-The Phenom II has 6mb of L3 cache memory. The Athlon II has no L3 cache memory.
-The Phenom II is 10% faster when the clock rates are equal.
-The Phenom II chip is binned higher then the Athlon II. Which means the Phenom II chip came closer to perfection than the Athlon II chip.
และฝรั่งก็บอกต่อมาว่า....
The more expensive chips like the Phenom II X4 are more stable than an Athlon II X4 chip.
The general rule of thumb is you can overclock a more expensive processor chip higher than a cheaper chip.
