# Model : ECS NForce6M-A2
# CPU : Socket AM3 socket for AMD Phenom II processors
High-performance HyperTransport 1.0 CPU Interface
Support transfer rate up to 2000 mega-transfers per sencond
# Chipset : NVIDIA GeForce 6100/nForce 430
# System Bus : 2000 MT/s
# Memory : Dual-channel DDR3 memory architecture
4 x 240-pin DDR3 DIMM socket support up to 32GB
Support DDR3 1333/1066/800 SDRAM
# Expansion Slots
1 x PCI Express x16
1 x PCI Express x1
3 x PCI
(No Parallel Port)
# Storage/RAID
1 x ATA133 IDE connectors (support 2 x IDE devices)
1 x FDD
4 x Serial ATAII 3.0Gb/s devices
# Audio : Realtek ALC662 6-channel HD audio CODEC
# Lan : Realtek RTL8111DL Gigabit Lan (Co-lay RTL8103EL)
# USB : Max. 10 USB 2.0 ports (6 port at mid-board)
# Form Factor : ATX Size, 305mm 210mm
# 24-pin EATX Power connector
# 4-pin ATX 12V power connectors
# OS Compatibility : Windows : XP/Vista/Win 7
# Expansion Slots
1 x PCI Express x16
1 x PCI Express x1
3 x PCI
(No Parallel Port)
# Storage/RAID
1 x FDD
