เบื่อฟ้าอยากลองแดงครับ
  • #46
    ประมาณนั้นฮะ
    • #47
      ครั้งแรกที่อ่านหัวข้อ "....อยากลงแดง"// กำ
      ถ้าเบื่อก็เปลี่ยนได้ครับตามที่คห.แรกๆบอก ใช้แล้วหน้าตาดีทำให้สดชื่นก็ได้มั้งกับการจมปลักกับของเดิมๆ เวลามีกระทู้ดราม่าจะได้มี exp ด้านซีพียูทั้งสองฝั่งไว้พิจารณา
      • #48
        • #49
          แม่เจ้า Pentium G3258 @ 4800MHz ผลทดสอบแรงเทียบเท่า Phenom ll x4 จาก Guru3D ^^
          Performance Processor: MediaShow Espresso
          MediaShow Espresso, the cool thing about this video transcoder is that it can utilize the GPU to assist it with the transcoding process. However, you can also solely use the CPU, making this a very interesting benchmark as you can check out behavior of CPU transcoding AND GPU transcoding all in one test. Mind you that hardware accelerating like AVX and GPU, OpenCL have been disabled for this test. This is pure unadulterated CPU performance.
          Video Transcoding: H.264 (DTS5.1) to x.264 AC3 5.1
          Performance Processor: 3DMark 06 CPU Test
          Performance Processor: 3DMark Vantage CPU Test
          3DMark Vantage focuses on the two areas most critical to gaming performance: the CPU and the GPU. With the emergence of multi-package and multi-core configurations on both the CPU and GPU side, the performance scale of these areas has widened, and the visual and game-play effects made possible by these configurations are accordingly wide-ranging. This makes covering the entire spectrum of 3D gaming a difficult task. 3DMark Vantage solves this problem in three ways:
          1. Isolate GPU and CPU performance benchmarking into separate tests,
          2. Cover several visual and game-play effects and techniques in four different tests, and
          3. Introduce visual quality presets to scale the graphics test load up through the highest-end hardware.
          To this end, 3DMark Vantage has two GPU tests, each with a different emphasis on various visual techniques, and two CPU tests, which cover the two most common CPU-side tasks: Physics Simulation and AI. It also has four visual quality presets (Entry, Performance, High, and Extreme) available in the Advanced and Professional versions, which increase the graphics load successively for even more visual quality. Each preset will produce a separate, official 3DMark Score, tagged with the preset in question.
          ใช้งานเสถียรสุดได้แค่ 4.60 GHz เอง ( LinX )
          Originally posted by MajiNPic View Post
          ผมใช้ 4.70GHz ไฟกระเด้งจาก 4.60GHz ขึ้นมาเยอะมากครับ ของผมอยู่ราวๆ 1.45V ถึงจะผ่าน LinX
          Originally posted by Khow View Post
          เคยพูดไปทีนึงว่า 5.0GHz นี่ใช้งานจริงไม่ค่อยจะได้ใช้จริงได้ราวๆ 4.7
          Watch dogs ถ้าไม่ลากที่ 4.5+ นี่ความกระตุกมาเยือนเลยปรับ low ยังกระตุกบัดซบสุดๆ
          Originally posted by sunsun View Post
          ของเว็ปเราเองนี่แหละคับ
          0 เฟรม ไปไม่เป็นเลยทีเดียว ชัดเจน ^^
          เล่นไปกระตุกไป เงิบ ...
          ใช้งานจริง วิ่งไม่ถึง 4.80 GHz นะครับ ^^
          กราฟ การใช้งานจริงมาแล้วนะครับ
          เสพกราฟได้เลย ล่าสุดๆ
          • #50
            • #51
              สรุปแล้ว i7 ดีกว่า สินะ
              • #52
                i8 ดีสุดฮะ (มันมีไหมฟร๊ะ)
                ////เผ่น ....................
                • #53
                  เพิ่มเติมอีกนิด อ่ะครับ
                  โจทย์ นี้จะต่างกับ จัดสเป้คที่ล้อค งบ มา 2.5 3.5 K
                  ซึ่ง FX 8 `หรือ 6 จะถูกกว่าได้ส่วนต่างไปอัดการ์ดจอมาได้ สามารถทำได้แรงกว่าในงบ จำกัด
                  แต่นี้เป้นการ อัพจากเสป้คเดิม ซึ่ง จขกท. ไม่ได้ล้อคงบเท่าไหร่ ????
                  เน้นว่า อัพแล้วแรงกว่าเดิม ส่วนตัวผมว่า คอร์ ฮาสเวล รีเฟรส ที่อัพคล้อก ไปแรงๆๆ
                  อันนั้น น่าจะเห้นผลต่าง จาก ไอวี่ 4 คอร์ อยู่มากครับ เช้คเรื่องความร้อนและ พาวเวอร์คอนซัมป์ชั่น
                  ให้ดีว่า ฮาสเวล รีเฟรส ไม่ใช่ตัว oc น่ะครับไม่งั้น ไปลาก เอาเอง ก็ดร้ายๆๆๆๆๆจริง ถ้าของท่าน มี k
                  ถ้าจะไป i7 บอร์ดZ97 น่าจะรีดประสิทธิภาพดีสุดนะ
                  ช่วงนี้ amd คงต้องปล่อยอินเทลให้แรงทิ้งไป ทำไรมากไม่ได้ครับ รอเอาคืน กลางปี 2015_/// A10 8800 k ละกัน อิอิ
                  คิดว่าน่าจะมัน Carizzo CORE + พลัง HSA และการ์ดจอแยก คงมีโปรแกรมมาซับเยอะละ
                  • #54
                    ขอโทษครับ ผมอ่านแล้วงงๆ หมายถึงตัวนี้ใช่ไหมครับ
                    ( งบประมาณนี้พอดี 5555 )
                    • #55
                      ช่ายครับ งบเยอะ ไม่อั้นจิงๆๆ
                      • #56
                        ครับขอบคุณครับ งบคงประมานนี้แหละครับ ขอบพระคุณครับตัดสินใจละ คงกลับไป intel เหมือนเดิม อิอิ
                        • #57
                          chipset ตัวไหนล่าสุดครับตอนนี้ z97 ใช่ไหมครับ ?
                          • #58
                            บอร์ชิพเซ้ต Z97 น่ะ แพงนิด ซิ้งค์เดิมๆๆไม่แน่ใจเอายู่ไหม อาจต้องเปลี่ยนนะครับเผื่องบด้วย
                            ของเก่าไงขายทั้งชุดน่ามีคนเอาอยู่
                            ไม่เป้นไร อัพแล้วมาโชว์ ประสิทธิภาพให้ดูกันบ้าง ก็ได้อยากรู้ว่า
                            รีเฟรซ แล้ว แรง + ร้อน ขึ้นรึเปล่า อิอิ
                            เทอโบ 3.6-4.0 GHZ ไม่ต้องไปคล้อกเล่นเดิมๆๆ ก็แรงหูดับแล้วผมว่า
                            • #59
                              ของเดิมคงไม่ขายไม่อะไรครับ ให้แฟนใช้ ยกให้เลย
                              ซึงค์ที่ต้องเปลื่ยนนี่ของ เดิมๆ จากตัว cpu หรอครับ
                              ริยังไง
                              • #60
                                ช่ายครับ ประกอบดูก่อนก็ได้ถ้าหนวกหูเสียงดังค่อยเปลี่ยนได้ ถามในโซนอินเทลดุก้ได้
                                น่าจะมีคนถอย มาใช้แล้ว 4790
