Athlon II X2 240 2.8 GHz 2,320 (jiB)
45nm SOI 2MB socket AM3 65W
AMD64 Technology Yes
Simultaneous 32- & 64-bit computing Yes
L1 Cache (Instruction + Data)
64K of L1 instruction and 64K of L1 data cache per core (256KB total L1 per processor)
L2 Cache (total dedicated) 2 MB
HyperTransport™ Technology
One 16-bit/16-bit link @ up to 4.0GHz full duplex (2.0GHz x2)
Integrated DDR Memory Controller
Memory Controller Width 128-bit
Type of Memory Supported
Support for unregistered DIMMs up to PC2-6400 (DDR2-800MHz) -AND- PC3-8500 (DDR3-1066MHz)
Memory Bandwidth
Up to 17.1 GB/s total bandwidth (DDR3-1066) + 16.0GB/s (HT3)
Up to 12.8 GB/s total bandwidth (DDR2-800) + 16.0GB/s (HT3)
Total Processor-to-system Bandwidth (HyperTransport plus memory bandwidth)
Up to 33.1GB/s bandwidth
Up to 28.8GB/s bandwidth
Process Technology
45 nanometer, SOI (silicon-on-insulator) Technology
Packaging
socket AM3 (938-pin) organic micro PGA
Thermal Design Power
65W
Die Size 117.5 mm2
Number of Transistors ~234 million
Manufacturing Sites
GLOBALFOUNDRIES Fab 1 Module 1.
E5200 2,420 (JIB)
Essentials
Status Launched
Launch Date Q3'08
Processor Number E5200
# of Cores 2
Clock Speed 2.5 GHz
L2 Cache 2 MB
FSB Speed 800 MHz
FSB Parity No
Instruction Set 64-bit
Embedded No
Supplemental SKU No
Lithography 45 nm
Max TDP 65 W
VID Voltage Range 0.962V-1.200V
เปรียบเทียบที่ราคา 2000+ ประสิทธิภาพคงไม่ต้องบรรยายกันมาก
Memory Bandwidth
Process Technology
Packaging
65W
Die Size 117.5 mm2
Manufacturing Sites
E5200 2,420 (JIB)
Essentials
Status Launched
Launch Date Q3'08
# of Cores 2
Clock Speed 2.5 GHz
L2 Cache 2 MB
FSB Speed 800 MHz
FSB Parity No
Embedded No
Supplemental SKU No
Lithography 45 nm
Max TDP 65 W
