โห นึกว่า แรม ผม เสีย ใน bios มอง ถูกน่ะครับ
x2 6000+ ก่ะ ax78 ลากได้สุดๆๆ เท่าไร ครับ ใครลองแล้วบอกกันน่อยครับ
Hardware Monitor 1.0.6.0
Mainboard Vendor http://www.abit.com.tw/
Mainboard Model AX78(AMD770+SB600) (0x41F - 0xB0B6520)
LPCIO
Vendor Winbond
Model W83627DHG
Vendor ID 0x5CA3
Chip ID 0xA0
Revision ID 0x23
Config Mode I/O address 0x2E
Dump config mode register space, LDN = 0xB
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 FF FF FF FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 A0 23 FF 00 C4 00 00 FF 50 00 7C 00 EA 00 00 FF
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 02 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor
Winbond W83627DHG hardware monitor
Voltage sensor 0 1.44 Volts [0xB4] (CPU VCORE)
Voltage sensor 1 6.41 Volts [0x73] (+12V)
Voltage sensor 2 3.25 Volts [0xCB] (AVCC)
Voltage sensor 3 3.23 Volts [0xCA] (+3.3V)
Voltage sensor 4 1.21 Volts [0x97] (VIN1)
Voltage sensor 5 3.34 Volts [0x8B] (+5V)
Voltage sensor 6 1.56 Volts [0xC3] (VIN3)
Temperature sensor 0 34ฐC (93ฐF) [0x22] (SYSTIN)
Temperature sensor 1 58ฐC (136ฐF) [0x74] (CPUTIN)
Fan sensor 1 2058 RPM [0x29] (CPUFANIN0)
Dump hardware monitor
LPC Register space, base address = 0x0290
bank 0
00 04 FF 04 FF 14 23 32 55 80 80 B3 CC FF FF 00 00
10 04 FF 70 00 00 01 01 3C 43 17 00 00 FF FF FF C2
20 B4 73 CB CA 97 8B C3 22 FF 29 FF D4 00 BB 5A F7
30 A4 72 21 BB 5A BB 7D EB 9D 3C 3C 8C 8C 8C 8C FF
40 03 00 00 FF FF FF 07 05 2D 00 00 07 D9 15 80 5C
50 FF FF 00 FF FF FF B7 A7 C1 F0 FF FF 19 E4 00 05
60 04 C4 55 23 7F FF 3C FF 01 FF 01 FF FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
80 04 FF 04 FF 14 23 32 55 80 80 B3 CC FF FF 00 00
90 04 FF 70 00 00 01 01 3C 43 17 00 00 FF FF FF C2
A0 B4 73 CB CA 97 8B C3 22 FF 29 FF D4 00 BB 5A F7
B0 A4 72 21 BB 5A BB 7D EB 9D 3C 3C 8C 8C 8C 8C FF
C0 03 00 00 FF FF FF 07 05 2D 00 00 07 D9 15 80 5C
D0 FF FF 00 FF FF FF B7 A7 C1 F0 FF FF 19 E4 00 05
E0 04 C4 55 23 7F FF 3C FF 01 FF 01 FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bank 1
50 3A 00 02 50 00 50 01 88 FF FF FF FF FF FF FF FF
bank 2
50 37 00 02 64 00 64 1F 00 FF FF FF FF FF FF FF FF
bank 3
50 05 07 01 05 01 06 04 01 04 05 00 20 52 0B 00 00
bank 4
50 00 13 FF 00 00 0F 00 05 5A 48 8C 8B 09 5D 20 7F
bank 5
50 CB 88 0A FF 6F 48 09 B1 8F 2B 00 00 E3 00 00 00
Hardware monitor
AMD Athlon 64 X2 6000+ hardware monitor
Temperature sensor 0 53ฐC (127ฐF) [0x66] (core #0)
Temperature sensor 1 56ฐC (132ฐF) [0x69] (core #1)
Hardware monitor
ATI Radeon HD 2600 PRO hardware monitor
Temperature sensor 0 50ฐC (121ฐF) [0x32] (GPU Core)
Hardware monitor
Hitachi HDP725025GLA380 hardware monitor
Temperature sensor 0 34ฐC (93ฐF) [0x22] (HDD)
Hardware monitor
Temperature sensor 0 33ฐC (91ฐF) [0x21] (HDD)
Processors Map
Number of processors 1
Number of threads 2
Processor 0
-- Core 0
-- Thread 0
-- Core 1
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name AMD Athlon 64 X2 6000+
Codename Windsor
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 6000+
Package Socket AM2 (940)
CPUID F.3.3
Extended CPUID F.43
Brand ID 4
Core Stepping JH-F3
Technology 90 nm
Core Speed 3125.3 MHz (12.5 x 250.0 MHz)
HT Link speed 1250.1 MHz
Stock frequency 3000 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
max FID 15.0x
max VID 1.450 V
Features XD, VT
K8 Thermal sensor yes
K8 Revision ID 5.3
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02002008h
Max CPUID level 00000001h
Max CPUID ext. level 80000018h
Function eax ebx ecx edx
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00040F33 0x00020800 0x00002001 0x178BFBFF
0x80000000 0x80000018 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00040F33 0x000009A3 0x0000001F 0xEBD3FBFF
0x80000002 0x20444D41 0x6C687441 0x74286E6F 0x3620296D
0x80000003 0x32582034 0x61754420 0x6F43206C 0x50206572
0x80000004 0x65636F72 0x726F7373 0x30303620 0x00002B30
0x80000005 0xFF08FF08 0xFF20FF20 0x40020140 0x40020140
0x80000006 0x00000000 0x42004200 0x04008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x0000003F
0x80000008 0x00003028 0x00000000 0x00000001 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00000040 0x00000000 0x00000000
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
Cache descriptor Level 1 I 64 KB 1 threads
Cache descriptor Level 1 D 64 KB 1 threads
Cache descriptor Level 2 U 1 MB 1 threads
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0xC001001E edx = 0x00000000 eax = 0x00000053
MSR 0xC0010015 edx = 0x00000000 eax = 0x02000041
MSR 0xC0010042 edx = 0x31041206 eax = 0x04160211
MSR 0xC0010041 edx = 0x00000001 eax = 0x00000611
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 02002008h
0x00000001 0x00040F33 0x01020800 0x00002001 0x178BFBFF
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00800
Drive
Name Hitachi HDP725025GLA380
Drive
ร้อนมั้ยครับ
