Originally posted by demonkun
CPU Properties
CPU Type DualCore AMD Athlon Black Edition 7850
CPU Alias Kuma
CPU Stepping DR-B3
Engineering Sample No
CPUID CPU Name AMD Athlon(tm) 7850 Dual-Core Processor
CPUID Revision 00100F23h
CPU VID 1.2500 V
North Bridge VID 1.2500 V
CPU Speed
CPU Clock 2812.7 MHz
CPU Multiplier 14x
CPU FSB 200.9 MHz (original: 200 MHz)
HyperTransport Clock 1808.2 MHz
North Bridge Clock 1808.2 MHz
Memory Bus 535.7 MHz
DRAM:FSB Ratio 16:6
CPU Cache
L1 Code Cache 64 KB per core
L1 Data Cache 64 KB per core
L2 Cache 512 KB per core (On-Die, ECC, Full-Speed)
L3 Cache 2 MB (On-Die, ECC, NB-Speed)
Motherboard Properties
Motherboard ID 04/09/2009-RX780-SB710-7A66AG0BC-00
Motherboard Name Unknown
Chipset Properties
Motherboard Chipset AMD 770, AMD K10
Memory Timings 6-6-6-24 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
DIMM3: Kingmax KLEE88F-B8KU6 2 GB DDR2-1100 DDR2 SDRAM (6-7-7-25 @ 555 MHz) (5-5-5-18 @ 400 MHz) (4-4-4-15 @ 333 MHz)
DIMM4: Kingmax KLEE88F-B8KU6 2 GB DDR2-1100 DDR2 SDRAM (6-7-7-25 @ 555 MHz) (5-5-5-18 @ 400 MHz) (4-4-4-15 @ 333 MHz)
BIOS Properties
System BIOS Date 04/09/09
Video BIOS Date 05/04/09
Award BIOS Type Award Modular BIOS v6.00PG
Award BIOS Message AMD 770 BIOS for GA-MA770-US3 FA
DMI BIOS Version FA
Graphics Processor Properties
Video Adapter ATI Radeon HD 4670 (RV730)
GPU Code Name RV730 (PCI Express 2.0 x16 1002 / 9490, Rev 00)
GPU Clock 165 MHz (original: 750 MHz)
Memory Clock 299 MHz (original: 800 MHz)
