MPC-HC v1.7.10.56 อัฟเดท LAV Filters to v0.67.0.44 ใครสนใจ กดเบาๆ ^^
  • MPC-HC v1.7.10.56 อัฟเดท LAV Filters to v0.67.0.44 ใครสนใจ กดเบาๆ ^^
    MPC-HC v1.7.10.56
    This file includes only a short list of the changes between MPC-HC's versions.
    For the older changes see:
    https://github.com/mpc-hc/mpc-hc/blo...ngelog_old.txt
    Legend:
    + New
    * Changed
    ! Fixed
    next version - not released yet
    * Updated Unrar to v5.3.8
    * Updated Little CMS to v2.7 (git 40c6403)
    * Updated MediaInfoLib to v0.7.80-1-g3fc28610
    * Updated ZenLib to v0.4.32
    * Updated LAV Filters to v0.67.0.44:
    - LAV Splitter: Support HTTPS protocol
    - LAV Splitter: Switch back to an improved version of old asf demuxer
    - LAV Video Decoder: Add experimental support for VP9 DXVA2 decoding (disabled by default)
    - LAV Video Decoder: Enable hardware decoding for HEVC and 4k/UHD by default
    - Ticket #5666, LAV Video Decoder: YADIF deinterlacing sometimes caused black screen in DVD menus
    - LAV Audio Decoder: Fix a possible crash when using bitstreaming
    * Old DirectX 7 renderers have been removed. Settings will be updated automatically to use the corresponding VMR-9 renderers.
    If you really want to use a renderer similar to VMR-7 (windowed), use Overlay mixer or the "system default" renderer
    * Make video renderer statistic scalable to window size and unify graph look for Sync and other renderers
    * Rewrite subtitles downloading framework
    - Support for multiple subtitle providers including default OpenSubtitles as well as podnapisi, titlovi, SubDB and ysubs
    which can be enabled in options (Subtitles->Misc)
    - Ability to login into OpenSubtitles
    - Ability to filter subtitle list by selected languages
    - Option to automatically search and download subtitles at the beginning of playback without user interaction
    - Prioritize subtitles for hearing impaired where indicated
    * Updated Basque, Belarusian, Bengali, Catalan, Chinese (China), Czech, Danish, Finnish, French, German, Greek,
    Hungarian, Indonesian, Japanese, Lithuanian, Malay, Romanian, Polish, Portuguese (Brazil), Punjabi, Russian,
    Slovak, Spanish, Swedish, Thai, Turkish and Ukrainian translations
    ! Window position and/or size could be wrong when exiting fullscreen mode for the first time and
    "Launch files in fullscreen" option is enabled.
    https://mpc-hc.org/
    รูปซ้าย หรือ บน RGB32 รูปขวา หรือ ล่าง NV12
    รูปซ้ายสีจะเข้ม รูปขวาสีจะไม่เหมือนรูปซ้าย+สว่างกว่าหน่อย ถ้าใครสายตาแยกความแตกต่างได้นะ ^^
