CPU Cooler Zalman 7000B-CU LED ใส่ AM2 ไม่ได้ครับทำไง ดี ครับ
  • CPU Cooler Zalman 7000B-CU LED ใส่ AM2 ไม่ได้ครับทำไง ดี ครับ
    พอดี ไปสอยมือสองมา ใส่ กับ 939 อยู่แต่ ถอยมา ใส่ ax78 รู มาให้ แบบ 4 รู สงสัยใส่ไม่ได้ ช่าย ป่าว ครับ
      The Zalman CNPS7000B-Cu CPU Cooler with a cool blue LED fan inside? Oh Yeah! The CNPS7000B-Cu takes the tried and true 7000A and increases its performance while shaving off a cool 18g of weight. The 7000B packs a 92mm fan and a 3154 cubic centimeter pure copper heat dissipation area! Designed for use with some of the hottest CPUs on the market, Intel LGA775, Intel Pentium 4 (Socket 478), AMD Duron/Athlon/Athlon XP (Socket 462), and Sempron/AMD64 (Socket 754/939/940), the CNPS7000B-Cu is a safe bet. And best of all, the 92mm fan coupled with the included FAN MATE 2 keeps your system running cool silently. Features: Does not generate noise or vibration in Silent Mode Pure Copper base material ensures excellent heat dissipation Intel Pentium 4 (Socket 478), AMD Duron/Athlon/Athlon XP (Socket 462), and Sempron/AMD64 (Socket 754/939/940) compatible design for broad compatibility 92mm fan inside the HSF maximizes airflow and makes installation easier The adjustable fan speed controller (FAN MATE 2) enables control of noise and fan performance Blue LED fan Specifications: Compatibility: Intel: P4 LGA775 - All Speeds (With Optional Clip Available Below) P4 478 Willamette - All Speeds P4 478 Northwood - All Speeds P4 478 Prescott - All Speeds AMD: Duron 462 – All Speeds Athlon 462 Thunderbird Athlon XP 462 Palomino – All Speeds Athlon XP 462 Thoroughbred – All Speeds Athlon XP 462 Barton – All Speeds Athlon 64 754 – All Speeds Athlon 64 939 – All Speeds Athlon 64 FX 939 – All Speeds Athlon 64 FX 940 – All Speeds Opteron 940 – All Speeds Dimensions: 109 x 109 x 62mm (L x W x H) Weight: 755g Base Material: Pure Copper Dissipation Area: 3154 cm2 Bearing Type: Double Ball Bearing Speed: 1350~2600rpm +/- 10% Thermal Resistance: 0.27~0.20 C/W Noise Level: 18~27.5dBA +/- 10% * Note: The maximum weight for a cooler is specified as 450g for Intel Socket 478 and AMD Socket 754/939/940, and 300g for the AMD Socket 462 CPU. Special care should be taken when moving a computer equipped with a cooler which exceeds the relevant weight limit. Zalman Tech is not responsible for any damage that occurs when moving a computer.
      ในเว็บบอกใส่ได้ งง ครับ
        มันมีตัวล็อคมาให้ด้วยนะ ลองถามเจ้าของดีดี
        เค้าไม่แถมตัวล็อค AMD มาให้อ่ะสิ
        ปล. VVVV ใช้ตัว8700 NT มีมาให้นะคับ
        AMD สู้ๆคร้าบบบบ
          ไม่มีครับ ขาย ต่อได้มั้ยเนี่ย ใครรับ ดูแล ต่อบ้าง ครับ
            บางอันก็เป็นขาล็อคมากับน็อตอะครับ หรือไม่ก็เป็นตัวล็อค แน่นมากๆ ขอบอกๆ
