มีว่างขายในบ้านเราแล้วยัง
www.asrock.com
A780FullDisplayPort
Support for Socket AM2+ / AM2 processors: AMD Phenom™ FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor
AMD 780G + SB700 Chipsets
FSB 2600 MHz (5.2 GT/s)
Supports Dual Channel DDR2 1066 with AM2+ CPU , and DDR2 800/667 with AM2 CPU, with 4 DIMM slots, maximum capacity up to 8GB
Integrated AMD RV610 graphics , DX10 class iGPU, Pixel Shader 4.0, Max. shared memory 512MB
Supports ATI™ Hybrid CrossFireX™
1 x PCI Express 2.0 x16 slots (green @ x16 mode)
6 x Serial ATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10 and JBOD), NCQ, AHCI and Hot Plug functions
Supports PCIE Gigabit LAN 10/100/1000 Mb/s
Supports 2 x IEEE1394 ports (one port on back panel, one header on board)
Four VGA Output options: D-Sub, DVI-D, HDMI and Displayport
Supports HDCP function to enjoy better quality with High Definition HDCP Encryption contents
Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback
1 x WiFi/E header
Supports ASRock OC Tuner
Windows® Vista™ Premium 2007 Logo Ready
Free Bundle: 1 x ASRock DisplayPort Card, 1 x DVI-to-HDMI converter
ASRock 1394_DVI I/O Plus: 1 x VGA/D-Sub Port, 1 x VGA/DVI-D Port, 1 x IEEE 1394 port, 6 ready-to-use USB ports
www.asrock.com
A780FullDisplayPort
1 x WiFi/E header
