinidad may be the first card of Radeon 300 series, as it?s currently planned for March (according to VR-Zone).
    AMD Radeon Rx 400 series are codenamed Arctic Islands
    380X = 290X, 380 = 290, 370 = 285, แต่ใช่ว่า 370X จะใหม่เสียทีเดียว มันคือตัว SM ครบชุดซึ่งมาแทน 280X(7970)
    ใหม่จริงๆจึงมีแค่ 390X, 390, 385X, 360X, 360 หรือว่าง่ายๆดูที่เลข GCN 1.3 เข้าใจง่ายสุด
      สเป็คตัวใหม่จริงๆ นี่แรงน่าดู
      ปล. Asus 7970 TOP ของผม จะเทียบเท่า 370 หรือ 370X หว่า
          ไม่ต้องรีบซื้อ ราคาไทยแพง ปล่อยให้เน่าคาร้านไป
          รอสิ้นปี GCN 2.0 แจ่มกว่า
            เครดิตควรไปที่ต้นฉบับ: 3DCenter.org
            คำทักทายจากประเทศไทย
              อีก 11 เดือน รอยาวเลยนะเนี่ย
                Q2 2015 นี่คือช่วงจำหน่าย ?
                  Hi..... google translated ?
                    สนใจ R7 360 เพราะเป็นการ์ดรุ่นเล็กที่เป็น GCN 1.3
                      370x คือ 7970 หรอฮับ ถ้าเป็นแบบนั้นจริง ขอราคาเท่า 260x จะแหล่มมาก มโนแพ๊บ
                        ไม่ใช่นะมันคือตัว 285 ที่ SM เต็มๆไม่โดนปิด รหัสที่ควรใช้จริงๆถ้าออกตัวนี้มาเมื่อปีที่แล้วน่าจะใช้ชื่อ 285X
                        ว่าง่ายๆเอามาแทน 280X นั่นแหละ แต่ออกช้าเลยเหมือนย้อมไปเป็น 370X แทนซะละ
                          เกือบปล่อยไก่ยกเล้า นั่งรอ Arctic Islands แจ้ คือตอนนั้น 7770 มือสองที่สอยมาประกันหมดพอดี
                          แอบเสียใจที่ Hawaii แค่เปลี่ยนชื่อเรอะ น่าจะเพิ่มให้เป็น GCN 1.2 เสมอหน้าเสมอตากันนิดนึง
                          เดี๋ยวเจอมุขซ้ำรอย 270 / 280 ปีนี้อีก ปล่อยไดร์เวอร์โอเมก้ามาอย่างเทพ แต่ลูกเล่นหลักๆ ล็อคเอาไว้ให้ GCN 1.1 ขึ้นไป
                          ฝากความหวังของหมู่บ้าน AMD เอาไว้กับ Trinidad ในการกอบกู้ตลาด ~4000-5000 เพราะโดน GTX750 สอยเสียหลักไปนาน
