มาเเล้วในราคา3080บาท คิดยังบ้างครับ ผมเห็นเเล้วสีสันดูเเล้วอย่างแก่
รายละเอียด http://www.asus.com/product.aspx?P_I...9zK&templete=2
CPU AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
AMD 140W CPU Support
AMD Cool 'n' Quiet™ 2.0 Technology (by CPU type)
Support 45nm CPU
*Refer to www.asus.com for the AMD CPU support list
Chipset AMD 770/SB710
System Bus Up to 5200 MT/s HyperTransport™ 3.0 interface
Memory 4 x DIMM, Max. 16 GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Due to OS limitation, when installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Install a 64-bit WindowsWindows® OS when you want to install 4GB or more memory on the motherboard.
*Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
Expansion Slots 2 x PCIe 2.0 x16 (*blue@ x16 mode, black@ x4 mode)
1 x PCIe x1
3 x PCI
Storage SB710 Chipset
1 xUltraDMA 133/100
5 x Serial ATA 3Gb/s Support RAID 0,1,10
1 x eSATA 3Gb/s ports
LAN Realtek 8112L PCIe Gb LAN
Audio VT1708S High Definition Audio 8 -Channel CODEC
- Supports Jack-detect and Multistreaming teconologies, and Front Panel Jack-Retasking
- Optical S/PDIF Out ports at back I/O
USB 12 USB 2.0 ports (6 ports at mid-board, 6 ports at back panel)
ASUS Unique Features ASUS EPU-4 Engine
ASUS Express Gate
ASUS Turbo Key
ASUS Q-Fan
ASUS CrashFree BIOS 3
ASUS EZ Flash 2
ASUS MyLogo 2
ASUS AI NET 2
Overclocking Features Intelligent overclocking tools
- Turbo Key
SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 550MHz at 1MHz increment
- PCI Express frequency tuning from 100MHz up to 150MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Back Panel I/O Ports 1 x PS/2 Keyboard/Mouse Combo port
1 x Parallel
1 x External SATA
1 x S/PDIF Out (Optical)
1 x LAN(RJ45) port
6 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 3 x USB connectors supports additional 6 USB 2.0 ports
1 x IDE connector
5 x SATA connectors
1 x CPU / 1 x Power / 1 x Chassis Fan connectors
1 x S/PDIF Out connector
1 x System Panel connector
1 x CD audio-in connector
1 x High Definition Front panel audio connector
1 x 24-pin EATX power connector
1 x 4-pin ATX 12V Power connector
BIOS 8 Mb Flash ROM
AMI BIOS, PnP, DMI v2.0, WfM2.0, ACPI v2.0a, SMBIOS 2.5
Accessories User's manual
1 x I/O Shield
1 x UltraDMA 133/100/66 cable
2 x SATA cable
Support Disc Drivers
ASUS PC Probe II
Express Gate
Anti-virus software (OEM version)
ASUS Update
Form Factor ATX Form Factor
12 inch x 8.8 inch ( 30.5 cm x 22.4 cm )
Support 45nm CPU
1 x PCIe x1
3 x PCI
1 xUltraDMA 133/100
ASUS Express Gate
ASUS Turbo Key
ASUS Q-Fan
ASUS EZ Flash 2
ASUS MyLogo 2
ASUS AI NET 2
- Turbo Key
1 x Parallel
1 x External SATA
1 x LAN(RJ45) port
6 x USB 2.0/1.1
1 x COM port
1 x IDE connector
5 x SATA connectors
BIOS 8 Mb Flash ROM
1 x I/O Shield
2 x SATA cable
ASUS PC Probe II
Express Gate
ASUS Update
