AMD Updates Brazos with E-450, E-300 and C-60 APUs
  • AMD Updates Brazos with E-450, E-300 and C-60 APUs
    When AMD first introduced its Brazos platform at the end of last year it promised annual updates to the platform. Today we get the first official update to the platform. Although not a major architectural or process change, the Brazos refresh is significant nonetheless.
    At the top we've got the AMD E-450, a part we previewed at Computex. The E-450 replaces the E-350 and brings with it higher clock speeds. The two CPU cores see a mild increase from 1.6GHz to 1.65GHz, while the 80-core Radeon HD 6320 GPU creeps up from 492MHz to 508MHz. Neither sounds too impressive, but the E-450 has a new trick up its sleeve: AMD Turbo Core. Similar to Llano, if there's available TDP the GPU cores in the E-450 can turbo up to 600MHz. In GPU bound games the E-450 can be up to 22% faster than the E-350.
    The E-450 also adds official DDR3-1333 support (up from 1066). When combined with the faster GPU you might see significantly better gaming performance out of the E-450. Don't expect to get anywhere near Llano's performance, but AMD notes a 36% increase in 3DMark Vantage performance.
    Next up is the E-300, this replaces the single-core E-240. The E-300 has two Bobcat cores, which means the refreshed E-series APUs are all dual-core parts. The CPU clock drops a bit down to 1.3GHz, as does the GPU clock (488MHz) but overall performance should go up as nearly any usage model these days will prefer two similarly clocked cores to one.
    The final update in AMD's Brazos refresh is the 9W C-60. The C-60 replaces the C-50 before it. Both feature two Bobcat cores, but the C-60 adds AMD Turbo Core support - this time on the CPU and GPU. The C-60 runs at the same 1GHz clock speed as the C-50, but it can turbo up to 1.33GHz. The GPU on the other hand can turbo up to 400MHz from its 276MHz stock speed.
    The refreshed Brazos parts are still built on the same TSMC 40nm process and retain the same 18W/9W TDPs. The update to enable Turbo Core is likely only a mild change to the chip and associated BIOS. The higher clock speeds and across-the-board dual-core (E-series) come courtesy of yield improvements. In addition to the extra performance, all refreshed Brazos APUs gain multimode DisplayPort support (DP++). The ++ simply means that you can carry HDMI and DVI signals over the DP connector, allowing OEMs to build systems with only a single DP output and provide passive dongles for single-link DVI and HDMI out.
    The AMD E-450, E-300 and C-60 are available from PC OEMs starting today. No word on when we'll see availability in the channel.
    อันล่างเเปล
