AMD CrossFireX : AFR Friendly mode เพิ่มความแรง 20+ fps ในเกมส์ได้ง่ายๆแค่ 2 คลิ๊ก
เพิ่มความแรง เพิ่มประสิทธิภาพการทำงาน CrossFire 50 เปอร์เซนต์ กันเลย
http://uppic.zubza.com/images/1345334622751_24.jpg
ก่อน 41 fps+
Default settings:
http://i228.photobucket.com/albums/e...671/twoway.jpg
หลัง 61 fps+
AFR Friendly mode forced on:
http://i228.photobucket.com/albums/e...1/threeway.jpg
ที่มาจาก moheban79
Member Guru
My average fps in Skyrim @5670x1080 Eyefinity Trifire is finally scaling like it should. I've included a couple cropped snap shots of with the Default settings vs after AFR Friendly mode forced on. You can see a marked 50 percent increase in performance. The only thing is sometimes the water effects flicker a little but its not bad. I have vsync forced on and also am using Widescreen fixer. Anyhow before 12.8 the scaling wasn't this good. Shame that it took so long for AMD to support the enthusiast features for a popular game thats been out a year.
The following images have been cropped and have used Afterburner to make note of Temperature, GPU utilization, Fan speed, and GPU clock speed in that order as you can see.
http://forums.guru3d.com/showthread.php?t=367183&page=9
ก่อน 41 fps+
Default settings:
หลัง 61 fps+
ที่มาจาก moheban79
Member Guru
