SAPPHIRE MOBO AM3!!
  • SAPPHIRE MOBO AM3!!
    ไม่รู้ว่ามีใครเห็นหรือยังนะครับ ซำก็ขออภัยด้วย
    Features and Benefits
    AMD Phenom&tarade; Quad-Core Processors with True Quad-Core Technology
    Realize new possibilities for connecting with friends, family, and digital entertainment with the phenomenal performance of the AMD Phenom™ II AM3 series quad-core processor. Built from the ground up for true quad-core performance, AMD Phenom™ processors speed through advanced multitasking, critical business productivity, advanced visual design and modeling, serious gaming, and visually stunning digital media and entertainment
    AMD™ 790GX Chipset: Backbone of the Performance Platform
    AMD™ 790GX chipset based PCs feature the latest PCI-Express™ 2.0 bus technology and deliver high performance,low latency architecture offer one of the industry’s advanced core-logic solutions with qualified performance and the latest technologies-PCI Express 2.0, secure high-speed networking, and high-performance storage—and ensures that your PC stays ready for the newest games, future applications, and next-generation PC specifications
    ATI CrossFireX Technology
    With two PCI-Express lanes deliver high transfer rate at each relative direction to support multi graphics engines embedded in VGA cards. With this fantastic design of ATI CrossFireX Technology to link ATI VGA cards graphics engines that will bring up wonderful multiple times of performance than single graphics engine can approached in enthusiast gaming PC.
    ATI Hybrid Graphics Technology
    To provide better gaming performance than a single graphics card, the innovative design of ATIHybrid Graphics Technology is capable to bring additional performance increase up to 1.75X by enabling the power of both integrated graphics core and the add-on graphics card simultaneously
    Hyper Transport Technology 3.0
    The highly scalable Hyper Transport 3.0 is capable to provide incredible bandwidth of the system bus up to 20.8GB/s which would dramatically elevate the efficiency of computing performance.
    AMD New generation of 45nm AMD Socket AM3 processors
    The 45nm AM3 processors that support Hyper Transport 3.0 Bus and integrate DDR3 memory controller, To provide advanced visual design and modeling, serious gaming, and visually stunning digital media and entertainment.
    GPU Clock Adjustable
    Onboard VGA can over-clocking
    Serial ATA2 3Gb/s&RAID ,e-SATA
    This platform supports reliable storage solution for enhanced data protection and data accessing performance. Serial ATA 3Gb/s is firstly introduced in this platform to provide blazingly 3Gb/s bus bandwidth thus higher disk performance. The SATA RAID allows multi-disk designs to be set up as RAID 0, 1,10 based on users’ priority of protection/performance, and which even makes more accessible by introducing the innovative windows-based facility
    E-SATA is a new standard for external storage devices. With an external data transfer rate of up to 3 Gb/s no other external data transfer solution can compete with speed and ease of use
    PCI-Express Gigabit LAN
    Delivers transfer speed ten times faster than conventional 10/ 100 Ethernet connections, supporting a high transfer rate up to Gigabit/s. Gigabit LAN is the networking standards for the future and is ideal for handing large amount of data such as video, audio, and voice
    DVI Interface
    DVI (Digital Visual Interface) provides high visual quality of digital display devices such as LCD monitors
    OC-CON high-polymer solid electrolysis aluminum capacitors embedded
    The working temperature is from 55 degrees Centigrade below zero to 125 degrees Centigrade, OC_CON capacitors possess superior physical characteristics that can be while reducing the working temperature between 20 degrees Centigrade each time, intact extension 10 times of effective product operation lives, at not rising degrees Centigrade of working temperatures each time a relative one, life of product decline 10% only too.
    Debug Port / The Professional Hardware Diagnosis System
    Being bugged of abnormal system failure through the tossed and turned nights no more, the embedded Hardware Debug Port offers you the real-time visual system healthy for the demanding usage of computing. No more bugging by unknown system failure and no more time wasted in the first moment of 24-hour nonstop ping business computing, the embedded Debug Port will turn you into a well training hardware professional with the seeing system situation.
    CPU Vcore 7-Shift / Shift to the scalabilities and flexibilities
    The adjustable voltage for CPU Vcore can be upgraded in 31 stages for the precisely hardware dynamic over-clocking of demanding computing performance.
    CPU
    Supports AMD Socket AM3: AMD AM3 Series processors
    Chipset
    AMD™ 790GX Chipset + AMD™SB750 Chipset
    Hyper Transport Bus
    HT 3.0
    Memory
    Dual Channel DDR3 memory technology
    4 * 240-pin DDR3 DIMM slots
    Supports DDR3 800/1066/1333 non-ECC ,un-buffered memory, module to 1600/1800/2133 can use
    Max.16GB
    Expansion Slots
    2 * 32-bit PCI slots
    2 * PCI Express 2.0 x16 slots by 8-LANE
    2 * PCI Express x1 slots
    Storage
    AMD™SB750 Southbridge Chipset :
    6 * Serial ATA2 3Gb/s connectors
    Supports HDDs with RAID 0, 1,5,10 functions
    1 * Ultra DMA 133 / 100 / 66 IDE connector
    Audio
    Realtek ALC888 HD Audio CODEC with 8-Channel
    Ethernet LAN
    Realtek RTL8111CVC PCI Express Gigabit NIC
    USB
    Embedded 12 * USB 2.0/1.1
    Special Features
    Advanced Power Design that supports the latest Socket-AM3 CPU
    SupportACPI S3 & CPU Smart FAN & D.I.Y Switch x3
    BIOS 7-Segment Debug LED
    ATI Hybrid graphics technology to enhance graphic performance max to 70%~80% with ATI Radeon HD2400 / HD3400 series graphics card
    ATI CrossFireX technology to do H/W CrossFire by multi graphic engines
    IMAGE IT!” System Backup Software and “ProMagicPLUS!” System Recovery System
    Rear Panel I / O
    4 * USB 2.0/1.1 ports
    1 * PS/2 mouse port + 1 * PS/2 keyboard port
    1 * VGA port+1 * DVI port+1 * HDMI port
    1 * RJ-45 port
    1 * Audio I / O ports
    1 * e-SATA port
    Internal I / O
    4 * USB 2.0/1.1 headers for 8 USB 2.0/1.1 ports
    CPU / Chassis Fan connectors
    1 * 8-pin ATX 12V Power connector
    1 * 24-pin ATX Power connector
    1 * COM header
    CD / AUX Audio in
    1 * HDMI_SPDIF header
    BIOS
    Award 8MB SPI Flash ROM
    Form Factor
    ATX Form Factor (305mm X 245mm)
    Chipset: AMD® 790GX + SB750
    Processor: Support AMD® AM3 CPU
    ATI Hybrid CrossFire Technology
    PCI-E® 2.0 and HT™ 3.0 technology
    6 Phase Vcore + 1 phase NB PWM design
    DDR3 DIMM up to 16GB 1333MHz Dual Channel
    Gigabit LAN + 8CH HD Audio
    2 PCI-E X16 + 2PCI-E X1 + 2 PCI
    High-End components used and high overclocking
    อ่อ ตัวนี้ นี่เอง เห็นแล้วครับ โล่งๆ
      เอามายั่วน้ำลายซะงั้น ของไม่มีคนเอามาทำตลาดในไทย เหอ
        หุหุ ทำการ์ดจอละดีแล้ว อิอิ
          ดูๆไปรู้สึกว่าสีมันทำมาแบบไม่สดใสเลยดูขุ่นๆไม่ค่อยจะสวยอ่านะ การ์ดจออ่ะดีแล้ว สวยแหล่ม