    เมื่อเอเอ็มดีเปิดตัวครั้งแรกของแพลตฟอร์ม Brazos ที่ส่วนท้ายของปีที่ผ่านมามันสัญญาว่าจะปรับปรุงประจำปีเพื่อแพลตฟอร์ม วันนี้เราได้รับการปรับปรุงเป็นทางการครั้งแรกเพื่อแพลตฟอร์ม แม้ว่าจะไม่ได้เปลี่ยนสถาปัตยกรรมหรือกระบวนการที่สำคัญที่ Brazos การฟื้นฟูอย่างมีนัยสำคัญกระนั้น
    ที่ด้านบนของเรามีเอเอ็มดี E - 450 ซึ่งเป็นส่วนหนึ่งที่เราดูตัวอย่างที่งาน Computex E - 450 แทนที่ E - 350 และนำมาด้วยความเร็วสัญญาณนาฬิกาที่สูงขึ้น ทั้งสองแกน CPU ดูเพิ่มขึ้นอ่อนจาก 1.6GHz ไป 1.65GHz ในขณะที่ 80 - core Radeon HD 6320 GPU ครีพขึ้นจาก 492MHz ถึง 508MHz ทั้งเสียงที่น่าประทับใจมาก แต่ E - 450 มีเคล็ดลับใหม่ขึ้นที่แขน : AMD แกนเทอร์โบ คล้ายกับ Llano, ถ้ามีใช้ได้ TDP แกน GPU ใน E - 450 สามารถเทอร์โบถึง 600MHz ในเกมที่ถูกผูกไว้ GPU เป็น E - 450 สามารถเป็นได้ถึง 22% เร็วกว่า E - 350
    E - 450 ยังเพิ่มการสนับสนุน DDR3 - 1333 อย่างเป็นทางการ (ขึ้นจาก 1066) เมื่อรวมกับ GPU เร็วขึ้นคุณอาจจะเห็นประสิทธิภาพที่ดีขึ้นอย่างมีนัยสำคัญการเล่นเกมออกจาก E - 450 อย่าหวังว่าจะได้รับประสิทธิภาพการทำงานได้ทุกที่ใกล้ Llano แต่เอเอ็มดีบันทึกการเพิ่มขึ้น 36% ในการทำงาน 3DMark Vantage
    ขึ้นถัดไปคือ E - 300, นี้แทนที่ Single - Core E - 240 E - 300 มีสองแกน Bobcat ซึ่งหมายความว่า Apus E - series ฟื้นฟูมีทุกชิ้นส่วนแบบ dual - core นาฬิกา CPU ลดลงเล็กน้อยลงไปที่ 1.3GHz, เช่นเดียวกับนาฬิกาของ GPU (488MHz) แต่ประสิทธิภาพโดยรวมควรจะไปขึ้นเป็นรูปแบบการใช้งานเกือบ ๆ วันนี้จะชอบสองแกนคล้ายกับการโอเวอร์คล็อกอย่างใดอย่างหนึ่ง
    การปรับปรุงขั้นสุดท้ายในเอเอ็มดี Brazos รีเฟรชเป็น 9W C - 60 C - 60 แทนที่ C - 50 ก่อนที่มันจะ คุณลักษณะทั้งสองแกน Bobcat แต่ C - 60 เพิ่มการสนับสนุน Core AMD เทอร์โบ -- ครั้งนี้เกี่ยวกับ CPU และ GPU C - 60 จะทำงานที่ความเร็วสัญญาณนาฬิกาเดียวกัน 1GHz เป็น C - 50 แต่ก็สามารถเทอร์โบถึง 1.33GHz GPU บนมืออื่น ๆ สามารถเทอร์โบถึง 400MHz จากความเร็ว 276MHz หุ้นของ
    ส่วนการฟื้นฟู Brazos ถูกสร้างขึ้นยังอยู่ในกระบวนการเดียวกัน 40nm TSMC และรักษา TDPs 18W/9W เดียวกัน การปรับปรุงเพื่อให้แกนเทอร์โบมีโอกาสที่จะมีการเปลี่ยนแปลงเพียงเล็กน้อยไปจนถึงชิปและไบออสที่เกี่ยวข้อง มารยาทที่สูงกว่าความเร็วสัญญาณนาฬิกาและทั่ว - the - บอร์ดแบบ dual - core (E - Series) มาจากการปรับปรุงผลผลิต นอกจากนี้ยังมีประสิทธิภาพเสริมทั้งหมดฟื้นฟู Brazos ได้รับการสนับสนุนมัลติ Apus DisplayPort (DP + +) + + เพียงหมายความว่าคุณสามารถดำเนินการส่งสัญญาณ HDMI และ DVI มากกว่าการเชื่อมต่อของ DP ที่ช่วยให้ผู้ผลิตเพื่อสร้างระบบที่มีเพียงการส่งออก DP เดียวและให้ dongles แบบพาสซีฟสำหรับเดียว - link DVI และ HDMI ออก
    เอเอ็มดี E - 450, E - 300 และ C - 60 มีอยู่จากผู้ผลิตเครื่องคอมพิวเตอร์เริ่มตั้งแต่วันนี้ คำเมื่อเราจะดูความพร้อมในช่องไม่มี
    ที่มา
    Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
    น่าสนใจตรง HDMI1.4a RAM1333 DisplayPort++
    ขายๆๆๆ !!!
    ASUS E35M1-M (E350 PC)
    MSI U270 (E350 Netbook)
    ASUS 1015B (C-50 Netbook)
