ผู้ใช้ AMD หลายคนต้องหัวร้อน เมื่อ!มีเพียง CPU ไม่กี่ตัวเท่านั้นที่ Boost ได้ตาม Spec
  • ผู้ใช้ AMD หลายคนต้องหัวร้อน เมื่อ!มีเพียง CPU ไม่กี่ตัวเท่านั้นที่ Boost ได้ตาม Spec
    Der8auer: Only Small Percentage of 3rd Gen Ryzen CPUs Hit Their Advertised Speeds
    World famous overclocker Der8auer published his survey of boost clocks found on 3rd generation Ryzen CPUs. Collecting data from almost 3,000 entries from people around the world, he has found out that a majority of the 3000 series Ryzen CPUs are not hitting their advertised boost speeds. Perhaps one of the worst results from the entire survey are for the 12-core Ryzen 9 3900X, for which only 5.6% of entries reported have managed to reach the boost speeds AMD advertises. However, the situation is better for lower-end SKUs, with about half of the Ryzen 5 3600 results showing that their CPU is boosting correctly and within advertised numbers.
    Der8auer carefully selected the results that went into the survey, where he discarded any numbers that used either specialized cooling like water chillers, Precision Boost Overdrive - PBO or the results which were submitted by "fanboys" who wanted to game the result. Testing was purely scientific using Cinebench R15 and clock speeds were recorded using HWinfo (which got recommendation from AMD), so he could get as precise data as possible.
    Der8auer comments that he still recommends Ryzen 3000 series CPUs, as they present a good value and have good performance to back. He just finds it very odd that AMD didn't specify what you need to reach the advertised boost speeds.
    "Why did AMD feel that it is necessary to advertise the boost or give the people false expectations and false hope for something that they cannot get? Why did they have to do the 3900X at 4.6 [GHz] when they probably clearly know that most of those CPUs would never maintain this speed? It was clearly never necessary to do this; it's completely unnecessary. The CPUs are good enough the way they are. They deliver, and they're good. But those frequency values are just completely wrong." - Der8auer
    เหมือนโดนหลอกแบบ FX หัวพิการ มีสมองไม่ครบ 2 ซีก แต่บอกมี 8 หัว
    ปัญหาหลักๆ เนื่องมาจากความหัวร้อน เอ้ย ความร้อนของ CPU เอง
    World famous overclocker Der8auer published his survey of boost clocks found on 3rd generation Ryzen CPUs. Collecting data from almost 3,000 entries from people around the world, he has found out that a majority of the 3000 series Ryzen CPUs are not hitting their advertised boost speeds. Perhaps one...
      Ryzen 3000 Series Boost Frequency Fix Incoming!
      https://wccftech.com/ryzen-3000-series-boost-frequency-fix-incoming/