    เพื่อใครสงสัย ทามมายต้องลงรูป จะได้ไว้ให้ตัดสินใจ ตั้งค่า config ไว้เปรียบเทียบ ว่าเป็นแบบไหน เดิมๆ ลงโปรแกรมเสร็จ หลัง install ครับ
    ลงเสร็จแล้ว อย่าลืมตั้งค่า config กันนะครับ
    ผมนี่
    ตอนแรกที่ลบ MPC รุ่นเก่าออกนี้ แล้วพอลงใหม่ แล้วไปดูอนิเม นี่ ตอนแรกก็ว่า เฮ้ย ทำไมสีมันไม่เหมือนเดิม แปลกใจมากๆๆ ดูแล้วสีมันแปลกๆ.. ดูแล้วสีเปลี่ยนไป ตอนแรกก็ว่ารู้สึกไปเอง หรือสายตาเราเพี้ยนหรือป่าวหว่า หรือ สีมันเปลี่ยนไปจริงๆ หรือว่าตัว MPC ตัวใหม่มันปรับสี ....บลาๆๆ
    บังเอิญมีรูปดูอนิเมกันดั้ม ตอนใช้ MPCเวอร์ชั่นเก่าอยู่ ก็เลยจับมาเทียบกับสีรูปเก่าที่เซฟเอาไว้ ก็เลยเห็นว่าสีแตกต่าง จริงๆ ไม่ได้รู้สึกไปเองว่ามันต่าง เลยไล่หาสาเหตุ พอไล่ไปไล่มา ก็เลยเจอสาเหตุตรงนี้ นี่เอง นั้นเอง ^^
      เลือก คำสั่งนี้ใน MPC หรือ กดคีย์ลัด ตรวจสอบว่า MPC Output NV12 หรือ RGB32 หรือ อื่นๆ ครับ
        กดตั้งค่ายังไงหรอ
          Originally posted by TNPG View Post
          กดตั้งค่ายังไงหรอ
          กดตรงนี้ครับ ตั้งค่า Lav ที่ติดมากับ MPC ครับ
          แล้วมันจะไปโผล่ที่ config Lav ตามรูปนี้ครับ ที่เหลือ ก็งม ดำน้ำเอาเองต่อเลยครับ
          แต่ถ้าตั้งค่า config อื่นๆ ที่เราแอดไว้ เลือกตรงนี้ แล้ว คลิ๊กเม้าเข้าไปตั้งค่าได้ ครับ
            ถ้าแยกไม่ออกนี่สายตาแย่แล้วหล่ะ แต่ผมใช้ PotPlayer ^ ^
            Version ใหม่นี่กดใช้ Hardware หรือ Software ถอดรหัสที่คอลโซลด้านหน้าได้เลยสะดวกดีครับ
              PotPlayer แต่ก่อนผมก็ใช้ ติดใจมาก เหมาะปรับ config ได้กระจาย
              แต่ปัจจุบันนี้ ใช้แต่ MPC ตัวเล็กดี ตัวอื่นไม่ได้สนใจลงเลย ใช้แต่ MPC ดูอย่างเดียวเลย
                เดียวนะ...ช่างแอร์ในตำนาน ซะด้วยย
                  MPC-HC v1.7.10.56 ดีจริง
                  MPC ที่เคยใช้ๆมานี่ ส่วนใหญ่ ปรกตินี่ บางเรื่องที่เป็น DVD นี่จะเปิดหน้า Menu ไม่ได้เลย
                  ชอบมีปัญหาเวลาดูไฟล์ ที่เป็นแบบ DVD
                  รุ่นนี้นี่ ดู เมนู DVD ได้ปรกติ ละมั้ง หรือป่าวหว่า 555+
                    ลองแล้วครับสีสวยขึ้นจริงแต่ RGB มันได้เฟรมมากสุด 24 เฟรม ซึ่ง NV12 มันปั่นเฟรมได้ 60 เฟรม ปกติใช่ไหมครับ
                      อันนี้ไม่รู้เหมือนกันครับ รอท่านอื่นบอกละกันครับ
                      พอดีผมดูแต่ อนิเม 24 เฟรม แล้วเปิดใช้ AMD Fluid Motion Video
                      ดูอนิเมจาก 24>ไป 60 fps นะครับ ดูอนิเม 60 fps กับ RGB32 ได้ 60 fps ปรกตินะครับ
                        ทำไมกระทู้ได้ดาวเดียวตลอด
                          ถามคนโหวต น่าจะได้คำตอบตรงสุด
                            อย่าไปสนใจเรื่องดาวเลยครับ มันอยู่ที่คนกด ถ้าอคติก็กดให้น้อยตลอดแหละห้ามกันไม่ได้
                            ดูที่สาระของกระทู้ดีกว่าครับ ^ ^
                              ผมก็งง ใครก็ช่างกดไม่ดูเนื้อหาในกระทู้ เห็นตา THE FOOL โพสไรนี่ดาวเดียวตลอด กระทู้บางกระทู้นี่ไม่สมควรจะได้ดันได้
