เมื่อ LANPARTY DK ขายดีจึงมีต่อ
  • เมื่อ LANPARTY DK ขายดีจึงมีต่อ
    LANPARTY DK 790FXB-M2RSH
    เสป็ค:
    CPU
    * AMD® AM2+ processors: Phenom FX / Phenom / Athlon / Sempron AMD® AM2 processors: Athlon series / Sempron
    * HyperTransport 3.0 (5200MT/s for AM2+) HyperTransport 1.0 (2000/1600MT/s for AM2)
    * AMD OverDrive provides tuning options using the new “Advanced Clock Calibration” overclocking feature.
    * Socket 940 AM2+ 65nm
    Chipset
    * AMD chipset - Northbridge: AMD 790FX - Southbridge: AMD SB750
    System Memory
    * Four 240-pin DDR2 DIMM sockets
    * Supports DDR2 667/800/1066 MHz DIMMs
    * Supports dual channel (128-bit wide) memory interface
    * Supports up to 8GB system memory
    * Supports unbuffered non-ECC x8 and x16 DIMMs
    Expansion Slots
    * 3 PCI Express (Gen 2) x16 slots - 2-way or 4-way CrossFire at x16/x16/NC bandwidth - 3-way CrossFire at x16/x8/x8 bandwidth - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
    * 3 PCI slots
    BIOS
    * Award BIOS
    * CMOS Reloaded
    * CPU/DRAM overclocking
    * CPU/DRAM/Chipset overvoltage
    * 8Mbit SPI flash memory
    Audio
    * Realtek ALC885 8-channel HD Audio Codec
    * High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight)
    LAN
    * Marvell 88E8053 PCIE Gigabit LAN controller
    * Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
    Serial ATA with RAID
    * Supports up to 6 SATA devices
    * SATA speed up to 3Gb/s
    * RAID 0, RAID 1 and RAID 0+1
    IDE
    * One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
    Rear Panel I/O
    * 1 mini-DIN-6 PS/2 mouse port
    * 1 mini-DIN-6 PS/2 keyboard port
    * 1 optical S/PDIF-out port
    * 1 coaxial RCA S/PDIF-out port
    * 6 USB 2.0/1.1 ports
    * 1 RJ45 LAN port
    * Center/subwoofer, rear R/L and side R/L jacks
    * Line-in, line-out (front R/L) and mic-in jacks
    Internal I/O
    * 3 connectors for 6 additional external USB 2.0 ports
    * 1 connector for an external COM port
    * 1 front audio connector
    * 1 CD-in connector
    * 1 IrDA connector
    * 1 CIR connector
    * 6 Serial ATA connectors
    * 1 40-pin IDE connector
    * 1 floppy connector
    * 1 24-pin ATX power connector
    * 1 8-pin 12V power connector
    * 2 4-pin 5V/12V power connectors (FDD type)
    * 1 front panel connector
    * 6 fan connectors
    * EZ touch switches (power switch and reset switch)
    Power Management
    * ACPI and OS Directed Power Management
    * ACPI STR (Suspend to RAM) function
    * Wake-On-PS/2 Keyboard/Mouse
    * Wake-On-USB Keyboard/Mouse
    * Wake-On-Ring
    * Wake-On-LAN
    * RTC timer to power-on the system
    * AC power failure recovery
    Hardware Monitor
    * Monitors CPU/system/chipset temperature
    * Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
    * Monitors the speed of the cooling fans
    * CPU Overheat Protection function monitors CPU temperature during system boot-up
    PCB
    * ATX form factor
    * 24.5cm (9.64") x 30.5cm (12") All specifications above are subject to change without prior notice.
    สเป็ค:
    CPU
    Chipset
    System Memory
    Expansion Slots
    * 3 PCI slots
    BIOS
    * Award BIOS
    * CMOS Reloaded
    Audio
    LAN
    IDE
    Rear Panel I/O
    * 1 RJ45 LAN port
    Internal I/O
    * 1 CD-in connector
    * 1 IrDA connector
    * 1 CIR connector
    * 6 fan connectors
    Power Management
    * Wake-On-Ring
    * Wake-On-LAN
    Hardware Monitor
    PCB
    * ATX form factor
    สำหรับคนที่ใช้ LANPARTY DK 790FX-M2RS อยู่ตอนนี้มี เบต้าไบออส new micro code สำหรับ Support AM3 CPUs ออกแล้วครับ
    ดาวน์โหลดได้ที่ http://img.lanparty.tw/Upload/BIOS/CM/D7LDA01.zip
      แจ่มเป็ด
      ส่งสัยจะได้เลิกเปลี่ยนงานนี้
      ท่าน _d มีราคาคร่าวๆใหมครับ
        Originally posted by wikorn View Post
        แจ่มเป็ด
        LANPARTY DK 790FXB-M2RSH เมืองนอกราคาราวๆ 5,700 บาทครับ
        ส่วนอีกตัวน่าจะถูกกว่าหน่อยนึง คิดว่าราคาคงอยู่ราวๆห้าพันนี่ล่ะครับ
        ส่วนราคาบ้านเราก็บวกขึ้นไปตามระเบียบครับ
          ถ้าไม่แพงมากจะสอยแน่นอน
            สวยมากครับ
            แรงแน่ แน่
              ราคา+ขึ้นไป น่าจะราวๆ 6พัน
              แจ่มเป็นครับ
              ส่วนผม ใช้รุ่นพี่มันอยุ่ (790FX-M2RS)
                และแล้ว SB750 ก็มาสถิตกะ Dark ว่าแต่ทำไม่มันไม่เปลี่ยน Sink NB เนี่ย
                  สวยมาก น่าจะแหล่ม
                    เงินกำลังจะหมุนไป ๆ
                      2รุ่นนี้ออกเป็นเดือนละแต่ บ้านเราเค้าไม่เอามาขายนี่ดิปัญหา
                        ถ้าเทียบกับ Foxconn DFI ดีกว่าหรอคับ ในเรื่องเกี่ยวกับ OC นะ
                          แหล่มๆ
                            เหลืองทั้งบอร์ดเลย เหอๆ เรืองแสงด้วยรึเปล่าครับเนี่ย
                              สวยเว้ย อยากได้
