PotPlayer 1.5.26695 Update ใครมีปัญหา ใช้ GPU ถอดระหัสดูหนังแทน CPU ไม่ได้มาใช้คับ
ออกใหม่ล่าสุด PotPlayer 1.5.26695
ใช้ GPU ถอดรหัส แทน CPU ในการ์ดดูหนัง
Uploaded with ImageShack.us
PureCodec 20110126 ออกใหม่ล่าสุด อีกโปรแกรม
http://jm.wmzhe.com/
Daum PotPlayer 1.5.26695 Beta
Fixed a problem that some fonts invisible in font selection
Added an option to show bookmarks on navigation bar
Fixed a problem that does not recognize bookmarks on some MP4 files
Daum PotPlayer 1.5.26654 Beta
Added support of album art visual effects
Fixed error problem while closing the program
Daum PotPlayer 1.5.26588 Beta
A specific support for WMA audio decoder to fix some problems
Daum PotPlayer 1.5.26481 Beta
Some fixs while playing VC-1 files
Daum PotPlayer 1.5.26437 Beta
Changes in visual of album art
Support for a few album art functions (with mouse click to switch)
Fixed error problem of high resolution video recording
Daum PotPlayer 1.5.26392 - x86/x64 Stable
- This version is the latest announced version on http://tvpot.daum.net/video/live/PotplayerSpec.do (in Korean) -
Daum PotPlayer 1.5.26387 Beta
Daum PotPlayer 1.5.26384 Beta
Added remember finished action function
Bug fixed in EAC3 PassThrough
Bug fixed in visualization
Some AAC audio support
Daum PotPlayer 1.5.26332 Beta
Fixed green screen problem on Nvidia cards while playing H264 videos with DXVA
Daum PotPlayer 1.5.26310 Beta
Added the ability to set temporary storage folder
Some changes in subtitles handling
Daum PotPlayer 1.5.26295 Beta
Added support of BIK files
Added display album cover while playing music
Added an option to playlist settings to show file extension
Daum PotPlayer 1.5.26229 Beta
Fixed audio playback problem of MP4 files
Improved INI file handling
Daum PotPlayer 1.5.26143
Optimize RTSP playback
Chat management page changes reflect at real-time
Fixed a bug with other users in chat
Fixed inconsistency in the user name and nickname
Daum PotPlayer 1.5.26107 Beta
Added auto delete bookmark function
Improved file delete function
Fixed a problem that RT subtitle file could not handle properly
Fixed problems while playing FLV video files
Daum PotPlayer 1.5.26036 Beta
Improved motion blur feature
*Some fixs in built-in codecs
Daum PotPlayer 1.5.25875 Beta
Added 0.1 second adjust to AB repeat function
Fixed a problem where AB repeat display incorrectly
Fixed problems in multi-core video processing
Daum PotPlayer 1.5.25819
Added motion blur function
Fixed a problem that where the extension disconnected
Daum PotPlayer 1.5.25770 Beta
Fixed screen tearing issues of some ASF file playback
Fixed compatibility issues of HDTV playback with using DXVA and subtitles
*Control Panel (select skins > original_new_en.dsf and press F7 for this) now in english (Thanks to bolota)
Daum PotPlayer 1.5.25720 Beta
Added custom color theme feature
Fixed in stored login information
Daum PotPlayer 1.5.25717 Beta
Fixed a problem that the album disappear from specific condition
Fixed a problem that the control panel does not disappear when minimized
Daum PotPlayer 1.5.25705
Daum PotPlayer 1.5.25669 Beta
Added a new skin
Added a control window to the new skin (in korean)
Added the ability to play DVDs for playback on the previous position
Changed adjustment based on the modification of window size control
Fixed a problem that where the overlay mixer is in use without subtitles
Changed multiple execution live and mini to operate individually
Daum PotPlayer 1.5.25642
Added auto-login feature
Added RTSP protocol
Added chat ban function
Fixed a problem that some videos did not work with Winamp DSP plug-in modification
Changed some shortcuts
*Other fixes for known problems of users recent feedback (subtitles, bookmark....)
Daum PotPlayer 1.5.25231 Beta
Daum PotPlayer 1.5.25194 Beta
Built-in codecs as default for WMV7/8/9
Fixed a problem that some PC were terminated when mouse right button is pressed
Slideshow of visualization output can be modified
Fixed in some novelties SRT subtitle reading
Daum PotPlayer 1.5.25055 Beta
*Improved image overlay on screen feature (Direct3D, LayeredWindow)
Daum PotPlayer 1.5.24796 Beta
Daum PotPlayer 1.5.24775 Beta
Added a skin function output feature
Added translucent skin function mode
Some fixs that occured while playing MPEG2 files
Fixed a problem that when often search stopped while playing a .MP4 file
Daum PotPlayer 1.5.24704 Beta
*Some fixs for "unhandled exception occurred" error messages..
