Adobe Premier Pro ในเวอร์ชันล่าสุดพร้อมสนับสนุน OpenCL จากฝั่ง AMD แล้ว R9 290 Series
  • Adobe Premier Pro ในเวอร์ชันล่าสุดพร้อมสนับสนุน OpenCL จากฝั่ง AMD แล้ว R9 290 Series
    Premiere Pro CC Update (7.2.1)
    Today we have released an update to the December 2013 Premiere Pro CC release, with several important bug fixes. This update is recommended for all users. You can install the update through the Creative Cloud desktop application, or you can check for new updates from within any Adobe application by choosing Help > Updates. Ideally, you should install the updates automatically through the Creative Cloud desktop application or by choosing Help > Updates, but you can also directly download the update packages from the download page for Windows or Mac OS. Note that if updates aren?t visible in the Creative Cloud app, quitting and relaunching may help.
    issues fixed with this release:
    ?Intermittent Buzzing could occur on audio playback where audio transitions were present
    ?Reveal in project sometimes did not work in imported sequence when clips were present in the project
    ?Premiere Pro could occasionally crash on playback of certain multi cam assets
    ?Using matte cleanup tools in Ultra keyer could sometimes cause the top half of the image to disappear when paused in Open CL mode
    ?Autosave could sometimes interrupt playback.
    ?The AMD Radeon R9 290 Series has been added to the OpenCL supported card list
    ?Inserting a merged clip with in/out points via menu or command would insert the entire merged clip, not the in/out range
    ?Playing with preroll could sometime crash Premiere Pro
    ?When editing in Anywhere mode, adding synthetics would sometimes show a 10 digit number under the progress panel?s Name column
    http://www.adobe.com/support/downloa...atform=Windows
    Originally posted by Hkz3efoxz
    http://forum.tirkx.com/main/showthre...8%B7%E0%B8%AD-!
    Adobe Premier Pro ในเวอร์ชันล่าสุดพร้อมสนับสนุน OpenCL จากฝั่ง AMD แล้ว ซึ่งหลังจากคบกับ CUDA อยู่นาน กับการใช้ GPU มาช่วยในการประมวลผล และแล้วเมื่อ Adobe ได้ลองหันมาคบกับ OpenCL ดูบ้างนั้น ผลที่ออกมาคือ แจ่มช้างเลยครับพี่น้อง ซึ่ง AMD ได้มีการ DEMO โชว์ในงาน NAB2013 ที่แสดงให้เห็นว่าชัดๆไปเลยว่า OpenCL นั้นเหนือกว่า CUDA หลายขุมนัก โดยการทดสอบนั้นใช้การ์ดทำงานในตระกูล FireGL และ Quadro มาประชันกัน แต่ไม่เพียงแค่การ์ดในตระกูล Workstation เท่านั้นที่จะใช้งานทาง Adobe บอกด้วยว่าการ์ดสำหรับเล่นเกมส์ทั่วๆไปที่รองรับ OpenCL อย่าง Radeon HD และ APU ก็ใช้งานได้ด้วยนะเออ..!!!
    เอาแล้วไง เมื่อพลัง OpenCL ออกมาดีแบบนี้ ถ้าเกิดผู้ผลิต Software หลายๆเจ้าต่างพาเหรดมาเล่นด้วยนี่งานเข้า CUDA เลยล่ะ หลังจากที่เป็นจุดขายมานาน เริ่มสนุกอีกแล้วครับตลาดกราฟิกการ์ด ที่ไม่เพียงแต่เกมส์มิ่งซีรีย์แต่ลามไปถึงการ์ด Workstation ด้วยเลยทีเดียว
    ที่มา+เพิ่มเติม : http://www.rage3d.com/articles/hardware/amdopencladobe/
    Cr::ZoLKoRn
    สามารถใช้ได้ทั้งการ์ด Firepro & การ์ด เล่นเกมส์ธรรมดา (5xxx,6xxx,7xxx Series รุ่นต่ำกว่านั้นไม่ได้แน่ใจ) สรุปใช้ได้ทั้งหมด !
    สำหรับคนที่ขี้เกียคลิกลิ้ง อ่านได้เลย !
    Real-time work flows are made easier and smoother on OpenCL enabled devices with Adobe's new Premier Pro, previewed yesterday by Adobe and AMD. The new version of Premiere Pro supports OpenCL accelerated effects on AMD FirePro discrete graphics and APUs, as well as AMD's consumer line of graphics products like Radeon GPUs and A-series APUs.
    AMD will be demonstrating the effects of OpenCL acceleration in person at NAB 2013, the National Association of Broadcasters exhibition and conference which begins on Monday, April 8th in Las Vegas. Along with Dell, AMD will be partnered with Adobe to showcase the OpenCL accelerated Mercury engine in Premiere Pro next, on AMD's FirePro series of workstation cards for professional use.
