AMD Ryzen 5 PRO 4650G 6 Core Benchmarks Leak With Better Graphics & Overclock !!
  • AMD Ryzen 5 PRO 4650G 6 Core Benchmarks Leak With Better Graphics & Overclock !!
    Just a few days after the Ryzen 7 PRO 4750G benchmarks leaked out, the AMD Ryzen 5 PRO 4650G and the Ryzen 3 PRO 4350G Renoir APUs have also leaked along with their specs and benchmarks. Both APUs are part of the AMD Ryzen 4000 Renoir PRO series family which will be launching next week on the 21st of July as we had exclusively reported earlier this month.
    AMD Ryzen 5 PRO 4650G 6 Core APU Specifications
    The AMD Ryzen 5 PRO 4650G is a Zen 2 APU featuring 6 cores and 12 threads. The APU has clocks configured at 3.7 GHz base and 4.3 GHz boost. The CPU featured 6 MB of L3 cache and has a TDP of 65W. The GPU side comes with Vega 7 integrated graphics that support 448 cores running at a clock speed of up to 1900 MHz.
    When compared to the Ryzen 5 3600X, the Matisse CPU has to offer a 3.8 GHz base and a 4.4 GHz boost clock. That's a 2% increase in both base and boost clocks over the Renoir APU. The Ryzen 5 3600X also features a higher TDP of 95W which will allow it to sustain higher clock speeds for long durations compared to the Renoir APU. The AMD Ryzen 5 3600X currently costs around $219.99 US while the Ryzen 5 PRO 4650G is expected to hit a price point close to $249 US or lower.
    AMD Ryzen 4000 'Renoir' Desktop APU Lineup
    AMD Ryzen 7 4700G 7nm Zen 2 8/16 3.6 GHz 4.45 GHz DDR4-3200 Vega 8 / 512 SPs 2100 MHz 65W ~$289 US
    AMD Ryzen 5 4400G 7nm Zen 2 6/12 3.7 GHz 4.30 GHz DDR4-3200 Vega 7 / 448 SPs 1900 MHz 65W ~$219 US
    AMD Ryzen 3 4300G 7nm Zen 2 4/8 3.8 GHz 4.10 GHz DDR4-3200 Vega 6 / 384 SPs 1700 MHz 65W ~$139 US
    AMD Ryzen 7 PRO 4750G 7nm Zen 2 8/16 3.6 GHz 4.45 GHz DDR4-3200 Vega 8 / 512 SPs 2100 MHz 65W ~$289 US
    AMD Ryzen 5 PRO 4650G 7nm Zen 2 6/12 3.7 GHz 4.30 GHz DDR4-3200 Vega 7 / 448 SPs 1900 MHz 65W ~$219 US
    AMD Ryzen 3 PRO 4350G 7nm Zen 2 4/8 3.8 GHz 4.10 GHz DDR4-3200 Vega 6 / 384 SPs 1700 MHz 65W ~$139 US
    AMD Ryzen 7 PRO 4750GE 7nm Zen 2 8/16 3.1 GHz 4.35 GHz DDR4-3200 Vega 8 / 512 SPs 2000 MHz 35W TBA
    AMD Ryzen 5 PRO 4650GE 7nm Zen 2 6/12 3.3 GHz 4.25 GHz DDR4-3200 Vega 7 / 448 SPs 1900 MHz 35W TBA
    AMD Ryzen 3 PRO 4350GE 7nm Zen 2 4/8 3.5 GHz 4.1 GHz DDR4-3200 Vega 6 / 384 SPs 1700 MHz 35W TBA
    Source : https://wccftech.com/amd-ryzen-5-pro...nchmarks-leak/
    แถม เพิ่มความ Hype (เกินจริง)
      เทคโนล้าหลัง แถมไม่มี AVX512 ด้วย แถม ไมโครซอฟท์ลอยแพไม่ออก insider preview สำหรับซีพียูเอเอ็มดี ยังไงก็ K A K แถมเน่าคาร้านด้วย
      อันนี้ของ 4750G ยังสู้ 3700X ไม่ได้ แต่ได้คล็อคกับลาเทนซี่ต่ำกว่า (อย่างที่ผมเคยบอกไป สถาปัตยกรรม Zen2 แคช L3 หายไปความแรงก็หายไป แต่ได้คล็อคมาชดเชย)
      ที่มา cr : https://www.techpowerup.com/270006/a...el-performance
      ปล. ลองรัน Geekbench5 บนเครื่องของตัวเอง 3700X แบบเดิมๆ แถมเปิดอะไรๆ ค้างไว้เยอะ ได้คะแนน Single-Core Score 1311 , Multi-Core Score 8488
        สนใจ
        -AMD Ryzen 5 4400G
        -AMD Ryzen 5 PRO 4650G
        ไม่รู้ว่าจะออกวางขายตอนไหนครับ
          Originally posted by bome2004 View Post
          สนใจ
          -AMD Ryzen 5 4400G
          เห็นว่าจะวางขายเดือนสิงหาครับ ผมชื้อทุกอย่างมารอหมดแล้วเหลือ CPU อย่างเดียว แต่มองแล้วตัวรหัส 4เร็วกว่ามากเลย คิดว่าต้นเดือนหน้าราคาเจนเก่าคงลดลงพอสมควรเพื่อต้อนรับการมาของรหัส 4
            ลองเอาฝั่ง mobile มาเทียบดูครับ
              คะแนน กับข่าวพวกนี้แหละ ที่ผมมองว่า ข่าวความแรงของ TIGERLAKE มันแปลกๆ
              ว่าทำไมถึงเขี่ยพวก เกลาเหลา 8 หัว ร่วงได้ เหลือ 2 เดือน เห็นว่า EVENT ใหญ่จะมา
              จะมาแบบ LGA1200 นี่มั้ย ถ้าแป๊กล่ะบันเทิง
                VEGA 11 น่าจะสูญพันธุ์แล้ว เจอ VEGA 8 เพิ่มคล็อกแบบนี้
                  เซ็งกับการกั้กจริง
                    โอ้ว แรงดีๆ เดียวลองเทียบกะ Intel 8750h ผมหน่อย
                    ช่วงแรกๆ ลำคาน CPU throttling เหลือเกิน ต้องใช้ CPU throttling stop ลดไฟ ทาง AMD มีปัญหานี้มั่งไหมหว่า สนใจ 4800HS
                      AMD Ryzen 7 4700G Renoir APU With Vega 8 GPU Is Almost As Fast As Entry-Level Discrete Graphics When Overclocked
                        เอิ่ม...วันแรกที่ผมได้มา นั่นคือเรื่องแรกที่ผมไปปรึกษาคุณ ZoLKoRn เลยล่ะครับ
                        ถ้า ยี่ห้อ/รุ่น ที่มีการระบายความร้อนดี มันก็น่าสนครับ
                          Intel CPU รุ่นต่อไปจะใช้ฟังชั่นนี้ไม่ได้แล้วตะหาก หมายถึงลดไฟอ่ะน่ะ เอ้อ สงสัยจะให้มันวิ่งเต็ม ต้องแกะเครื่องเปลือยแบบ Desktop
                            AMD Ryzen 7 4700G APU Overclocked To Almost 5.0 GHz Across All 8 Cores, Gigabyte Achieves DDR4-5400 Memory Overclock on Renoir Desktop Platform
                            https://wccftech.com/amd-ryzen-7-470...400-overclock/