Daum PotPlayer 1.5.24685 Beta
Added file information feature to playlist
Some fixs for Win Vista to allows more control
Fixed a problem in Built-in subtitles that when often search stopped while playing a .mkv file
Some fixs for built-in PAL DVD playback codec or problem behaviors
Daum PotPlayer 1.5.24362 Beta
Fixed a problem that INI saving operation was over environmental management
Fixed H264 DXVA problem while watching TV or video recording
Fixed a problem that screen horde of DV files when double sound track playing
Daum PotPlayer 1.5.24274 Beta
Fixed a problem in bookmark
Fixed a related broadcast problem
Daum PotPlayer 1.5.24134 Beta
*Fixed some known issues
Daum PotPlayer 1.5.24117 Beta
Fixed a problem that where subtitles does not come out from a part of MP4 file
Fixed a problem that EVR did not click when using DVD menu
Fixed a temporary noise problem
Fixed Pixel shader problem while watching digital TV
Other bug fixes
Change Color Space (YUY2, NV12, YV12 moderately optional)
Changed ini file saving to unicode
Daum PotPlayer 1.5.23965 Beta
Fixed broadcasting buffer problems
*Some fixes in video recording synchronization, file synchronization, screenshots
Daum PotPlayer 1.5.23885 Beta
Added GIF logo features for broadcasting
Added Flash File (SWF format) logo features for broadcasting (32-bit)
*Fixed issues related smooth subtitles, DVD playback authorization
Daum PotPlayer 1.5.23767 Beta
Added ability to use Direct3D 9Ex
Added Font smooth overall output function
Fixed audio problem for some MP4 files
Logo to be used to modify animated GIF images
Fixed a problem that broadcasting logo PNG alpha channel was handled incorrectly
Fixed a problem that the program did not run on older CPU
Fixed a problem while temporary files are deleted
Fixed a skin problem that mouse did not work in the area of treatment
Added preffered audio option
Added Subtitles force left-aligned option
Daum PotPlayer 1.5.23507 Beta
Add a command line parameters (/autoplay)
Fixed some H264 TS file playback recognition problems
Fixed refresh issues of file association
Fixed bookmarks/chapters identify display problems
Fixed ARGB -> YV12 color conversion error problem
Daum PotPlayer 1.5.23457 Beta
Fixed aspect ratio calculation problem when using EVR renderer
Fixed Intel GMA-HD video card black screen problem with using DXVA
Fixed playlist sort problem
Daum PotPlayer 1.5.23408 Beta
Add move video window to screen center while starting playback
Add retain subtitles bottom margin feature
Add directly save DHTV stream
Fixed invalid argument error problem that occured in some computer
Fixed some VC-1 encoded video playback that can not be decoded with DMO
Fixed some problem in DTS and DTS-HD
Daum PotPlayer 1.5.23336 Beta
Add search function to the play list
Add repeat setting function
Fixed some memory error problem while broadcasting running
Fixed broadcasting sync problem while recording
Fixed a problem while adding files to playlist from explorer
Daum PotPlayer 1.5.23326 Beta
Fixed a problem that mouse cursor does not hide automatically
Winamp playback video link correction
Fixed a problem that the file can not open if folder has hidden attribute
Daum PotPlayer 1.5.23312 Beta
Daum PotPlayer 1.5.23311 Beta
Improved the inter-word tagging subtitles
Fixed some MP4 files audio playback problems
Fixed some damage AVI playback problems
Daum PotPlayer 1.5.23269 Beta
Fixed issues with switching to madVR renderer
Daum PotPlayer 1.5.23260 Beta
Update built-in decoder (to be tested)
Daum PotPlayer 1.5.23234 Beta
Add time limit of subtitle function
Add FLAC source filter selection
Add FLAC audio codec selection
Daum PotPlayer 1.5.23127 Beta
Add subtitles border transparent function
Add can automatically switch the standard audio mode in the Configuration Manager
Add saving subtitles named filmname
Add subtitles Fade effect function
Add Trying to load the subtitle file folder if there are no matching subtitles available
Add a built-in audio renderer (cross-fade function)
Changes in to the individual computer program to play H.264 suspended animation issues
Fixed initialization specific album art problem
Fixed position of each switch configuration state of preservation
Fixed deadlock issue procedural security measures
Fixed adjust speed when broadcast can not be played in the current location
Improved special broadcast buffer mode
Daum PotPlayer 1.5.22857 Beta
Add next generation EAC3, TrueHD, DTS-HD MA through functions
Add WebM Play recording
Add analog TV time positioning functions
Improved external decoder subtitle synchronization
Fixed DVB machine FusionHDTV Express search problems
Fixed playing MPEG file locking problem
Daum PotPlayer 1.5.22627 Beta
Add VP8 coding support
Add WebM playback
Fixed related skin issues
Daum PotPlayer 1.5.22578 Beta
Add a pointer to hover in the search bar to display time information
Add a shutdown feature at a specific time
Add frame playback delay
Add automatic identification interlaced scanning of TV Movies
Improved broadcast buffer mode
Fixed some problems in the setting screen on Vista