    AMD's internal testing shows the addition of a FirePro W-series graphics card can run Adobe Premiere Pro effects accelerated by OpenCL by up to six times. The basis for comparison here is an older workstation, where it makes more sense to replace just the GPU and update to the new version of the software than it does to buy a new box and software; the lion's share of performance is in the GPU now.
    AMD can also show the difference between NVIDIA's latest Kepler based Quadro workstation cards using CUDA and AMD FirePro cards featuring GCN architecture and using OpenCL accelerated effects. The performance increase varies by product but the more affordable solution, the FirePro W5000, is claimed to be 27% faster than NVIDIA's Quadro K2000. At the same ~$499USD price point, that makes the FirePro a compelling option over the Quadro card, ostensibly a quarter more performance for free.
    AMD's as of yet unreleased Richland APU will see benefits, with the integrated Radeon HD 8670D graphics of the A10-6800K speeding up a color corrector effect by upto 4.3 times over the quad core CPU alone. Acceleration rates like that make more advanced effects and editing more palatable to more users, something that will help adoption rates of AMD APUs for prosumers and hobby video enthusiasts.
    The enhancements to Adobe Premiere Pro put Windows users in a position to compete with Mac users, who have had OpenCL acceleration for some time. The list of accelerated effects includes, but is not limited to:
    • ProcAmp
    • Sharpen
    • Color Balance (RGB)
    • RGB Color Corrector
    • Lumetri -- Compression 1
    • Lumetri -- Cinematic 1
    • Lumetri -- Sepia
    • Lumetri -- B&W Yellow Filter
    • Lumetri -- Maxiumum Desaturation
    • Lumetri -- Back in the Day
    • Lumetri -- Dreams 2
    • Lumetri -- Duo-toning
    • Lumetri -- Warm Overall
    Effects such as these can provide adjustments to video footage that offer primary and secondary color correction, gamma irregularities, color shifts, color layering and matching in real time, so users can preview changes in real time on marked segments of video before committing to the full render.
    In a press release today, Neal Robison, Senior Director of Software Alliances at AMD spoke of creativity at the speed of thought:
    "AMD and Adobe are dedicated to delivering professional and consumer level solutions that support open standards and provide artists everywhere with the ability to create at the speed of thought. Through AMD's strong relationship with Adobe, video editors no longer have to wait for the rendering of edits, effects, and composites - most everything can now be achieved at high-quality in real-time."
    Support for OpenCL in a high profile application like Adobe Premiere Pro is a great step for AMD. In a single product update, the performance and capabilities of their existing install base has been increased usefully. Ideally this trend towards common and open standards will be pervasive across all ISVs, and Adobe will be joined by many other big names looking to use OpenCL to remain competitive and innovative for their future products.
    ลองอ่านดู
    R9 290 Series นี่ ใช้ยัน ตั้งแต่เกม ยันทำงานเลย
    โหดสัส
    เอื้อเฟื้อเผื่อแผ่ R9 ซีรีย์อื่นด้วยสิพี่
      เห็นว่าไว้แบบนี้นะ
      เจอรูปมา APU ยังได้
        ต้องเป็นตัว premiere pro cc แล้วอัพ 7.2.1 มันยัด r9 290 ให้แล้วแต่อยากเห็นคนลองจริงว่า r9 ใช้กันได้จริงไหม ถ้าได้ก็
          จัดเลยสิจะได้รู้ทั่วกัน
            อีกหนึ่งข่าวดี อิอิ
              ใครขายการ์ดจอเยอะๆ อยู่ลองจัดเลย มีหลายรุ่นนิ 555555555+
              โยนให้ซะ
                ผมทำให้ได้นะ ติดอยู่อย่างเดียวเองครับ คือ ผมไม่มีตัง
                  ผมทดลองใช้ตัว 30 วัน ผมใช้การ์จอ R9 290 พออัฟเดทเป็นตัว 7.2.1 พอเปิดมาเท่านั้นโปรแกรมปิดตัวเลย -.- สงสัยต้องจัดของแท้สินะ 55+
                    รอ AE ซับพอร์ตอยู่นะ เช็ค 3D Ray Tracing ผ่าน แต่ใช้ไม่ได้
                    ซับพอร์ตไว ๆ นะ
                      เป็นมาตาฐานละใช้ทั้งสามค่าย ค่ายแดงแรงสุดในด้านนี้
                          เหมือนช่วงหลังadobe จะปลื้มopen CL มาเลยนะครับ
                            ผมจะไปเล่น เขียวก็เพราะว่าจะเล่น AE นี่แหละพอเห็นว่าแดงจะรองรับเนี้ยยังลังเลเลยว่า จะเขียวหรือแดงดี เขียวดีกว่าก็ไปเขียวแต่ถ้าแดงดีกว่าเขียวก็จะไปแดง รออย่างเดียวเลยตอนนี้
                              สุดยอดมากครับ //แต่ผมใช้ Vegas 555555555555555+
