How to Enjoy Blu-ray Movies without a Blu-ray Player?
  • How to Enjoy Blu-ray Movies without a Blu-ray Player?
    If you still have no good idea of how to spend the vacation, I have got an idea ? why not rant or shop some interesting movie Blu-ray Disc and share the happiest hours with your family?
    The great picture quality of Blu-ray movie could bring you unprecedented visual experiences. However, you need the help of a Blu-ray player to enjoy the Blu-ray movie. So if the device, such as your iPad, Mac, etc. does not support Blu-ray, you would get in a trouble. Luckily, Aiseesoft Blu-ray Ripper could help you solve all these problems.
    Aiseesoft Blu-ray Ripper is a powerful and professional Blu-ray ripping tool to rip Blu-ray disc and common DVD to any popular video and audio formats. Plus, this Blu Ray Ripper can also help you convert most popular video files. Most excitingly, this Blu-ray Ripper enables users customize video effect, such as trimming video, cropping video frame, watermarking video, etc.
    Now, this article would show you how to rip Blu-ray with this Blu-ray Ripper
    Step 1: Download Aiseesoft Blu-ray Ripper and install this application in your computer
    After launching the Blu Ray Ripper, you could see the interface as bellow.
    Step 2: Load your Blu-ray Disc or common DVD.
    Step 3: Customize video effect
    Trim video length
    The Blu-ray Ripper enables you to trim the video length by setting its start and end time. Or you can just drag the slide bar.
    Watermark video
    You can add any text/image watermark to your video and set its position and transparency.
    Merge video clips
    This feature enables you to merge several Blu-ray movies into one. You just need to choose the movies you need and click the ?Merge? button.
    Crop video frame
    You can crop the video frame by cutting off the black edges and unwanted areas. Also you are allowed to adjust video aspect ratio: Full Screen, 16:9, 4:3 and Keep Original
    Adjust video effect
    You can adjust video brightness, saturation and contrast.
    Step 4: Start converting
    After all these settings, you can press the ?Start? button to convert the Blu-ray ripping process.
