Bluesky Frame Rate Converter Version 2.12.1 (06/29/2018) ใหม่ AMD Fluid Motion 60FPS
  • Bluesky Frame Rate Converter Version 2.12.1 (06/29/2018) ใหม่ AMD Fluid Motion 60FPS
    Changes
    Fixed issue that "Enable support for DXVA decoder" setting was not functioning
    http://bluesky23.yukishigure.com/en/BlueskyFRC.html
    LAV Filters 0.72
    0.72.0 - 2018/06/19
    LAV Video
    Changed: Enabled CineformHD decoding by default, since the decoder has much improved
    Fixed: Decoding Matroska files with Linked Segments which used old x264 44 encodes could result in corruption
    LAV Audio
    NEW: Blu-ray Dolby Digital Plus 7.1 decoding and bitstreaming support
    NEW: LAV Audio will fallback to audio decoding if bitstreaming is not supported by the audio renderer/hardware
    Fixed: DTS-HD HRA bitstreaming did not work properly with many A/V receivers
    Fixed: TrueHD bitstreaming could result in drop-outs on high bitrate TrueHD+Atmos streams
    0.71.0 - 2018/02/15
    General
    - LAV Filters now requires Windows Vista or newer, Windows XP is no longer supported
    LAV Splitter
    - NEW: Preliminary support for UHD Blu-ray parsing
    LAV Video
    - NEW: D3D11 hardware accelerated decoding (native mode with madVR, Copy-Back otherwise)
    - Fixed: HDR metadata was not properly communicated to madVR in DXVA2-Native mode
    - Fixed: Anamorphic WMV9/VC-1 videos were not being played back with the correct aspect ratio in all cases
    - Fixed: Changing certain settings while playback was paused could result in a deadlock
    - Fixed: Playing severly corrupted HEVC streams with hardware decoding could result in playback failing entirely, instead of skipping over the corruption
    LAV Audio
    - NEW: Basic support for AAC 960 streams (common in DVB radio streams)
    0.70.2 - 2017/07/06
    LAV Video
    Fixed: DXVA2 decoding could fail in 0.70 after a dynamic media type change
    0.70.1 - 2017/07/01
    LAV Video
    NEW: DXVA2-CopyBack uses D3D9Ex to allow headless operation
    Changed: Increased the maximum number of decode threads to 32
    Changed: Rebalanced the "Auto" thread strategy to use the exact number of available CPU cores, instead of 1.5x the cores
    Fixed: Certain H264 streams could crash in 0.70 due to lack of buffer padding
    0.70.0 - 2017/06/15
    General
    Official LAV Filters builds require a SSE2 capable CPU
    LAV Splitter
    Fixed: Certain MP4/MOV files didn't play or seek correctly in recent versions of LAV Splitter
    Fixed: HEVC in MP4 without PTS timestamp is being signaled appropriately
    Fixed: Closing RTSP streams did not properly call the TEARDOWN function
    LAV Video
    NEW: CUVID support for VP9 8/10-bit and HEVC 10/12-bit decoding
    NEW: DXVA2 support for VP9 10-bit decoding
    Changed: Simplified the internal dataflow to reduce overhead and improve performance
    Changed: Enabled P010 output to EVR on Windows 10 Creators Update
    Fixed: Y416 output was incorrect (required by madVR 0.91.8 and newer)
    Fixed: Parsing H.264 MVC SEI NALs could fail in some cases
    Fixed: CUVID decoding could deinterlace progressive streams under certain circumstances, degrading the quality
    LAV Audio
    Fixed: LATM AAC streams with Program Config Elements (PCE) (common in DVB-T2 broadcast) played with audible distortions
    Fixed: Very short PCM audio streams didn't play properly
    https://www.videohelp.com/software/L...tory#changelog
