The M4A89GTOD PRO comes with an expansive feature-set thanks to the AMD 890G. The more interesting component being the AMD SB800 southbridge chip, which is on its way to being one of the first PC motherboard chipsets to natively support SATA 6 Gb/s. The chip doles out six SATA 6 Gb/s ports, while doing away with its on-die IDE controller. An external JMicron-made storage controller compensates with an IDE connector, a SATA 3 Gb/s port (colored black) and perhaps an eSATA port (at 3 Gb/s speeds), too.
The AM3 socket CPU is powered by a 5-phase (two chokes per phase) VRM. It is wired to four DDR3 DIMMs for dual-channel memory. Expansion slots include two PCI-Express 2.0 x16 (x8, x8 when both are populated), two PCI, and one each of PCI-Express x4 and PCI-Express x1. There's the usual VIA-made 8+2 channel HD audio CODEC with optical SPDIF connectivity, FireWire, USB 2.0 ports from the southbridge, and observable display connectivity which includes DVI and D-Sub. Interestingly the blank padding right below the audio connectors shows there could be room for a revision with USB 3.0 support using an NEC-made two port USB 3.0 controller. ASUS may release this board a little later this year, probably in Q2.
เครดิต : http://www.techpowerup.com/112338/AS..._Pictured.html
งดแรงชั่วคราว
