- 7.1 CH HD Audio with Content Protection
- DAC with 110dB dynamic range (VIA® VT2020 Audio Codec)
- Premium Blu-ray audio support
Extream 4
- 7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
- Supports THX TruStudio Pro™
LAN
Extream 4
Supports Energy Efficient Ethernet 802.3az
SATA
Extream 3
6 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10 and RAID 5), NCQ, AHCI and "Hot Plug" functions
Extream 4
5 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10 and RAID 5), NCQ, AHCI and "Hot Plug" functions
USB 3.0
Extream 3
2 x USB 3.0 ports by NEC MPD720200, support USB 1.0/2.0/3.0 up to 5Gb/s
Extream 4
- 2 x Rear USB 3.0 ports by NEC UPD720200, support USB 1.0/2.0/3.0 up to 5Gb/s
- 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by NEC UPD720200, supports USB 1.0/2.0/3.0 up to 5Gb/s
Accessories
Extream 3
Quick Installation Guide, Support CD, I/O Shield
- 4 x SATA Data Cables (optional)
- 1 x SATA 1 to 1 Power Cable (optional)
- 1 x eSATA3 bracket (optional)
Extream 4
- Quick Installation Guide, Support CD, I/O Shield
- 2 x SATA 1 to 1 Power Cables (optional)
- 1 x Front USB 3.0 Panel
- 6 x Screws
