Single-Event Effects (SEE) testing was conducted on the AMD Ryzen 3 2200G microprocessor with integrated graphics. Testing was conducted at Massachusetts General Hospital's (MGH) Francis H. Burr Proton Therapy Center on June 2nd, 2019.
การทดสอบเป็นการยิง Proton เพื่อจำลองการถูกทำร้ายจาก รังสี cosmic ที่จะเหนี่ยวนำ Electron ให้หลุดจาก Gate และ Bus Line บน CPU
เพื่อดูว่าจะนำ CPU อะไรมาใช้ในอณาคต ( MAR Colony ISS ) ทำไปเพื่อว่าจะเลือก computer devise ให้นักบินอวกาศ ไปเล่น PUBG ฆ่าเวลาบนโนน้นละมั้ง
แต่จริงๆแล้งอาจจะไม่ใช่แค่นี้ก็ได้ รอดูกันไปครับ
Manufacturers stipulate that their processors are not intended for high-reliability applications, and this fact is generally understood when it comes to designing potential spacecraft. However, this major limitation does not preclude the community from characterizing the technology. The change in process from planar to three-dimensional design, on its own, warrants further study, given how relatively young it is. The complexity of these commercially available FinFET devices has a significant impact on their testability. These devices contain billions of transistors with a high layer of abstraction between device input/output (I/O) and the transistor level response. In addition, the devices require significant on-board circuitry such as proprietary power management integrated circuits (PMICs), DDR3 and DDR4 dynamic random access memory (DRAM), and often proprietary low level boot code.
Single-Event Effects (SEE) testing was conducted on the AMD Ryzen 3 2200G microprocessor with integrated graphics; herein referred to as device under test (DUT). The goal of this work is to provide a baseline on radiation susceptibility data for the DUT. While not all radiation-induced errors are critical, the effects on the application need to be considered. More so, failure of the device and an inability to reset itself should be considered detrimental to the application. Radiation effects on electronic components are a significant reliability issue for systems intended for space.
ข่าวพวกนี้ถ้าอยู่แต่ในห้อง INกะลา new room นี่ ไม่มีทางรู้หรอกครับ จริงมัย?
และที่แปลกใจอีกอย่าง ทำไม NASA สนใจจะทดสอบ CPU ก๊อบ คุณภาพต่ำ ที่ MS จัดให้อยู่ในกลุ่มประชากรชั้นสอง ก็ไม่รู้สิครับ
แต่ผมรู้อย่างนึงคือ NASA ไม่ได้สนใจจะใช้ AVX512 แน่ๆ ไม่งั้นจะทดสอบ บน RYZEN G ที่ใช้ ZEN-1 architecture ทำไม ก็มันมีแค่ FMA-128
Single-Event Effects (SEE) testing was conducted on the AMD e9173 Graphics Processor Unit (GPU). Testing was conducted at Massachusetts General Hospital's (MGH) Francis H. Burr Proton Therapy Center.
Proton Testing of AMD Ryzen 3 1200 Microprocessors
July 23, 2019
Single-Event Effects (SEE) testing was conducted on the AMD Ryzen 3 1200 microprocessor. Testing was conducted at Massachusetts General Hospital's (MGH) Francis H. Burr Proton Therapy Center on June 2nd, 2019.
NASA เค้าสนใจ อะไร AMD หว่า
เอามาเล่าให้ฟังขำๆ ครับๆ
