Pls help choose M/B krab....
  • Pls help choose M/B krab....
    I have
    - AMD Phenom 1090T
    - A.DATA DDR3 2000 MHz CL9 (4GB)
    - XFX HD4890 1GB
    - Antec Signature 650
    What brand/model of motherboard that you recommend krab?
    Heat Sink?
    - Overclock is not the important issue. Wanna overclock but prefer to have the system stability.
    - System will be 24/7
    - Don't want to over spend (Crosshair IV formula) because I am not the extreme gamer.
    ASUS M4A88TD-M/USB3 = 3,540
    ASUS M4A89TD PRO = 5,640
    GIGABYTE GA-890GPA-UD3H = 4,340
    GIGABYTE GA-890FXA-UD7 = 6,800
    GIGABYTE GA-880GA-UD3H = 3,440
    Above costs by J.I.B.Computer
    ASROCK 890GX EXTREME 3 = 3,990 By TKCom
    Do U want to check spec, go to that's brand web.
      Let's say
      - Gigabyte motherboard can run only 1866(OC) but the RAM can run 2000 MHz, Asus can run at 2,000(OC), will I notice the significant drop in performance?
      - For chipset 890FX, 890GX, 880 and 870, what will be a good choice, since I don't run the crossfire, onboard Video nor a super-overclock?