Fixed in TV card/full-screen game/broadcast problem
Fixed audio track switching BDA issue of machine flexibility
Other bug fixes
Daum PotPlayer 1.5.22347 Beta
Add DVD playback speed
Add a custom volume adjustment
Fixed some MP4 files subtitles synchronized issues
Fixed problem when more than 3 audio tracks in AC3 SPDIF output compression
Fixed sound problem with the noise on broadcasting
Fixed invalid position of subtitles output word spacing settings
Fixed audio decoder playback delays on 64-bit system
Fixed failure menu shortcuts
Fixed deleting some temporary files
Fixed screen using with keyboard shortcuts to minimize
Fixed screen tearing play problem in some MPEG2 files
Fixed MPEG2 <-> H.264 can not be converted to play in the BDA issue
Fixed security of chat module
Daum PotPlayer 1.5.22243 Beta
Update Built-in Codecs
Adjust some default settings
Other bug fixes
Daum PotPlayer 1.5.22219 Beta
Remake DRM
Fixed EVR CP 60-frame playback problem
Some fixs
Daum PotPlayer 1.5.22155 Beta
Fixed the problem of skin garbled output message (UTF-8 +)
Built-in decoder update
Fixed Built-in decoder on initial configuration
Fixed playback control method
Fixed recording broadcast error problem
Fixed time display problem caused by procedural error
Improved de-interlacing functionality video compression
Improved text rendering issues
Daum PotPlayer 1.5.22033 Beta
Improvements of the built-in decoder
Add a video coding compression, + Deinterlacing
Daum PotPlayer 1.5.22016 Beta
* Re-configure the form design parameters
* Simplified main menu
+ Add subtitles Fade Effect
+ Add captions to the output surface mode features in the map
+ Add MadVR renderer
+ Add Play online media positioning function when the slider
+ Add playlist album features
+ Add playlist function temporary queue
+ Add MultiThread H.264 multi-threaded decoding
+ Add playlist tabs
+ Add to display file information MediaInfo components
+ Add a form to set the translucent feature
+ Add images 90-degree rotation
+ Add images migration functionality
+ Add Windows7 Taskbar support
+ Add bookmark function to display thumbnails
+ Add record format can be saved as ASF, OGV format
+ Add self-closing feature when play finished
+ Add a custom boot size function
+ Add file navigator
+ Add to open the streamlined menu
+ Add function to view the summary information
+ Add a voice filter process can be immediately reset function
- Updated built-in decoder
- Fixed some problems can not load subtitles
- Fixed can not load the first two drives in the subtitle problem
- Update VMR9 without rendering and rendering renderer EVR Recommended
- Enhanced (MPEG, NSV, OGG, REAL, MP4) file playback
- Support for simultaneous recording of two or more media video
- Enhance the seamless playback
- To improve the video, audio processing
- Improved video recording
- To improve the frame rate processing demand
- Improve the DXVA decoder
- Fixed some special H.264 files after sliding the screen Loss
- Fixed output HD-DVD's subtitles high CPU utilization problem
- Fixed use of images in a specific ratio of the screen is lost when cutting issues
- Open similar documents to improve the logic
- Adjust the Vista or Windows7 of VMR7, VMR9, EVR mode distribution
- Can edit subtitles cover
- Detailed information output mode
- To improve the Explorer file association
- Some PC play a specific broadcast lead to CPU 100% occupancy rate of
- Fixed some functional problems for the broadcast of the invalid
- Modify the image filter in use immediately reset function
- Fixed the screen output ratio imbalance
- Fixed other known issues
Daum PotPlayer 1.4.20896 Beta
Some changes for Chat and personal TV..
*Important note to people who use "DirectShowSpy" (DirectShow Filter Graph Spy) !
PotPlayer does not like this tool..And the solution for Win Vista and Seven, unchecking "remove the lock-ups when opening files" option will be solved this problem..(PotPlayer EN Setup, will do this automatically!)..But in Win XP, it does not work that way..So on the XP, you need to unregister DirectShowSpy.dll or else program gives an error like "Unhandled exception occurred...."
*DirectShowSpy (DirectShow Filter Graph Spy) kullananlara önemli not !
PotPlayer bu araçdan pek hoşlanmıyor..Vista ve 7 için çözüm, "remove the lock-ups when opening files" ayarı işaretlenmez se sorun çözülür..(PotPlayer setup bu ayarı otomatik yapar!) Ancak XP de bu ayar işe yaramıyor..O yüzden XP de "Unhandled exception occurred...." gibi bir hata almamak için DirectShowSpy.dll unregister edilmelidir..
Daum PotPlayer 1.4.20879 Beta (in English!)
Ban HTML tag used during a chat
Improvement chat room error
*To see history of previous versions of the program read the "History.txt" (Translated from korean to english on translate.google.com)
*Thanks to friends who have made a "potplayer1.4.20715ru.exe" !
http://www.dvbsupport.net/download/i...ct=view&id=236
http://www.dvbsupport.net/download/i...ct=view&id=239
Added a new skin
Added RTSP protocol
Other bug fixes
Add WebM playback
Other bug fixes
Other bug fixes
Remake DRM
Some fixs
+ Add playlist tabs