      The AMD 3rd gen Ryzen 3000 series CPUs are some of the best processors ever released but there a few minor problems which may prevent them from performing as expected. In this video we go over how to find and in some cases possibly fix issues with CPU boost, BIOS settings, high idle
        ต้อง สูญเงินอีกเท่าไหร่ ถ้าอยากจะวิ่งตาม Spec CPU ทั้งบอร์ด และ ระบบระบายความร้อน
        หรือต้องจ่ายเงินเยอะๆ เพราะชอบ และ สวย แต่ต้องมาโดนบอร์ดเก่าๆ กากๆ ทุบหัวขมำด้วย แต่ไม่รู้เรื่องการปรับ Ram นะ
          เฉยๆๆ
            เรื่อง นี้ไม่หัวร้อน แต่หัวร้อน เพราะ R5 2600 เล่นเกมแล้วกระตุก 1เกม
              รู้สึกเฉยๆเพราะซีพียูราคาถูกมาก แค่นี้ก็คุ้มมากมาย
                เคยมีคนนึงโพสไว้ คนไม่ได้ซื้อใช้หัวร้อนกว่าเยอะ
                จะมาเล่าในส่วนของคนใช้ มันอาจอยู่ที่ไบออส ที่ต้องออกรอมาแก้ไขจริงๆ
                ส่วนตัวใช้ 3700X สเปคบอกบูทได้ที่ 4.4 Ghz มีไบออสนึงของบอร์ดผม
                ที่มันบูทได้จริงๆนะ แต่แปปเดียวและหัวเดียว แต่อัพไบออสแก้ไขโน่นนี่ของมันไปมา
                ตอนนี้เหลือประมาณ 4.3 กว่าๆ ในหลายๆ คอร์ แต่ไม่ทุกคอร์ ส่วนตัวแอบเซ็งนิดๆ ว่าเมื่อไหร่เมิงจะนิ่งสักที
                แต่ก็ยอมรับได้ รอไบออสเค้าออกมาแก้ต่อไป โครตชอบซิ้ง RGB แถม กับประสิทธิภาพ CPU ผมว้าวมากๆ เลยแหละ
                ส่วนตัวก็ยังอคติกับ CPU อีกค่าย ซึ่งผมว่านโยบายการตลาดมันน่ารังเกียจ และเคยทำให้ผมหัวร้อนกว่าเยอะ ผมว่ามันเอาเปรียบผู้บริโภคมากๆ
                เรื่องซิ้งแถมที่ไม่มีคุณภาพหรือไม่แถมเลย รวมถึงประเด็นหลักคือ การใช้แป้งเปียกใต้กระดอง ผมไม่เห็นด้วยอย่างยิ่ง
                ผมถึงย้ายมาใช้ค่ายนี้ ณ ปัจจุบัน | AMD FX ก็เคยซื้อใช้และเคยบอกว่า เป็นการซื้อที่โง่ที่สุดในชีวิตครั้งนึงในชีวิตเลย
                  ปัญหามันอยู่ที่ AMD เมื่อไรจะปรับปรุงซักทีจะได้เลิกโดนด่าสักที ไม่ใช่ไบออสอะไรหรอก นั้นมันปลายเหตุ ทำออกมาแล้วไม่ดี ปล่อยออกมาก็มีบัค
                  ผมว่าไปๆมาๆ Gen 3 นี่ปัญหาเยอะกว่า Gen 1 อีก ขนาดผม Gen 1 Day One ใช้ Gen 1 มาไม่เห็นมีปัญหาอะไรจุกจิกขนาดนี้ นอกจากเรื่อง Ram แต่ปัญหาจะไม่เยอะขนาดนี้ ถ้าไม่ใช่คำขี้โม้วของ ผู้บริหารที่โฆษณาเกินจริงไปหน่อย
                  อยากจะเสถียร คงต้องรอ Gen 4 ออกมา เหมือนสมัย Gen 2 ออกมานั้นละ
                    3700x ผมบูทได้แค่ 42.75 ghz -บูทสูงสุด 5 คอร์พร้อมกัน รอดู bios ต่อไป
                      ท่าจะจริง คนไม่มีใช้หัวร้อนกว่าเยอะ
                      ดูอย่างอั๋นไม่ได้ใช้ ยังมาตั้งกระทู้คือยืนยันได้ชัดเจน
                      และยอดขายRYZEN 3000 ยืนยันเองว่ามันควรใช้ หรือไม่ควรใช้
                        อันนี้นี่ปัญหาใหญ่เลย X570 ไปไม่ถึง แต่บอร์ดรุ่นปู่ไปได้ดีกว่า
                          เข้ามาหัวร้อน
                            ไปอ่านข่าวในเวปนอก เห็นว่า AMDพวกเขาระบุปัญหาในเฟิร์มแวร์ของตน พวกเขาจะทำการอัปเดต Biosในวันที่ 10 กันยายนเพื่อแก้ในเรื่องนี้ รอดูกันต่อไป
                              ฟ้องเลยครับ เผื่อได้ค่าขนม แต่ในไทยคงไม่มีทาง แต่ที่เมกามีลูกคุณช่างฟ้องเยอะ ขนาดเรื่องคดีเรื่องคอร์ของรถไถ เอเอ็มดียังแพ้เลย
