Mainboard ล่าสุด จากทาง DFI
  • Mainboard ล่าสุด จากทาง DFI
    เท่าที่เปิดดูมี2 ตัวใหม่เพิ่มเข้ามาครับ
    ไม่รู้ว่า TK จะนำเข้าไหมน๊อ งานนี้ งามดีแท้ๆ
    เริ่มจากตัวแรกเลย
    เขามีนามว่า
    "LANPARTY DK 790GX-M2RS"
    CPU
    # AMD® AM2+ processors: Phenom FX / Phenom / Athlon / Sempron AMD® AM2 processors: Athlon series / Sempron
    # HyperTransport 3.0 (5200MT/s for AM2+) HyperTransport 1.0 (2000/1600MT/s for AM2)
    # AMD OverDrive provides tuning options using the new “Advanced Clock Calibration” overclocking feature.
    # Socket 940 AM2+ 65nm
    Chipset
    # AMD chipset - Northbridge: AMD 790GX - Southbridge: AMD SB750
    System Memory
    # Four 240-pin DDR2 DIMM sockets
    # Supports DDR2 667/800/1066 MHz DIMMs
    # Supports dual channel (128-bit wide) memory interface
    # Supports up to 8GB system memory
    # Supports unbuffered non-ECC x8 and x16 DIMMs
    Expansion Slots
    # 2 PCI Express (Gen 2) x16 slots - Hybrid CrossFireX - combination of the integrated graphics and a discrete graphics card in a PCIE slot (8-lane port). - Two graphics cards support CrossFireX; each operating at x8 (8-lane ports) bandwidth
    # 1 PCI Express x1 slot
    # 3 PCI slots
    BIOS
    # Award BIOS
    # CMOS Reloaded
    # CPU/DRAM overclocking
    # CPU/DRAM/Chipset overvoltage
    # 8Mbit SPI flash memory
    Graphics
    # Integrated ATI Radeon HD 3300 graphics core
    # One DVI-I connector for digital LCD display
    # Microsoft® DirectX 10
    # Hybrid CrossFireX technology combines the onboard GPU and a discrete PCIE graphics card
    # Onboard Performance cache for added performance
    Audio
    # Realtek ALC885 8-channel HD Audio Codec
    # High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight)
    LAN
    # Marvell 88E8056 PCIE Gigabit LAN controllers
    # Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
    Serial ATA with RAID
    # Supports up to 6 SATA devices
    # SATA speed up to 3Gb/s
    # RAID 0, RAID 1 and RAID 0+1
    IDE
    # One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
    Rear Panel I/O
    # 1 mini-DIN-6 PS/2 mouse port
    # 1 mini-DIN-6 PS/2 keyboard port
    # 1 optical S/PDIF-out port
    # 1 coaxial RCA S/PDIF-out port
    # 1 IEEE 1394 port
    # 6 USB 2.0/1.1 ports
    # 1 RJ45 LAN port
    # Center/subwoofer, rear R/L and side R/L jacks
    # Line-in, line-out (front R/L) and mic-in jacks
    Internal I/O
    # 3 connectors for 6 additional external USB 2.0 ports
    # 1 connector for an external COM port
    # 1 connector for an external IEEE 1394 port
    # 1 DVI connector
    # 1 front audio connector
    # 1 CD-in connector
    # 1 IrDA connector
    # 1 CIR connector
    # 6 Serial ATA connectors
    # 1 40-pin IDE connector
    # 1 floppy connector
    # 1 24-pin ATX power connector
    # 1 8-pin 12V power connector
    # 1 4-pin 5V/12V power connector (FDD type)
    # 1 front panel connector
    # 6 fan connectors
    # 1 diagnostic LED
    # EZ touch switches (power switch and reset switch)
    Power Management
    # ACPI and OS Directed Power Management
    # ACPI STR (Suspend to RAM) function
    # Wake-On-PS/2 Keyboard/Mouse
    # Wake-On-USB Keyboard/Mouse
    # Wake-On-Ring
    # Wake-On-LAN
    # RTC timer to power-on the system
    # AC power failure recovery
    Hardware Monitor
    # Monitors CPU/system/chipset temperature
    # Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
    # Monitors the speed of the cooling fans
    # CPU Overheat Protection function monitors CPU temperature during system boot-up
    PCB
    # ATX form factor
    # 24.5cm (9.64") x 30.5cm (12") All specifications above are subject to change without prior notice.
    ตัวต่อปายยย
    "LANPARTY DK 790FXB-M2RSH"
    CPU
    Chipset
    # AMD chipset - Northbridge: AMD 790FX - Southbridge: AMD SB750
    System Memory
    Expansion Slots
    # 3 PCI Express (Gen 2) x16 slots - 2-way or 4-way CrossFire at x16/x16/NC bandwidth - 3-way CrossFire at x16/x8/x8 bandwidth - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
    # 3 PCI slots
    BIOS
    # Award BIOS
    # CMOS Reloaded
    Audio
    LAN
    # Marvell 88E8053 PCIE Gigabit LAN controller
    IDE
    Rear Panel I/O
    # 1 RJ45 LAN port
    Internal I/O
    # 1 CD-in connector
    # 1 IrDA connector
    # 1 CIR connector
    # 2 4-pin 5V/12V power connectors (FDD type)
    # 6 fan connectors
    Power Management
    # Wake-On-Ring
    # Wake-On-LAN
    Hardware Monitor
    PCB
    # ATX form factor
    แฮะ รออยู่น๊าส์
    เหอๆ แปลนเดียวกันเดียร์
      ถ้ามีขายก็คงดีอ่ะ งิงิ
      sigpic
      งดแรงชั่วคราว
        ไอ้ตัวที่สองนี่แหละ
        อย่าแพงมากนะ มองอยู่
          TK ไม่นำเข้าเด่วผมนำเข้าเอง เอิ๊กๆๆ
            จัดมา
