Full Guide: How to Convert DVD to MP4, AVI, 3GP, iPod ......
  • Full Guide: How to Convert DVD to MP4, AVI, 3GP, iPod ......
    DVD is the first choice for many people when they want to watch movies at home. It has high quality picture, different subtitles and audio tracks and most important, some of the DVD movies are more enjoyable than than the cinema one.
    However, when we travel, when the disc is broken, when we want to backup the DVD movies, when we want to share the movies with friends, when we want to make usage of the movie, what should we do?
    Convert DVD to video video formats you need.
    This guide aims to show you how to convert DVD to different video format both for windows/mac users.
    Part 1: How to Convert DVD on Windows with DVD Ripper
    Step 1: Load DVD
    Put your DVD to your DVD Drive and click “Load DVD” button to add your DVD
    Step 2: Choose Profile
    Choose your output video profile from a drop-down list.
    Step 3: Start Conversion
    Part 2: How to Convert DVD on Mac with DVD Ripper for Mac
    Step 1: Load DVD
    Click the “Load DVD” button, find the DVD folder of the movie you want to add from your DVD-ROM, and Click “Open”.
    Step 2: Choose output profile and settings
    Selecting output format is really easy, you can chose your output format according to your devices players and the default setting works great.
    For a veteran of digital player, you could customize your own settings by clicking “Settings” button to chose your own video resolution, frame rate, bit rate, encoder, etc.
    If you want to convert both DVD and videos, here is a really powerful DVD Converter Suite. It can help you to convert DVD and videos easily. It can also help you to backup the iPod music and videos to your computer.
    Total Video Converter
    iPhone Ringtone Maker
    Best DVD Ripper
    โอ้ พอดีเลยกำลังนึกอยากทำพอดี
      ถามหน่อยมันเกี่ยวกับเกมส์ตรงไหน ถ้าเอา เกมสที่เป็นDVD9 มาแปลงเป็น MP3จะเอาไปเล่นบน Nokiaได้มั้ย
      ก่อนตั้งกระทู้อ่านหน่อย Software ZoneกับGAME Zone เขียนต่างกัน
      อยากจะขอบคุณที่มีน้ำใจ แต่มันไม่ถูกกาลเทศะ
        ดูวันที่ สมัคร ด้วยครับ
        วันที่สมัคร: 1 Jul 2010
        หุหุ
          อย่าไปด่าบอทมันครับ~ เพราะมันเป็นแค่บอท..
          หุหุ....
            People want to show their individuality anytime and anywhere with their inimitable hairstyle, clothing, and other things. Your phone's ringtone is also really important to show your difference from others. So how to make your own unique ringtone for your incoming calls, clock alarms, clock timer becomes a really important thing.
            Today I will show you how to make your own iPhone ringtones from your DVD/video/music. Someone will say that you can buy them on itunes. Yes, everybody can buy it. It is not unique and special. Let's make our own iPhone ringtone together.
            Things you need:
            1. DVD/video/audio files that contains the music you want
            2.iPhone Ringtone Maker
            3. Computer(Windows/Mac)
            Step 1: Load File/DVD
            Load your video/audio files or DVD to this iPhone Ringtone Maker
            Step 2: Choose music
            You need to choose which part you want to convert as your iPhone ringtone or you want to make the whole files as your iPhone ringtone. Just drag the bar to set the begin point and end point
            Step 3: Pre-listening
            You can pre-listening the ringtone, if you do not like it you can adjust the length of your ringtone.
            Step 4: Make Ringtone
            After you have done all the tings above, you can click “Generate” button to start the conversion.
            Soon you will get your own ringtone.
            Tips:
            1. if you want to put your ringtone directly to your iPhone, please check the box before “import to iPhone”.
            2. if you want to manage your ringtone, you can click “manage ringtone” button to do it easily.
            For Mac users, you can use
            iPhone Ringtone Maker for Mac to do this easily with the same operation as windows one.
            To help you to make your iPhone and iPod more enjoyable here I also recommend you this
            DVD to iPod Converter,
            DVD to iPhone Converter and iPod Transfer
